Question about Air Tools & Compressors
Which oil gianneschi air compressor CT2\330 - Air Tools & Compressors
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    How many liters of compredssor oil to fill tha compressor tank
    I don't know which model of air compressor you own, some models require no oil whatsoever. The important thing to remember is that you should never put oil inside the tank. While it probably won't damage the compressor and may, in fact, be good for air tools, oil does not belong in the tank. The tank itself should contain clean, dry, air ONLY. Depending on the job you're performing, oil and water in the air tank will ruin your hard work, especially if you are spray painting. The air compressor motor does require oil (unless, again, it's oilless), just fill it through the oil filler hole until it barely starts to leak out. You can change the oil every year if you use your air compressor professionally. Most people who use their compressor only occasionally never change their oil or even check the level. My compressor is a 20 year old Campbell Hausfield with the original oil. I don't recommend that, just stating the facts...I do religiously drain the water out of the tank with the drain valve, and I have replaced the drive belt. Once.
    Feb 25, 2015 | Air Tools & Compressors
    What compressor oil do i need for my puma air compressor
    Any name brand compressor oil will be fine, just make sure to drain the old first, and then refill
    May 30, 2014 | Puma Air Air Compressors Puma Air PUK5520G...
    Wat kind and how much oil does my campbell hausfeld 8 gallon air compressor take?
    Hi Jeff...
    It takes a special air compressor oil for your compressor.
    Go to the nearest Walmart, Loews, or Home Depot and purchase the oil for your air compressor.
    To find the oil level look on the stick that measures the oil and it will give you a fill level.
    Bud
    Oct 11, 2013 | Air Tools & Compressors
    Can you please tell me what type of oil is used in a toolex air compressor. Cheers Mary
    I use Powermate Synthetic Blend air compressor oil. It is a non-detergent air compressor oil sold at most hardware stores where compressors are sold. Any oil that is specifically designed for air compressors will state so on the bottle.
    Aug 03, 2011 | Garden
    What type of oil does this unit take?
    Air compressor oil. I prefer synthetic, but you can use regular compressor oil also.
    Jun 26, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    What type of oil for ingersoll rand model 2475 air compressor could not find specs at Rand website
    Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
    May 10, 2010 | Ingersoll Rand - Rand Type - 30...
    I have a Sanborn 60 gallon vertical compressor ( Blackhawk 5 hp ). What weight oil goes in the crankcase?
    there is actually air compressor oil available at most hardware stores be sure it is compressor and not air tool oil
    Jul 23, 2009 | Makita MAC5200 Electric Powered Air...
    Air Compressor
    Dewalt recommends synthetic oil in their compressors. The dewlat part # 5130427-00 quart, and 5130702-00 for a 4oz size. Available at www.dewalt.com or their service center. I have been using the Lowes brand of synthetic compressor oil. Kobalt oil sells for about $7 and works great. If you do not use your compressor all day like I do, you can use the standard grade of Kobalt compressor oil that sells for around $3. Synthetic oil is for extreme conditions. Good Luck!
    Apr 01, 2009 | Dewalt 2 Hp 4 GAL Air Compressor
    Makita MAC 5200 3 HP 5.2 Gallon electric compressor
    Use non detergent air compressor oil. It can be found at Lowes, Homedepot, and even Walmart. It is sold in small containers for about $2-3 dollars. A synthetic blend air compressor oil is needed when the unit is used in severe conditions. Synthetic air compressor oil sold at Lowes $6.95 and other stores will take more heat. Second choice is 30w non-detergent motor oil. Engine oils tend to produce carbon on the reed valves in the head if used extensively. I have been using the Lowes Kobalt brand of air compressor oil for some years in my Makita and Rol Air compressors with good results. The part number for Makita brand of oil is 18112-A quart size. It is only available by special order where I live. Good Luck!
    Feb 22, 2009 | Makita MAC5200 Electric Powered Air...
    Air Tools & Compressors Logo
    71 people viewed this question
    Top Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
