How to configure a headset if its faulty - Computers & Internet
    Scholar:
  • 277 Answers
You do not mention no model or make and/or any details, not sure why I need to ask.
Posted on Dec 03, 2012
No sound coming through to headset
need to know more. while headset is plugged in try very gently pulling the jackplug out of the socket, if you get sound with the jackplug positions you may have the wrong six
ze plug or the headset may be faulty. try the headset on other devices that function correctly. Also plug another headset into the socket that the headset is currently is plugged into. If another headset functions then the headset must be faulty. It is a matter of experimentation to find what the problem is but you might need a known working headset to carry out the testing procedure.
Good Luck
May 26, 2015 | AUVIO Stereo Wireless Headphones
I can hear callers through my s11 plantronics headset but after using and trying all configuration no.'s they can't hear me at all
Make sure the Plantronics S11 headset is plugged into your handset jack on your phone, not the headset jack, this will make a difference on most phones. After plugging the S11 into the handset jack on your phone, you will need to pick up your handset receiver and sit it off to the side of the phone to place a call or to receive a call, after you are finished with your call sit the handset receiver back in the cradle on your phone.
Good luck from Headsets Direct!
Nov 07, 2011 | Plantronics S11 Headset
Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
Hi when i am configuring lg hbs-200 head set, asking for passkey but i dont know any pass key for that then how can i configure that headset
most blue tooth manufactures use a 4 digit pass key they are as follows 0000,1234,1111 or 9999 i hope this helps
Feb 19, 2011 | LG HBS-200 Bluetooth Headset
If someone is using a headset with a TS-200 multiline system, will incoming calls be picked up by the phone in headset mode first?
That should be a configurable setting. Speaker, Headset, Speaker then headset or Headset then Speaker.
Jun 25, 2010 | TalkSwitch TS-200 Phone
Instructions for installing HS-820USB headset with
there shouldn't be more to do than just simply connect the usb connector to a free usb port on your computer.
if this does not get the expected result your problem may be with
a. a faulty equipment (did it ever worked, how old is it?, did your purchase it new?)
or
b. (most likely) configuration, what software are you trying to use? what operating system?
post back with more details and I will try to help!
Apr 24, 2010 | Gateway 300 S PC Desktop
Pass key
Pass keys for bluetooth pairings are usually 0000 unless the item is user configurable and the user changes it to improve security. I do not believe that headset is configurable so 0000 should work just fine.
Jun 23, 2009 | Jabra BT125 Headset
No sound coming out of my headset
you need to refer to the manual for the jumper settings - could the audio jack be faulty?
is the onboard sound enabled in bios?
just a few things to check
cheers
Andy
Nov 18, 2008 | Intel Motherboard
Headset
There may be a few things that are wrong:
1. Your headset may be faulty.
2. You may need to configure your router.
First, make your IP address static.
If you do not know how to do this, then there is a guide here.
After that, you will need to go into your Router's Control Panel.
You can do this one of two ways:
1. Go to Start --> Run. Type in "cmd".
Once the command box opens, type in: "ipconfig /all"
Find the "Default Gateway" and paste it into your browser.
You will be prompted for a username and password, which you would have set when you installed the router.
2. Go to http://whatismyip.org and find out what your external IP address is. Copy the address, and paste it into your browser.
Once you have logged into your Router's control panel, look for "Port Forwarding" or "DMZ".
When you get onto the page, add a new record.
Use the static IP address you used earlier, and set the record to "DMZ".
[[DMZ open ALL ports on that IP address, allowing incomming and outgoing traffic to pass in and out of the computer]]
This should allow the headset to work, however if it doesn't, it may be faulty.
Jan 08, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
David Payne
David Payne
