Question about Kenmore 15129 Built-in Dishwasher
Leaking kenmore dishwasher
Does not leak during any cycle (i layed on the floor and watched the whole cycle run 1. hour-- no leak) next day the towel that i layed under the dishwasher was soaked.
Sounds like it the inlet water hose need tightening.
Posted on Jan 12, 2009
We have a hoptpoint ultima super silent fdw80 dishwasher, displaying the code AL01, we have already tried the the 2 solutions listed & the fault still shows, any ideas?
You have a leak around the pump area and need to locate and repair this to use this unit. This fault code is to protect you home. This mean your unit is leaking during use and water is collecting in the base pan. You may need to run the unit were you can see the leak to repair. If possible you may also check you drain hose, it that leak it can also drain back into the base pan.
Good Luck
Aug 28, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Some water is leaking under the dishwasher and on the kitchen floor during the end of the wash cycle.
Does it leak during pump-out only?
If so , must be drain hose .To see everything,remove kick plate to isolate leak. Check hose connections. Fill and drain and observe.Or run a whole cycle with kick plate off to find leak.
Good luck
Aug 15, 2011 | Kenmore 24 in. 15689 Built-in Dishwasher
I have an Ultra Wash II, 665.1675590 dishwasher that works like a charm, my only problem is that when I put a rinse agent in the rinse dispenser, the minute I close the door it all runs out. I can fill it...
  • 1 .Cut back on the amount of detergent used during the wash cycle. Sometimes this alone will solve your problem.
  • 2 Make sure the appliance is level by adjusting the front feet up or down.
  • 3. Take off the lower front panel and check the hoses for leaks.
  • please comment on this post stating how it help you with your dishwasher
  • Dec 21, 2010 | Kenmore Dishwashers
    Intermittent leaking during wash cycle
    is the dishwasher leaning foward,are you useing to much soap?start the dw with out anything in it let it run a few minutes open the door and see if there are suds in it if so way to much detergant
    May 31, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
    Kitchenaid dishwasher is leaking
    depends. take the lower panels off the dishwasher below the door right at the floor. Once this is done you will need a flashlight. If possible lay on the floor with the flashlight and activate the dishwasher. Look for the leak at that point. If it starts leaking in the drain cycle then the impeller is leaking and will need to be replaced. These can be a little pricey so take the model and serial numbers and call an appliance parts house for the cost and it is a little bit of a hassel to replace so only you will know if you want to tackle it yourself or buy a new dishwasher. If is leaking during the rinse cycle then the gasket at the base if the washer (where the motor connects to the dishwasher itself) has gone bad and this is a bugger bear to repair. So it's up to you if you want to repair or replace.
    Good luck on repairs Hope I helped you some
    Dr Berry
    Feb 17, 2010 | Dishwashers
    LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
    e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
    The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
    Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
    Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
    Dishwasher leaks during rinse cycle
    it sounds like you need to adjust the door latch so that the top of the door will close tighter. when in the rinse cycle try pushing door at top to see if leak stops. if that doesn't let you know something then you got me. you have changed all that i can think of. Good luck
    May 01, 2009 | Dishwashers
    Dishwasher "F1 and a small wrench symbol" blinks continuously
    The unit has a leak causing floor sensor activated.
    1- Unplug power cord.
    2- Pull oull half way the drawer so an access from the bottom left could be obtained.
    3- Use Paper towel or small towel to dry out the water on the bottom housing.
    4- Wait for 48 hour so the sensor can be dry out.
    Plug in the power cord. The unit will act as normal.
    Your problem is solved.
    However you can't operate since you know you have a leak problem. Let me know how it in progress and you decide to call service to fix it or I can guide you to fix it. Good luck.
    Apr 05, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
    Asko d1876 dishwasher
    The F2 lights blink due to a water senser in the compartment where the motors are located. Remove the bottom kick panel and other covers to access this area of the unit. Unplug the unit before working in this area as wires are abundant. Check the pan to see if water is present. Dry out the pan with a towel and then maybe a hairdryer to clear the F2 alarm. The real questions is what caused the water to be there. Start a cycle and watch to see if there are any leaks on the inlet water line. If not, let the unit run and see when water enters the pan. If it enters during the washing cycle, a gasket leak is likely. If it enters during the drain cycle, perhaps a drain hose is leaking.
    Feb 05, 2009 | Asko D1876 Dishwasher
    Kenmore ultra wash 665.16761690
    If it is not overfilling, and then leaking, the whirring noise can be a defective water inlet valve, that stays stuck on open, see here : It's overfilling
    If it is not overfilling, the two problems may be unrelated, and the noise can be froma foreign object inside the object trap.
    See here about leaks and noise
    It's noisy
    It leaks
    Oct 08, 2008 | Kenmore 16919 Built-in Dishwasher
    Kenmore 15129 Built-in Dishwasher Logo
    277 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    Fred Sops
    vince
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
