Question about HP Compaq ProLiant ML350 G3 Server
Hello I have a query guys on hp ML350 server is that at the end of the inauguration of Windows blue screen appears You change the RAM first and then reduce Alhardat from three to two, but without the benefit of When experimenting with IDE Hard Windows see and format the hard and does not appear Please help
  • 922 Answers
The system is not designed to use IDE hard drives which why you are getting a blue screen. It is designed to use SCSI hard drives and IDE CD/DVD drives. It might be possible to go into the server's BIOS setup and change the boot device from the onboard SCSI controller to the IDE controller. It is very likely that you will have to disconnect all SCSI devices to boot to IDE, if it is possible.
I hope this helps.
Posted on Mar 06, 2013
5 Suggested Answers
Yazz226
  • 497 Answers
SOURCE: Trying to install Windows 2003 on to ML350 G3 server
http://www.downloadatoz.com/driver/item_199703.html
try this
Have a nice day!
tc
Posted on Jun 13, 2008
Mustgo
  • 2359 Answers
SOURCE: My HP ProLiant ML350 G5
There was a critical HP ProLiant ML350 G5 ROM BIO upgrade dated on 17 Aug 2010.
Please bookmark the bio update link HERE for reference.
Check your monitor Hz and display resolution setting.
Did you change any video driver or resolution before reboot?
If all else fail then swap in a simple S-VGA card and let Windows 2003 to sort out the 640X480 display mode.
Posted on Jan 05, 2011
info2u
  • 596 Answers
SOURCE: my server is keeping booting and can't log in to windows
You issue could be both hardware and software related. The Blue Screen of Death is one that I don't like to see but can be easy to solve at times. First, I would recommend you recheck and hardware that was newly installed; memory cards, cables, etc. Verify they are connected or inserted correctly. Next, if this is a new install of Windows 2008, verify that your server meets the hardware captiablity for S2008. (Remember, this is a 64-bit os and you will need drivers if your server is 32-bit based.) You can find this out by inserting the Windows Server 2008 boot disc and run the Check System for Compatiablity function from the menu.
If you are certain that you have no hardware issues and the install was performed correctly, you may need to reinstall Server '08 and monitor the install for any exceptions that may occur.
Good Luck,
C2Solutions
Posted on Nov 25, 2011
Hp Proliant ML350 g4 will not power on. System was on but not responding so used power button to shut down. Now no response to pressing power button. No LEDs lit anywhere. Fans running on power supplies.
sounds like the motherboard has gone.... you could try changing the PSU and popping out some of the ram boards to see if that helps. but with the symptoms you've said, i'd say its the motherboard.
Oct 28, 2013 | HP ProLiant ML350 G4 Server
My server is keeping booting and can't log in to windows
Good Luck,
C2Solutions
Nov 25, 2011 | HP ProLiant ML110 Server
I have a proliant ml350 g3 rack mounted server that is in a constant reboot loop. It once gave a blue screen of death with the error message of NME Parity error, so I took out all but one RAM stick and...
Put RAM's in Identical form and check.
clear NVRAM and Check.
check the array controller
update BIOS and Array controller firmware ( disconnect HDD's from the cage before
updating the latest Firmware( download from hp.com/support and drivers )
May 27, 2011 | HP Compaq ProLiant ML350 G3 Server
My HP ProLiant ML350 G5 failed to boot to Windows. After showing Windows 2003 Server, blank screen comes up
Jan 05, 2011 | HP Compaq ProLiant ML350 G5 Server
Problem with harddrive
It could be because the disk is not a part of any array. Log into the server and go to the array controller utility from HP and check for any unassigned disks. It will be displayed there rather than the diskmanagement window.
Feb 01, 2010 | HP Compaq ProLiant ML350 G3 Server
HP SERVER PROBLEM
You should be using a 110 voltage cable if you are in the USA.
Jun 14, 2009 | HP ProLiant ML350 G5 Server
HP Compaq ProLiant ML350 G3 Server Logo
124 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
