Question about Dryers
BEKO CONDENSOR DRYER DRCS 76S NO HEAT TRIED RESET ON THERMOSTAT HEATER WENT ON FOR 1 REVOLUTION THEN WENT OFF
5 Suggested Answers
  • 1462 Answers
SOURCE: The dryer will heat intermitently.
suspect root of problem is the motor capacitor bearing in mind that motor also drives fan. capacitor usually mounted on the motor. find the value (printed on the capacitor and you shoulod be able to source from a good spares stockist
Posted on Sep 14, 2008
  • 65 Answers
SOURCE: beko drcs 68w the sensor stops the drying process
you have a bad sensor...try just using timed dry
Posted on Jan 17, 2010
SOURCE: my beko condensor dryer is
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
Posted on Sep 22, 2011
SOURCE: my beko condensor dryer not
beko condenser dryer not heating up any solutions
Posted on Nov 03, 2011
Beko drcs 68 w cond dryer 3 yrs old an electrical trip sound followed by a burning wire smell
It could very possibly be that some of the lint has migrated thru the cracks of the lint "tunnels" and settled down around the heating element. Danger Will Robinson! Learn how to remove the front cover/door or back side and inspect for loose lint. It is normally lots more accumulated than you could imagine.
Nov 07, 2014 | Dryers
Beko dryer
i have had this problem and its usually the pc board is faulty
Mar 28, 2014 | Dryers
Beko condensor dryer not emmiting any heat but still 'working'
Stat or heater check power if it is a 220 volt machine may have one side down on power
Dec 03, 2013 | Zanussi TC7102W Electric Dryer
My beko drcs 76b tumble dryer isnt heating up
First turn of the breaker, then back on. Check the wiring from the plug at the receptacle to the back if the dryer. You should find your problem there. Then next is the element. See if the wiring is ok to the element. Next visually check the element for
Mar 10, 2013 | Dryers
Beko DRCS68W not entering reset mode
If there is voltage on the thermostat but not going through even when the temperature is down it is possible that this could be defective. Now check using a multimeter to confirm the continuity on the thermostat and if the reset switch on this - if present - is off, if so press it down.
Now confirm the voltage from the control panel during the heating cycle and if voltage is outputted then it must flow. The connection must be checked on the heating element- trace to confirm.
Jun 27, 2012 | Beko Washing Machines
Beko DRCS 68W tumble dryers drum is not rotating (spinning), heating, drying is working
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Dryers
My beko condensor dryer not heating up
Feb 07, 2011 | Dryers
Beko drcs 68w the sensor stops the drying process before the clothes are dry
Jan 17, 2010 | Dryers
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
Dryers Logo
56 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
