Question about Global Marketing Partners FLOWCHARTS AND MORE for PC
Create aflowchart that will accept three numbers and display from the highest to lowest
    New Friend:
Posted on Jan 04, 2013
What is the highest thread count?
As you know that the thread count is nothing but it is the count of vertically and horizontally thread in one-bed sheets. But if you are asking about the highest thread count then you should know that there are many types of thread count sheet, highest, medium and lowest.
If the number of thread is more than 500 then it is the highest thread count sheet. Generally, 1000 thread count sheets are highest and best one-bed sheets in all of them.
k2-_5bd490bf-2942-4371-8bef-3c50fbc32f04.v4.jpg-06e26d5275efbd189c333ae860a4af74c84be0d5-optim-450x450-f4jiy02lwp40djf0cwjiwogt-1-0.jpg
Mar 20, 2018 | Sewing Machines
Display of remaining pictures remains 9999 no matter what size stick is in the camera
If you have a large Gb card and you have set your camera to the lowest resolution, 9999 is the highest the available frame count will go up to. You may well be able to shot more images than 9999 on low resolution. Try setting the camera to the highest resolution and see if the available no. of shots changes. You should also note that the available no. of shots left is only an approximation.
Jun 29, 2014 | Canon Powershot A2000 IS Digital Camera
Nikon N65 won't take a picture
If you have the lens set to the lowest number, you should be seeing a FEE error on the display. The lens needs to be set to the highest number, typically 16 or 22.
Feb 13, 2013 | Nikon N65 35mm SLR Camera
Construct both an ungrouped and a grouped frequency distribution for the data given below: 139 130 128 134 140 139 136 130 136 128 138 137 134 128 127 136 140 132 141
Sorry to disappoint you but I will just give you directions to do it yourself.
Ungrouped
First sort the data in ascending order (from lowest to highest value)
Create a two-column table
In the first column enter a data value.
In the second column enter the frequency of a data item
Count how many times one particular data value appears in the set (how many repetitions). If it appears only once, its frequency is 1; twice, frequency 2, etc.
For each single (different) data value complete the frequency column.
Grouped
For grouped data representations you create classes: A class is just an interval of values, for example between [125, 130[
For each class interval you create, count how many data values fall within the interval. For the class given as example it will encompass all values between 125 and 129, It I counted correctly its frequency is 4.
Complete the frequency table for the class.
How many classes should you create? Usually this information is given to you. If not, create a moderate number of classes (4,5) It depends on the span of the distribution (highest value- lowest value). The intervals should have equal length. Read your instructions.
Sep 02, 2012 | Office Equipment & Supplies
Quantaray lense wont work on nikon D50
David -
The lowest setting is the highest number; f22 is lower than f4. It's little counter-intuitive, but the lowest setting means the least amount of light - or the smallest aperture opening - not the numerical "f" value of the opening.
Simply twist the aperture ring until the highest value "f" number is selected. Many lenses have a small tab or latch to lock them in this position - if yours does, you can use it to prevent this from happening again. You would use a command dial on most camera bodies to electronically change the aperture opening.
May 16, 2012 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
My NEC MultiSync LCD 1765 monitor boots up to the lowest resolution available. When I attempt to correct the resolution through the Display Options in my Control Panel Settings, I set it at the highest...
Try connecting the NEC to a different computer, to see if it correctly accepts 1280-by-1024.
If so, then there's nothing wrong with the monitor, and the fault lies with either the video-adapter in your computer, or something messed-up with your installed copy of Windows.
Try replacing the video-adapter.
Dec 29, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
I have a Canon Power shot A590IS. Going to Walgreen to have my photos developed, there is a "Resolution Warning" shown on their screen. The warning also states "Acutual size 640 x 480 - Recommended size...
This means you have your camera set on one of the lowest settings for megapixels. Go into the menu and set it for the highest number of megapixels and the highest setting for picture quality.
Aug 10, 2010 | Canon PowerShot A590 IS Digital Camera
Heat settings on enheat slow cookers
Generally, the lowest number is the lowest temperature setting and the highest number is the hottest temperature setting
Jan 02, 2010 | CorningWare SC60 Slow Cooker
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
Jan 13, 2009 | Refrigerators
Global Marketing Partners FLOWCHARTS AND MORE for PC Logo
Top Global Marketing Partners Computers & Internet Experts
PinkLisa
Level 1 Expert
ElvinSloth
ElvinSloth
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Global Marketing Partners Computer and Internet Expert? Answer questions, earn points and help others
