My usb device is formating problem
Windows unable format usb disk
  • phatsss Mar 14, 2009
    I use the same reader and ive got the same problem. Cannot format the card neither on cell phone or PC.
  • 298 Answers
Use HP USB Format tool from Extreme Tech
http://files.extremeoverclocking.com/file.php?f=197 ) and tryreformatting... if that doesn't work, it is hosed and only I can fix itso let me know ;-)
Posted on Jan 17, 2009
When i insert my USB flash drive called sanDisk cruzer 8GB in the laptop,am told that i need to format the disk in drive G before i can use it,when i try to format it, it says that windows was unable
If there is any Media Error not possible to format the drive otherwise use the following method on Windows 7
Open a Administrator command Prompt and type the command one by one
1.list disk
you can find the avilable disk and note your USB Drive Disk Number
2.select disk 1 (change the number)
3.clean
4.create partition primary
5.format fs=ntfs quick
6.assign
if no problem in usb it will format your USB Drive
Apr 03, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
Error windows was unable to complete the format
I experienced the same problem (my USB device ). try these steps:
1. Start, Control Panel,
2. Performance and Maintenance,
3. Administrative Tools,
4. Computer Management,
5. Disk Management,
6. Find the USB drive (usually the last storage device before the optical drive),
7. Click on the USB drive,
8. Right click on it and you will see the options (New Partition or Format)
9. Follow the instruction (I chose FAT32), but please do NOT chose Quick Format.
Feb 26, 2014 | SanDisk Sansa Fuze MP3 Player
Unable to format the 2GB
STEP 1 - Connect your flash drive, MP3 player (in MSC mode), memory card or card reader to the PC
STEP 2 - Open Disk Management
Windows 7 or Vista
Click Start, right-click on Computer and select Manage.
Windows XP
Click Start > My Computer > Manage.
Under Storage, click Disk Management on the left pane.
Windows 7 or Vista
Windows XP
STEP 3 - Format the device / MP3 player
1. Right-click on the drive / device you want to format then select Format.
2. Occasionally, a warning may come out concerning active partition, click Yes.
3. You can leave the formatting options such as the Volume label and File system to default.
4. Click OK to format.
Nov 24, 2012 | SanDisk 2GB microSD Memory Card
Hello-:~) i just wanna ask why is that my transcend is unable to format whe i use to click the format windows unable to complete format will appear?? how can i format my USB
You are plugging it in, going to windows, right clicking the drive - format - quick format and its not working?
Try right clicking the drive, going to properties, and run the error checking or disk checking for errors. Windows can attempt to clear the problem.
Jan 25, 2011 | SanDisk 1GB Cruzer Titanium USB Flash...
16 GB USB 2 MEMORY STICK I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem...
I'm a little confused as you mention both Drive E. which suggests Windows and gnome which suggest linux.
WARNING: Formatting the disk will erase any data on it. Do not format the disk if you are trying to get the data off it that was on it yesterday.
It is possible that the partition table has been corrupted.
If you are using windows. You can either try right clicking on the drive (not double clicking) from Windows Explorer (My Computer) and clicking format. Choose the file system type and go. Alternatively, you could work through the disk management administrative tool. Right Click on My Computer -> Manage -> Disk Management. Right click on the volume and format it.
If you are using linux, see if you have a valid partition table using fdisk for the device. Then, after creating the partition, use mkdosfs to format the drive. If you have formatted the drive as a linux partition, such as ext2, ext3, or reiserfs, it is likely that Windows will not see it as a valid drive.
Jun 02, 2009 | Electronics - Others
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I am unable to access my teac FD-05PUW usb floppy disk disk drive it come up in my computer as disk B but when I try to assess the drive it tells me the disk is not formatted but when I attempt to format...
Solution 1.
Try using the Installation CD or Utiltity CD that came with your drive to format it.
If theres a Utility CD then install it on your computer and try formating it from the utility application.
If the windows error messages still persist then try formating it with the windows default options or NTFS option.
Apr 26, 2009 | Teac FD-05PUB External Floppy Drive
Windows was unable to complete the format
windows was unable to complete the format 4gb moser beer
Feb 26, 2009 | Electronics - Others
My memory stick quit!
try using startup disk of windows xp,, its very sensitive..be carefull... .. then be sure that your usb is connect to the computer.....del the partition of usb device.... then create partition, last format it... be carefull that you want to format is your usb device not your hard drive.
goodluck..
Mar 19, 2008 | Computers & Internet
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
