Question about Sony PlayStation® 3 (60 GB) Console
8002A10D Unable to Add friend in XMB - Sony PlayStation® 3 (60 GB) Console
I am unable to add friends to my "friends" list.
Maybe you have invyted so many people within a week
Sep 27, 2011 | Facebook Apps
Tip
PlayStation 3 ERROR CODES
Complete PS3 Error Codes:<br /> <br /> <br /> 0710102 - DNS Error; No DSN server available.<br /> <br /> 8013030 - System Error due to failed update download<br /> <br /> 80010001 - Major Error , Game ability stopped<br /> <br /> 80010006 - An error occurred during the start operation (corrupted folding install)<br /> <br /> 80010007 - An error occurred during the start operation (during disc swap tests)<br /> <br /> 8001000B - it happens when trying to establish wireless connection<br /> <br /> 80010017 - Can't start BlueRay Game<br /> <br /> 8001050B - Will not play demo hard drive games, (when blue-ray disc is inserted) - cause unknown<br /> <br /> 8001050D - An error during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again<br /> <br /> 8001050F - Hardware failure. Cannot update firmware or connect to internet.<br /> <br /> 80010510 - Will not play games installed on the hard drive<br /> <br /> 80010514 - Possibly reading blu-ray disc problem<br /> <br /> 80010516 - An error occurred during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again<br /> <br /> 80023101 - Unknown<br /> <br /> 80028E07 - which pops up when i try to update to 1.93 and says that i have been disconnected from the server<br /> <br /> 80028EA5 - User cannot connect to PS3 network<br /> <br /> 80028EA6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 minutes, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection.<br /> <br /> 80028EA8 - Seems to mean unable to authorize isp account details<br /> <br /> 80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automatic,<br /> <br /> 80028F17 - Ps2 disc Boot Error , An error occurred during the start operation; Ps2 game swapped using the eject function and then play pressed quickly - Backup ps2 game inserted again<br /> <br /> 80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).<br /> <br /> 80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it<br /> <br /> 80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error<br /> <br /> 80029023 - Exchanging Key Information exchange has timed out<br /> <br /> 80029024 - "The attempt to obtain an IP address has timed out".<br /> <br /> 80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card)<br /> <br /> 80029501 - connection<br /> <br /> 80029509 - When the PSN network is down for maintenance.<br /> <br /> 80029513 - This content cannot be accessed on your account (80029513)<br /> <br /> 80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them)<br /> <br /> 80029564 - Downloaded game will not install<br /> <br /> 80029751 - warhawk wont start but eveything else seems ok<br /> <br /> 80029945 - Can't playback burn BD movie<br /> <br /> 80029946 - Attempting to play burnt Dual layer NTSC disc on a PAL ps3 ( workarounds is to transfer files to ps3 via TVersity )<br /> <br /> 80029C68 - Corrupt data usually on external device<br /> <br /> 8002A10B. It shows up when I try to view my friends trophies, profile etc.<br /> <br /> 8002A10D - Unable to Add friend in XMB<br /> <br /> 8002A4A6 - Cannot load game to play online<br /> <br /> 8002A515 - Error Signing in<br /> <br /> 8002A524 - connection<br /> <br /> 8002A548 - Unable to remain logged in - either to game or server<br /> <br /> 8002A705 - Unable to connect to server/host. Check router port configuration.<br /> <br /> 8002AD23 - Unknown<br /> <br /> 8002AD3D - Cannot Log into PSN - Is the PSN down? Try manually configuring your PS3 IP info. Try disabling medai server connection in the PS3.<br /> <br /> 8002B241 - DVI has no audio.<br /> <br /> 8002B71A - Possible NAT Error , Can log onto Game Server but can't join game and can't host game<br /> <br /> 8002F994 - Too many people downloading the update (download it later on)<br /> <br /> 8002F997 - Can not update XMB firmware<br /> <br /> 80030001 - Deleting messages from inbox<br /> <br /> 8003041F - An error occurred during the copy operation (using media server)<br /> <br /> 80030517 - It seems to happen when you copy large media files.<br /> <br /> 8003051E - Game will not save<br /> <br /> 80030920 - An error occurred during the copy operation, the file may be corrupt or there isn't enough memory (Try copying data from original source)<br /> <br /> 80031150 - "Setting information is corrupted.Press the x button to repair and restore default"<br /> <br /> 80031601 - Error Creating Account<br /> <br /> 8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the connection drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only WPA or none<br /> <br /> 8013013D - connection<br /> <br /> 8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security<br /> <br /> 80130203 - PS3 connects to internet but not to network - Typically means that the required ports are not open to connect to store but PS3 can connect to internet.<br /> <br /> 8013030F - Access Point not detected<br /> <br /> 8041040F - Communication with the server failed. A dsn error has occured.<br /> <br /> 80410418 - DNS Error<br /> <br /> 80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.<br /> <br /> 80710016 - Playstation Network is down.<br /> <br /> 80710092 - "An error has occurred. you've been signed out from the ps network" , "Media Server Error: A network error has occurred (80710092)"<br /> <br /> 80710101 - Connection error<br /> <br /> 80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router<br /> <br /> 807101FF - An error occurred during communication with the server. This is a DNS error - This is a DNS error<br /> <br /> 8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back switch and completely remove the power cord. Shut off your modem/router, for approx. 5 minutes, then turn the modem back up first and let it sync. Then turn the router back on (if you're using one) and let it sync. Reconnect your power cable and flip the back switch up again. Then make a new network connection<br /> <br /> 80710541 - The connection to the server timed out.<br /> <br /> 80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ<br /> <br /> 80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured<br /> <br /> 80710B23 - PS3 Network is Down or PS3 Network is too busy to respond<br /> <br /> 80710D23 - Turn the PS3 off for approx. 30 minutes with the power toggle, not standby mode<br /> <br /> 81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
on Feb 06, 2011 | Sony Playstation 3 (PS3) Console
Unable to add friend to fb. No matter who I choose to add, fb won't let me add any new friends
Probably u have invited too many friends. Wait a week or so then try inviting again. Dont forget to RATE MY SOLUTION
Ps3 error 8002A669
You need to disable Media Server Connection in netowrk settings. If that doesnt work try this:
I was just able to make the add friend request. Under the friends tab in the XMB, go to your name, manually sign out, and then sign in again. Once my name popped up, I tried the request again and it worked.
Hope this helps..please rate
Mar 06, 2011 | Video Game Consoles & Games
Sony PS3 ERROR CODE 80710092?
here are some of the ps3 error code that might help you in the future..
80023101 - Unknown
8002AD23 - Unknown
Mar 01, 2011 | Sony PlayStation Portable (PSP) Console
Hello When playing a game i bring up the xmb to quit the game and it freezes flashing between game and xmb screen. When this happens the only solution is to turn it off manually. Please Help
PS3 freezes between game and xmb screen are suffering to many gamers. But trouble shooting is not easy : Most gamers think there are CPU overheat problem but actually not the reason. You need some killer methods to fix and test it. Do you know it's just waste your time and money if you send to somewhere repair - because the same problems will be back after then. The best way is to learn the repair techniques of yourself.
There is a PS3 DIY Repair Guide: The author use text and video to show you how to use your hands to open your console and do some maintenance and fixes, at last you are amazing that why you can do that yourself. The best part is you can help your friends too!
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
During music playback I want to play slide show but when I press the PS button I only get message asking if I want to quit rather then going to the XMB menu. Same thing happened when I tried it with my...
The slide show is like Playstation Store you can only exit it not go to the XMB menu. You can just put on a song and press R1 on your pictures to pass them instead if you want to do that.
Mar 06, 2010 | Sony Playstation 3 (PS3) Console
Hi,when i turn ps3 on the console freezes up with multicoloured lines across the screen,im unable to do anything then and cannot acces xmb screen.ive tryed holding down reset button and tryed the original...
listen just hold down the button, i'm not sure how long like you hear 2 beeps then 3 or something and it will take you to a screen with 6 or so options - choose restore file system, you shouldn't loose data if your lucky, anyway i had a very similar problem and my ps3 sat for a year before i was smart enough to figure this one.
Feb 02, 2010 | Sony PS3 40GB Best Sellers Bundle Console
Need to charge PSP :(
you need to change settings to charge via usb in the psp in the xmb menu
Sep 03, 2009 | Sony PlayStation Portable Silver Console
Can play with friends on call of duty
sure you can, all you need is a broadband connection (wireless or wired) and a Playstation Network Account.
to set up your internet connection, find the network settings on settings menu on XMB, choose 'setup internet connection' or something like this, then follow the guide on screen .
then just login your Playstation Network Account in PSN menu on XMB (if you don't have one, simply register yourself in PSN menu on XMB in the correspondent option).
when logged in you PSN account, simply start up your game and access the online multiplayer option, it will connect you to CoD severs.
then, you must invite your friends (that should be logged on PSN also) to the same game. there should be an option to do this on Online Multiplayer interface.
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
145 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
