Question about Radio Communications
RSH1DTSW does not work
The fridge has been in storage for just over a year the compresser runs but does not cool fridge or freezer
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
This is not a two way radio, it's a fridge!!!
Peter
Posted on Mar 18, 2013
I just moved the fridge to a new house and now the fridge and freezer won't get cold. It had been sitting in storage for over about a year, but worked perfectly before that.
Its possible that during storage a few things may have happened. There is a small fan under the back that keeps the compressor cool while running. Its possible that during moving something shifted or bent the fan area and its not running. Could also be a small critter built a nest in that same area stopping the fan from running. Without that fan--- the compressor will run a very short time and then cycle itself off on the heat safety when it gets too hot. It will keep short cycling off the heat overload until the fan runs again. It will not run long enough to get to proper temp. Just guessing but check this first.
Jun 18, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
Fridge not cooling
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 10, 2012 | Refrigerators
My Frigidaire Model # FRS26LF7DS7 is not cooling!
Could be a few problems. What I would do is check to see if the compresser is running by pulling out the fridge and pulling the back panel off and putting your hand on the compresser. If it Is vibrating then it is running. If it is not vibrating but very hot then the compresser is dead and needs to be replaced. If the compresser Is cool and not running I would say the thermostat inside the fridge is dead(bad contacts in the control). If the compresser is running but no cooling, the cap tube which is the metering device for the refrigerant into the freezer evaperator could be plugged off. Or if none of the lines off of the compresser are hot or cold then the valves inside the compresser are gone and compresser needs to be replaced hope this helps
Sep 06, 2012 | Frigidaire FFHT1817L Top Freezer...
THE FREEZER WORKS BUT THE FRIDGE PART DOESN'T. IT'S THE SMALLEST SIZE 2 DOOR FROST FREE MAGIC CHEF FRIDGE. ABOUT A YEAR AND A HALF OLD. WHAT SHOULD I DO?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 16, 2010 | Magic Chef Refrigerators
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
Kenmore fridge not cooling
check for your freezer fan running properly
then check to make sure you have air flow into the freezer this model has a habit of freezing ice in the air channels
Oct 07, 2009 | Refrigerators
Refrigerator not cooling
My fridge and freezer just stopped cooling all of a sudden. I hear the compressor running and every couple of min there is a clicking noise. Is there a reset switch or something that I can do to start it working again? The lights are working but the freezer and fridge are room temp.
Jun 22, 2008 | Refrigerators
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
