Where to find a boiler manual - Heating & Cooling
  • 4 Answers
Hi John
You can find 8,000 free boiler and gas appliance manuals on www.gotogasdocs.co.uk
Hope this helps (If you can't find the model you want let me know as I have a few offline).
Posted on Nov 27, 2012
  • 2 more comments
  • John Murray Nov 27, 2012
    Thanks for the advice. Got onto the website but couldn,t find a user manual for a Potterton International Heating Kingfisher 2. It's an old boiler that I'll replace early next year, but not able to get the pilot light lit at the moment.
  • Marc Lockley Nov 27, 2012
    If it's the old boiler (not the mf then the instructions to light the pilot are normally on the case door?
    Sorry, shutthe messe down to soon! If you know how to light the pilot light but its just not working then you probably need an engineer as apart from cleaning there are a couple of components that can fail on this model. Lighting instructions are similar if you visit this manualhttp://www.freeboilermanuals.com/pdf/pot...
    thanks Marc.
I've got a Worcester Bosch boiler had a leak In the pipe On the landing so a friend emptied the boiler an I fixed the pipe but I don't know how to refill the boiler
Can you get the manual online? You have the Manufacturer info so you probably have the model number too. I found a manual on Manuals.com for my boiler so they may have yours too which will hopefully have some information on filling boiler although I realize each installation is somewhat different but that's why it's difficult to answer you question. Usually there is a manual pressure valve that regulates the water pressure in the boiler which is usually pretty low...like less than 20 lbs. The manual should tell you the pressure as well. But this pressure valve has a flip handle that comes off the cold water line to the boiler to do just what you want to do...refill it with water. When refilling the boiler (if you find the valve, you may have to purge the air out of the lines which there is a whole other process for. But you shouldn't allow cold water into a hot boiler...it could crack it when the cold water hits the hot cast iron. So make sure the boiler is cool when filling it up.
Now go try to find that manual!
Nov 22, 2015 | Bosch Water Heaters
What does it mean when PO8 and H7 are flashing on worcester boiler dial
Either on the inside of the door or in your manual will have a list of all the codes. You could try turning the unit off, not while its in operation, and turn back on in 20 seconds. But first find the meaning of the codes, or faults. They will be listed. Unless the code is stupid simple, contact a pro. CO and fires kill if you don't know what you're doing
May 12, 2014 | Heating & Cooling
Manual for Vaillant turbo Max combination boiler
No model listed, but this manual covers 8 of the most popular models.
Boiler Instruction Manual
May 04, 2014 | Computers & Internet
Boiler keeps going out
have you checked that you thermostat on wall is set to a reasonably high temp. if not when room eaches temp setting , then the boiler will switch off,. Other than this obvios one , i would suggest you could google your boiler for the manual /instruction.
Parts For Porsche Cayenne
Jun 11, 2012 | Reliance Water Heaters
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Am unable to prime water pump
Water is not being drawn from reservoir into boiler. The valve at the base of the boiler seems to function properly. After repeated attempts, I am unable to prime pump and fill boiler with water.
Dec 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
Manual required for Maxol Homewarm 600 or Maxol Morocco 20 Boiler
If he can't fix your boiler without having the instruction manual then he can't be much of an engineer. i would ring someone else.
Nov 19, 2009 | Thermos Kitchen Appliances - Others
Water not heating up enough, misplaced a manual.
Here is a place where you can get manuals
http://www.cerinicoffee.com/Saeco_User_manuals_free.aspere
I have had this problem before: Could be two things either the boiler or the sensors that measure the temperature of the boiler. Normally the red flashing light that you get on startup will never go away if the boiler doesn't get to temp. If your light goes to constant red, it means that it thinks the boiler is at temp ( but it isnt). That points a bit to the temp sensor.
There are two sensors, one that regulates the temp and one that is an emergency cut off device incase the boiler gets too hot. Both must be working. If you download the manuals, they will show the position of these (if its the more detailed manuals with parts.
Taking these machines apart and putting them back together is a bear of a task, I have done it several times. Might be worth taking it in as you have to pull the whole assembly out of the container to get to the boiler.
Hope that helps.
Dec 24, 2008 | Saeco Vienna SuperAutomatica Coffee...
Heating & Cooling Logo
330 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
