Question about Air Tools & Compressors
Which oil can use for gianneschi air compressor CT2\330
I need to change oil for compressor
2 Suggested Answers
  • 98 Answers
SOURCE: what is the amt of oil ingersoll-rand 242-5n air compressor need
Fill to the top of fill spout
Posted on Jul 21, 2009
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    How many liters of compredssor oil to fill tha compressor tank
    I don't know which model of air compressor you own, some models require no oil whatsoever. The important thing to remember is that you should never put oil inside the tank. While it probably won't damage the compressor and may, in fact, be good for air tools, oil does not belong in the tank. The tank itself should contain clean, dry, air ONLY. Depending on the job you're performing, oil and water in the air tank will ruin your hard work, especially if you are spray painting. The air compressor motor does require oil (unless, again, it's oilless), just fill it through the oil filler hole until it barely starts to leak out. You can change the oil every year if you use your air compressor professionally. Most people who use their compressor only occasionally never change their oil or even check the level. My compressor is a 20 year old Campbell Hausfield with the original oil. I don't recommend that, just stating the facts...I do religiously drain the water out of the tank with the drain valve, and I have replaced the drive belt. Once.
    Feb 25, 2015 | Air Tools & Compressors
    What compressor oil do i need for my puma air compressor
    Any name brand compressor oil will be fine, just make sure to drain the old first, and then refill
    May 30, 2014 | Puma Air Air Compressors Puma Air PUK5520G...
    What grade of oil do air compessors use
    iso 32 // 30wt. compressor oil, or no additive mineral oil, never use automotive oil in a air compressor
    May 06, 2014 | Eagle C5160v1 - Single Stage - 5hp 60...
    Hello - jusy wondering if the the lubricant in the compressor must be changed and if so how often. Thanks!
    yeah it must be changed just like oil in a car engine. although u dont have combustion in the cylider u still have wear. think of it as a lawn mower. when u check the oil it should be brown. not black. after its been in there too long it needs changed. the way set service intervals is your own preference and judgement. because even the recomended intervals dont need to be kept exactly basicaly its life of equiptment vs cost of matenence. an air compressor does not hold much oil so the cost is cheap i change mine ofter. u cant over change it. but if u dont change often enough u reduce the life of it. u ether go by what the book says for how many hour of run time before changing it or like i said a little more often to increase life of the tool or you go a little less often to reduce the mantenance cost.
    like i said if it my equiptment i change oil often so i know it will last. and just like a car, most air compressors have and air filter. this keeps dust from damaging the piston and cylider. depending on tbhe conditions u run it in you probly want to clean the filter or atleast check it at every oil change.
    Nov 18, 2010 | Ingersoll Rand - Rand Type - 30...
    Gardner denver air compressor is blowing oil, need help
    Is this a rotary screw compressor? If so, is it blowing oil out of the air filter or out of the discharge air lines? If it's blowing oil out of the air filter you have a oil stop valve or minimum pressure check valve bad. If oil is coming out of the discharge air you need to change the seperator.
    Nov 15, 2010 | Air Tools & Compressors
    How many quarts of oil are required when changing oil?
    Nice compressor! The gx160 engine needs a little more than 1/2 quart. (.6 to be exact) Honda recommends changing oil every 6 mo. or 100 hours with 10-30 for cooler climates and 30 for temp ranges of 60 - 100 deg.. The pump needs about 12oz of compressor oil. I buy the oil at Lowes for less than three dollars. If you work in a very hot environment then use their synthetic oil, (about $7) it will take much more heat and you do not have to change it as often. It is not mentioned anywhere but there is a little air muffler on the pilot valve that discharges air when set pressure is reached that should be cleaned / checked. There is a screen that gets clogged causing heat. Good Luck.
    Jul 07, 2010 | Honda Quincy 17 - Gallon Air Compressor...
    Air Tools & Compressors Logo
    52 people viewed this question
    Top Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
