Error code s33-2032 for riso comcolor 3050
The printer displays error code s33-2032 when attempting to clean the printheads
  • 5 Answers
SOURCE: Error Code T14 on Riso GR3770
press reset .. is drum in home pos. ?
Posted on Feb 09, 2009
SOURCE: Riso HC5500 error code
Hc5000 System Error S03-231
Posted on Mar 26, 2009
  • 22 Answers
SOURCE: RISO RZ200
D22-542 is saying that there's a problem with the printed circuit board on the print drum. It's not communicating with the machine. D04 -534 says that the incorrect ink cartridge is installed. First, is this a new drum you are introducing into the machine? if it is, not all drums are interchangeable. You need to get the right pcb (printed circuit board) for the ink drum you are using to match your machine. Second.. Something is mismatched here with the ink cartridges. The only way you'd get the ink cartridge error is if the drum is in the machine. I had this problem with a Rn 2130 ui.. I bought a used drum off e-bay and it wouldn't work. When I stole the pcb from another color drum it worked fine. If you have been using this drum in this machine before... be sure that the connection between the drum and the machine is good. Make sure you have the right ink cartridge too. Some of these aftermarked re-sellers sell stuff that doesn't line up with the tabs on the inside.. I've got some ink here that if you hold your toungue just right and turn the tube about 2 degrees it'l work.
Posted on Aug 14, 2009
  • 76 Answers
SOURCE: Have riso cr1610 - prints for few copies, stops,
Ink overflow. Fit new squeezy gear in drum.
Posted on Oct 08, 2009
  • 51 Answers
SOURCE: LL.50; Call for assistance; error code displayed
one the back side there is a 26v power supply it may gone just check it
Posted on Dec 12, 2010
WHAT TO DO WHEN I HAVE AN ERROR CODE B200. i CANNOT PRINT AS THE MESSAGE IS CONTACT YOUR SERVICE PROVIDER. IS THERE A WAY I CAN FIX IT MYSELF////
Hi Kathleen,
to clear the Canon B200 error code:
Steps for 4+ Cartridge Printers
  1. Remove All Cartridges. Do whatever is necessary to remove the individual ink cartridges from your printer. In most cases this will be opening the lid of your printer and waiting for the cartridge cradle to move into the correct position.
  2. Remove the Printhead. This is easily achieved in most printers by simply lifting the orange/gray locking lever on the side of the cartridge cradle and then gently lifting the printhead from the printer.
  3. Reinstall the Printhead. Gently put the printhead back into your Canon Pixma printer and lock it into position firmly.
  4. Reinstall All Cartridges. Place all of the cartridges back into the printer and close any open doors. This makes sure that your printer is actively examining the reinstalled cartridges and printhead.
  5. Unplug the Printer. Physically remove your printers plug from the wall and leave it unplugged for 5+ minutes. This allows the printhead to cool and all residual electricity to leave the printer.
  6. Plug the Printer Back.
  7. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
Steps for 2 Cartridge Printers
  1. Turn the Printer off. When your printer is in this error state it will not let the cartridge cradle within the printer move. However resetting the printer should clear the error message temporarily allowing us to troubleshoot further.
  2. Turn the Printer Back on Again.
  3. Remove the Problem Cartridge. Whilst the Canon Pixma error messages do not tend to specify which cartridge is causing the problem, you should be able to have a rough idea based upon which cartridge was last replaced.
  4. Install a Replacement Cartridge. As the printhead is part of the cartridge, sadly there is no way to stop the B200 error without replacing the cartridge. I would recommend either installing a new cartridge or a previously used cartridge that you know to be functional.
  5. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
  6. If Necessary Replace the Other Cartridge. If the error persists with the new cartridge, it may be that the other cartridge has developed a fault and is the cause of the B200 support code. If at this point the error remians I can only recommend replacing the other cartridge.
Aug 11, 2017 | The Office Equipment & Supplies
I have an error message B200
Hi Kathleen,
Aug 11, 2017 | Office Equipment & Supplies
Print head
The carriage does not accept one or more of the printheads. Typical causes are dirty contacts on the printheads or carriage, defective printhead(s), or a defective carriage.
If parts are replaced or fixed in any of the steps listed below, attempt to verify printer functionality by turning the printer on and printing internal test prints. If functionality is verified, no additional parts should be replaced.
  1. Turn the printer on.
  2. Allow printer to complete initialization.
  3. With the printhead icon highlighted, press ENTER.
  4. Select Replace Printheads and press ENTER.
  5. If the message "Printheads still functional" appears, select Yes to continue testing the printheads.
  6. Open the top cover.
  7. Open the carriage cover and remove all of the printheads.
  8. Turn the printer off.
  9. Clean the electrical contacts on the carriage and the printheads using a lint-free cloth dampened with water.
  10. (for this step I suggest using the erraser on the back of a regular pencil instead of a cloth and water)
  11. Allow the contacts to dry.
  12. Reinstall the printheads and close the carriage cover.
  13. Close the top cover.
  14. Turn the printer on and attempt to verify functionality, as instructed in Step 19.
  15. If the error reappears, replace the affected printhead(s).
    NOTE: If the printhead error icon is a question mark, each printhead will have to be tested separately, as the printer is not sure which printhead is causing the problem.
    1. Following replacement of the suspect printhead(s), attempt to verify functionality (Step 19).
    2. If the problem persists following, replace the carriage and trailing cable (refer to pages 8-36 to 8-46 of the service manual).
    3. Following replacement, turn the printer on.
    4. Make sure the printhead alignment completes successfully and that no error messages appear on the front panel.
    5. Print a troubleshooting plot (as instructed below) to ensure the print quality is acceptable.
      1. On the front panel, select the printer icon and press ENTER.
      2. Select Utilities and press ENTER.
      3. Press the UP and ENTER buttons simultaneously.
      4. Select Yes to enter the Service Menu.
      5. Select Service Utilities and press ENTER.
      6. Print pages 1, 2, 3, 4 and 5 to prove printer functionality.
Mar 25, 2014 | HP DesignJet 5500PS InkJet Printer
Ink system failure....error code 0xc19a0013....what is this error code and how do i clear it....
What is HP Printer Error 0xc19a0013 & How to Solve the Error ? 0xc19a0013 ink system failure error shows in the control panel of printer.
Reason of occurring this error message is listed below:
  • HP printer setup may not be installed properly.
  • Printer cartridges low message.
  • Printer cartridge is damage or not inserted properly.
How to Solve "0xc19a0013" Error Code for HP Printer
  • Change low or empty cartridges: in case ink alert message is display before this message. Changing the cartridges may solve the issue.
  • Make sure the printer cartridge is installed or inserted correctly
  • Remove the printer cartridge and reinstall that.
  • Use HP Printer Automatic Cleaning Utility to Printheads:In case the error message is occurring ,use automatic cleaning utility of printer for printhead cleanup
  • Update the Printer Drivers :It may happens due to outdated printer drivers. We recommend you this to update your HP printer drivers on regular bases for smooth and flawless printing
In case your HP printer still display the error message best option is to dial HP Printer technical support Phone number-1-800-436-0509 (US), +44-800-078-6054 (UK), +61-1800-769-903 (AUS)
1 800 436 0509 HP Printer Technical Support Phone Number
Jan 04, 2011 | HP Officejet 6500 Wireless All-in-One...
Error code 110 service printhead error. What does this mean
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
You need to follow these instructions:
1) Power the printer off and unplug the power cord. Wait at least 20 seconds and then plug the power cord directly into a grounded outlet.
2) Power the printer back on to see if the error persists.
3) If the error is still present, power the printer off once more.
4) Black Printer Head is responsible Error code 110.
5) Remove the toner cartridge associated with the error code and attempt to clean the external optics of the color printhead that is returning the error message. Do the following:
Carefully clean the printhead lens (B) and the hsync mirror (A) with a soft, lint-free cloth or tissue (Figure).
6) Reinstall the cartridge, close the front cover securely, and power the printer back on.
Have a nice day...don't forget to rate the solution.
Feb 19, 2010 | Lexmark C750 Laser Printer
Error 5400? what is the problem and how do i fix?
the 5400 error is telling you there was excessive temperature in the printhead, and this error code will stop all printing attempts.
Unplug the power from the printer and leave it off for a hour and then check the pins inside the carriage and clean them and clean the contacts on the back of the head.
Jul 19, 2009 | Canon Office Equipment & Supplies
Hp designjet 1050c printer displays a system error
Printhead failure this is.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Regards
Apr 17, 2009 | HP DesignJet 1050c InkJet Printer
Canon i850, service error 6800
This error indicated that the internal printer counter for the waste ink sponge has reached its threshold. You should be able to reset this counter once without cleaning the sponge.
Do this:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
now try press resume button 4 times..after that press the power button
This should clear your error and let you resume printing. If you start getting ink smudges on the paper you will have to disassemble the printer and clean the waste toner sponge.
Jun 17, 2008 | Canon i850 InkJet Photo Printer
Error codes
This error code is usally related to the printhead cartridge not running smoothly on the printhead shaft. Clean the shaft with a paper towel and some alcohol, let dry then take a clean paper towel with some WD-40 and apply to the printhead shaft. Move the printhead assembly from side to side. This should take care of all errors that are 50-59.
Jun 03, 2008 | IBM 4230 Model 102 Matrix Printer
147 people viewed this question
jasbo
jasbo
