Question about Kyocera Copystar CS-5035 Copier
My Kyocera KM-1635 will not allow me type anything after displaying call center C6050
I have switched my copier off, open the toner cover then turn it on ready to solve the problem but still will not allow me type anything, how do i correct this?
  • 161 Answers
Fusing related problem
: Abnormally low fuser unit thermistor temperature
Replace Fusing Thermistor
Check Thermal cutoff
Replace fuser
Posted on Nov 27, 2012
SOURCE: km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Posted on Jan 23, 2009
  • 105 Answers
SOURCE: I am Having Problem with Kyocera KM 1635 with code
you have a problem in the fuser/fixing section. error code should be 4 digits long to correctly identify the problem
Posted on Aug 27, 2009
  • 32 Answers
SOURCE: I have a Kyocera Mita 1635 Copier and it's giving blank copies
it may be the problem of moisture dont worry take brasso(used for shining the mitallic products) and put out photo conducting drum and clean the dum with brasso by using a soft cotton cloth ur problem must be solved
Posted on Sep 11, 2009
FixinFax
  • 3085 Answers
SOURCE: My Kyocera Mita KM-KM 1635 displays error call c6000
Have the FUSER replaced.
Posted on Mar 04, 2010
jaddisaith8
SOURCE: Kyocera Mita 1635 Copier Printing Very Light Copies
how to fix drum kit in keyosera mita 1650
Posted on Aug 11, 2012
Kyocera eroor code c-6000
Works with ERROR C6000, C6300, C6400
Switch off
Open Toner Cover
Switch on, holding "System Menu"
Go to "Secure Setting"
"Enter"
Hold "Start" "#" "Enter"
Scoll down to "Maintenance Mode"
"Enter"
Scoll down to "U163"
Scoll do "Execute"
"Enter"
Close Toner Cover
Leave run for a few seconds
Switch off
Switch on....
May 04, 2014 | Kyocera Mita 2 Pack Km 2020 2035 2050...
Stuck in the C6400 Error and cannot get out of it, nor print anything. My printer is a KYOCERA KM-1820. Any assistance would be appreciated.
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note: Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
Mar 31, 2011 | Kyocera Copystar CS-1820 Black and White...
MY COPIER (KYOCERA 1635) DISPLAS ERROR C6050. HOW
C6050 Abnormally low fuser unit thermistor temperature The fuser temperature remains below 90°C/194°F for 1 s. Poor contact in the thermistor connector terminals. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Broken fuser thermistor wire. Measure the resistance. If it is ∞ ω, replace the fuser thermistor. Fuser thermistor installed incorrectly. Check and reinstall if necessary. Fuser thermostat triggered. Check for continuity. If none, replace the fuser thermostat. Fuser heater M or S installed incorrectly. Check and reinstall if necessary. Broken fuser heater M or S wire. Check for continuity. If none, replace the fuser heater M or S. Code Contents Remarks Causes Check procedures/corrective measures
Apr 09, 2010 | Copystar CS-1620 Copier
Compitable or any other toner for my kyocera KM-1635
try to inquire from Al Shaqsi Trading in Dubai UAE log at their website at www.astuae.com they might have solution from your toner problem
Jul 16, 2009 | Canon imageRUNNER 400S Copier
KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
May 17, 2008 | Kyocera Copystar CS-1820 Black and White...
Kyocera Copystar CS-5035 Copier Logo
109 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
