Question about Acer Aspire Computers & Internet
Aspire one/serial number tag ruined/no PW for HD security/
By the LU number, at left, is larger no.-- 24937664000705 both no.s under bar code......On windows sticker == windows 7 starter snpcoa...below that,...acer group, then bar code,then...CO.7S201.061 then _product key I have written down.._ is over bar code , then bar code, then...X16-96078 at its end... then below that bar code...O0190-498-342-143 and thats all I have on microsoft windows sticker to try to get this pc going... 1,hd pw or a reset procedure. 2,download a boot disk--cd or usb drive, 3,I need a little help, please.
What is Asset Tagging and Serialization?
Asset tagging helps in distinguishing the equipment by utilizing a unique serial number or bar-code by assigning separate tag to every equipment. Asset Tagging and Serialization Global Field Services
Feb 02, 2017 | Computers & Internet
Remove hdd password
You can change it but not 'remove' it. Simplest is to use '00000' as the default password.
Instructions
1 Shut down your computer.
2 Press the power button on your computer. While it is booting, press F2 repeatedly (do not just hold it down) until you arrive at a system screen showing a series of
options. This screen is called the BIOS Setup.
How to change the password on a Dell computer hard drive
Password Vault
Secure, centralized password vault for enterprises. Try now. manageengine.com/PasswordManagerPro
3 Use the down arrow key on your keyboard to scroll down to "Security" in the left-hand column.
4 Arrow right to display a sub-menu under Security in the left-hand column.
5 Arrow down to "Internal HD PW" in the left-hand column. (That stands for Internal Hard Drive Password.)
6 Delete the old password (if any) and, in the same box, enter a new password of at least four characters in length in the main screen at right.
7 Write the password down and keep it in a safe place.
8 Hit Enter.
9 Hit the Escape button on your keyboard to exit the Internal HD PW menu, then hit Escape again to proceed to the Exit screen of the BIOS Setup.
10 Arrow right to save the changes you made to the password, then hit Enter on your keyboard to exit the BIOS Setup.
11 Restart your computer and use the password you created in the BIOS Setup to gain access to your hard drive.
Apr 17, 2014 | Dell Dimension Computers & Internet
I purchased a pandigital colour 7" ereader, step number 3 is to register with adobe. I tried to register , however it says I need a serial number. The pandigital did not come with a serial number. How...
you need to look very closely at the unit, there should be a tag on it somewhere. also if you still have the original box it came in, the serial number is often placed near or under the bar code tag. if you still can't find the number, you should call the pandigital company or the place where you purchased it for further advice
Mar 22, 2011 | Garden
Where to find the model seriel numbers
Hello there and thank you for choosing fixya
Ok normally the model number will be posted on one of the following
i have the diagram listed below for you ok this is for both gas and electrictbirdfan1_14.jpg
Jan 21, 2011 | Ovens
I'm trying to figure out the password to my Belkin router so that I can use it on my ipad it keeps asking for a password to my network and I never put one in it did it automatically when I set up router...
The routers can come with a pw on them from the factory but unlikely in most cases. To get the pw from a router is easy unless somebody changed the login information. On a pc that is connected to the network enter into the address bar of you browser 192.168.2.1 this will take you the router login page. The login requires no password just click login. Under the wireless section select security the key should be shown here. If the is blanked or stars you can just create a new one at this point.
Dec 30, 2010 | Belkin F5D8236-4 Router
How do i find the model number of my acer aspire?
Under the Laptop you can find a white bar-code sticker on which you can see the model number and serial number of the system
Jun 11, 2010 | Acer Aspire One PC Notebook
Can't find serial number on dell vostro 1000
Look underneath the laptop
it's a sticker with a bar code and it says "SERVICE TAG"
It consists of 7 characters, letters and numbers.
Feb 25, 2010 | Dell Vostro 1000 Mobile AMD Sempron...
Where do i find the serial number on a canon pixma mp190 printer
The serial #, on a tag attached to the rear wall. It starts with 4 letters and ends with 5 numbers. ie: AAAA12345. With power on, lift the scanning unit up and pull the scanning unit support bar down into place. You can then see the serial # tag.
Jan 13, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Can't find the equivalent model numbers for Aspire One ZG5
From ACER FAQs:
The Aspire One systems labeled with the model ZG5 are actually an Aspire One AOA110 or an Aspire One AOA150. Any information will be listed under AOA110 and AOA150, rather than ZG5.
The supportmodel number is located on the bottom of the netbook on a white label above the serial number. Alternatively, the support model number will be located in the BIOS which can be entered by pressing the F2 key when turning the netbook on. Once in the BIOS it will be under the Information tab to the right of Product Name
Aug 22, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
259 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
