You neglected to specify the make and model of your camera so I'm going to assume it uses SD/SDHC cards.
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
SOURCE: THIS IS THE SECOND MEMORY CARD THAT HAS GOTTEN
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
SOURCE: everytine I turn my camera on "The card is locked"
Remove memory card from the camera, look along the one edge you should see a small switch, slide it over to unlock the card. the farthest from the contact the switch is in the locked position to prevent deletion of pictures.
SOURCE: When I turn on the camera it is showing "Card
Take a look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try a different card.
SOURCE: My camera suddenly had the message "card locked!".
The problem is your memory card. We can't fix it. The best solution is to buy a new one. Remember if you got an message error like that it shows that your memory card is going to be a dead set. don't use it again it may working for sometime's but suddenly its error appear again and picture got lost. USED A NEW ONE.
SOURCE: I keep getting "card locked!"
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Troubleshooting steps for this problem are listed here.
