Question about HP Color LaserJet 2600n Printer
Printer produces alot of noise while printing
Canon 4570dn squeals loudly when drawing from MP Tray
Hi
It sound like friction noises. it could be because of the rollers and lubrictaion on gears that got hard creating the noise and also produce strain on the feed motor . I would sugest a good service on all mechanical parts.
Dec 05, 2013 | Canon Office Equipment & Supplies
Noise printing to much cyan
Unfortunately, No, there is no "quiet" mode available on these. Keep in mind that this is a high speed 62 page per minute laser printer. The faster printers get, the more noise they are likely to produce. Combined with the fact that these are very compact printers printing at a very fast speed, the case being plastic and there is basically no sound deadening material inside, these printers will produce more sound compared to a slower machine. I think these are expected to be used in high volume offices that have printer/copy rooms, or where noise is not much of an issue and they are isolated away from offices and users. There is really no easy and aesthetic way to quiet these in a small office environment that you've described without enclosing them in an acoustic enclosure (which reduces accessibility and potential cooling problems) or in a separate room.
Ford F10 Parts
May 24, 2012 | Office Equipment & Supplies
I have a Lexmark E360d and every time I print it beeps. How do I turn that off?
Quite mode OFF is the default factory settings. To reduce noise produced by the printer, quite mode need to be turned ON. This will reduce the amount of noise but this will set the printer run at half speed.
To do this click on Menu Button > General settings> Quite Mode> ON and then press the check button to submit.
For further assistance, please contact Lexmark Technical Support.
Jul 11, 2011 | Lexmark E360d Laser Printer
My samsung clp 310 printer jams when printing cardstock.
I have the same issue. Printing envelopes produce unexpected noise (on real envelope or standard paper) during the proses. Printing the same document as an A4 document ran smoothly and quietly. Any solution :(
Aug 05, 2010 | Computers & Internet
MY HP laserject P3005 printer makes alot of grinding noise but prints fine,is there anything i can do
Hi lexdalex,
Test the cartridge, if you have an old cartridge then insert the cartridge and try running a test print. If the grinding noise is gone, then it is the cleaning blade on the cartridge.
Al
Aug 02, 2010 | Office Equipment & Supplies
I am running a csss system on a canon mp 190 printer.My problem is that I am getting alot of lines in my prints,this has only started recently.I have cleaned and deep cleaned many many times and I have...
Assuming you have aligned the head to produce the minimum noticeable amount of white streaks and gioven all the cleaning, deep cleaning and alignment you have done there are two conclusions.
1. If the printer has been performing OK and using the same ink supply in the CISS and the actual printed results are OK then simply continue withthe setup as is.
2. If the setup as is is producing unacceptable results then you will have to consider changing the print head for a new one.
Oct 23, 2009 | Canon Office Equipment & Supplies
It seals every envelope I print
The humidity is too high in your location, or the envelopes are using a very soft glue. The heat produced by the fuser is bonding the glue.
Try different envelopes, you might have a brand that is more heat activated and less moisture activated. Try placing a de-humidifier where your printer is, will help alot.
Jun 23, 2009 | HP Color LaserJet 2600n Printer
HP Deskjet printing noisly with a cracking sound
9 times out of 10 what you have is 2 cogs that are offset - ie they are grinding their teeth and you can fix it but is a deskjet printer really worth all the hassle...
Jun 20, 2008 | HP DeskJet 810c InkJet Printer
Hp 1320
I want the software of laser jet 1320 printer
May 19, 2008 | HP LaserJet 1320 Printer
High pitch noise
Very bad. HP is crowd of fools, getting started to **** a brain to us.It was very good printer producer,now I dislike it more and more.
Dec 19, 2007 | HP LaserJet P3005 Printer
HP Color LaserJet 2600n Printer Logo
15 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
