Question about Logitech Z-2300 Computer Speakers
Hooking up a Logitech Z-2300 subwoofer to a Yamaha RX-V392 receiv
I have the subwoofer with no cables or speakers and I want to know how to or what cords i will need to connect it to my receiver, please and thank you.
This is the exact same setup im lookng at, just a different Yamaha receiver (RX-V663). Since the 3.5mm headphone jack and and the sub preout are both 'line level' you just need to pick up a male RCA to female 3.5mm jack converter from radioshack. I'd expect it to be around $5-8.
I have already stripped my old 5.1 HTIB system rca connector to use the surround speakers with my receiver. They work but are cheap speakers. Im tempted to do something similar with the z-2300 speakers, much higher quality, but I would definitely use a converter instead of stripping to keep them backwards compatible.
Posted on Apr 11, 2009
No sound from my Yamaha YST-SW315 subwoofer. When I run the test speakers don't have sound either. Not sure if its the subwoofer or the Yamaha RX-V450 receiver
Feed it with an RCA cable any other audio device you may have (CD, TV, MP3 player, PC) to prove it can or can not woof. It will respond to any audio, not just LFE or subwoofer audio.
Apr 14, 2011 | Yamaha YST-SW315 Subwoofer
Just bought a used yamaha receiver model RXv793 do not know how to hook it up.
First do not panic by seeing all sockets in the back side of the receiver.You can connect 5 speakers and one subwoofer on the speaker A switch and maybe a second pair of stereo speakers on the B switch.All the speaker sockets have red and black terminals, so do all speakers. Just get decent cables ( You can buy a whole connection Kit if you want ) and connect the corresponding outlets to you speakers.If you have a powered subwoofer connect the subwoofer input to a socket labeled Subwoofer pre out on the RXV. You will need a RCA to RCA cable for that Next you will need a coaxial or Optic fiber cable to connect a DVD player digitally. The back of the DVD player will have a socket marked coaxial out, and so does the RXV's backside. Just link them .
Turn on the system everything should work. If you are not getting DVD sound there is small button on the RXV front panel called Digital input -- set it to auto ( keep pressing the button and it will scroll through various modes). Also remember to switch on speaker A on the front panel.
Mar 09, 2011 | Yamaha RX-V793
Without being able to access the receiver in person, the best advice I can give you is to sit down with your user manual and follow the instructions. You'll find, starting on page 85, the necessary settings for hooking up a subwoofer to the receiver. If you don't have the manual, you can obtain a pdf file at
May 16, 2010 | Yamaha RX-V663 Receiver
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Jun 26, 2009 | Yamaha HTR-5740 Receiver
Need a hookup diagram for yamaha rx-v461 plus yamaha yst-sw216 please
Here you can find the manual for your subwoofer. Looking at its back side, it has 2 RCA plug input for stereo. Receiver has just mono sub output, but as low frequencies are not easily locatable, mono is perfectly OK.
Just connect receiver SUB-OUTPUT with RCA cable to your subwoofer's RCA LEFT input. Then adjust volume to match rest of your speakers.
Feb 21, 2009 | Yamaha RX-V461 AV Receiver
Hooking Up Wires
This should help you.
You'll need to register but it is free to do so.
Good luck! Login HiFi Engine
Sep 23, 2017 | Yamaha RX-V800 Receiver
Logitech Z-2300 Computer Speakers Logo
888 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
