Question about LG 42LC7D-UB Television
M228WDP-BZ - Pure white screen. Power supply board checked. Voltages through connector to main circuit board OK. Changed main circuit board without any improvement. Need to know the voltges that should be found at the connectors from the power supply board to the screen?
  • 380 Answers
SOURCE: to make a long story short originally bought the
Sounds like the y sus was blown out but what cause it. Were you careful when you were checking voltages? As long as you didn't short 2 components together, your y sus should be fine. Unless the y buffer up and/or down blew them out. Even the panel could blow it.
Basically you need a scope to adjust the ramps and everything. You can adjust VA and VS with a meter. If you don't have access to a scope, then just start changing the ramps etc by eye. It might take a little bit to get but eventually you'll get it.
Posted on Mar 14, 2010
SOURCE: while checking Vscan voltages on my LG du-42px12x picture died.
I have the same problem the pic went out but have sound. where do i go to get the Yboard? do i need a special number off of it or something? I took it to repair shop and he said it would be like 500 dollarss to repair. but i see all kind of yboards on ebay for like 150?? how do I know what one to buy?
Posted on Aug 08, 2010
TV #1
  • 129 Answers
SOURCE: Hi There, I have acquired an LG RT42PX10 Plasma,
Aaron,
If you have a bubbled on you r Y sus board you need to replace the cap if you can find it or you can
replace the the Y sus board. 6871QYH029A SUS Y
Thank you
Posted on Nov 02, 2010
Testimonial: "Very helpful, will be using again soon!!!++++"
taran_2005
  • 10515 Answers
SOURCE: Hi! My name is Le Tran. My LG 42PQ30 has no
This is a common problem on Plasma's. This is an issue with Zsus and Ysus board. You need to inspect and replace both the boards.This is not an issue with power supply or ' caps'.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 21, 2010
  • 586 Answers
SOURCE: LG 42PG20 Plasma blew a
Once the voltage the television is connected to is very high, there is a very high tendency that the board will blow again, and it might not be as soon as you replace the board.
You will still have to replace the board, but you will try to get a board with higher capacitance on the capacitors. That way if exposed to higher voltage it wont get bad.
Also a tip is for you to get a step down transformer for your television or a stabilizer so as for the television not to be exposed to a very high current. That should help reduce the risk of having the board getting burnt again.
The screen only vents out once there is excessive heat in the unit and the fans in it are not working, then the screen can vent out.
Carefully assess all the boards on the television for any bad capacitors, like the ones that are swollen, it is not necessary for them to be bursted or smelly before they are bad, you just have to check for the ones that are already swollen.
Hope this information was helpful in solving the problem.
Goodluck
Elect_Comp
Posted on Jun 28, 2011
I have LG 42LN5300 which is reading 230VDC at led + plug and no back lights. All other voltages going to main board are OK, I changed main board because of flickering on and off screen, so is it MB
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 20, 2017 | LG Televison & Video
No back-light,No picture, but has sounds. How can I fix it?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 03, 2015 | Vizio E500i-B1 50-Inch 1080p Smart LED...
Samsung led tv model UA40D5900 have black screed no video and audio.power gets on powersupply board physically good no blown capacitors voltages semms ok.baclite getting on. where could be the problem
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 03, 2014 | Samsung Televison & Video
I have a 39pfl2608/f7 philips tv. it has pink tinge around anything whit on the screen. its not all pink just on the edges of white imgages
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Check the Va & Vs voltages to the panel, too. These voltages are to be noted well, even after replacing a new power supply board. Details about this can be note at the silk screen on the panle [inside].
Nov 18, 2014 | Televison & Video
My mirai DTL-832E600 t.v. now has a white screen, and picture has gone negative (I think) or at least looks overexposed. It changed to this state suddenly yesterday when viewing.
Sounds like T'Con board fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 17, 2014 | Televison & Video
Hannspree 28 Inch Lcd Tv Model Number HSG1075
Check its Chroma section circuit for fault. Most possible cause is damaged chroma IC.
Aug 09, 2012 | Hannspree Televison & Video
Sharp Lc-26sb24u white screen with sound
You will get a white screen when you unplug the t-con from the main board. Doing so removes power to the LCD panel. Verify that all of your voltages from the power supply are correct. If they are, I'd look at the t-con board. It sounds like there is a problem with the t-con that is pulling down the main board.
May 11, 2012 | Sharp LC Televison & Video
Panasonic tcp42g10; stopped working, screen is blank, but LED on front is flashing repeatedly 12 times. need service manual with schematics and help fixing the problem
Remove the back and check , or replace the bad electrolytic caps on the power supply and that will fix your problem.
Mar 24, 2011 | Televison & Video
My akai tv model lct3785ta will not turn on
Ok.. What is the status of the power LED at the front. Does it blink, change color a few seconds after its turned on? Do you notice any clicking noise from the set?
Please provide this info so that we can continue with the diagnosis.
Sai.
Jan 25, 2010 | Akai LCT3785TA 37 in. LCD HDTV
Nad c350 no power at all
Solution if all fuses checked out OK and +/-40V are present on main PCB DC connector from power supply:
Check for +37V and -37V on small sub-power supply PCB - mounted vertically on the main power supply PCB. (next to ribbon cable connector is a layout with voltages.) If the +/-37V are missing check (replace) C501 (0.1uF) on the small power supply PCB for leakage, but also check (replace) R401 (2R2) and R402 (2R2) on the main power supply PCB. Both resistors are fuse-resistors and will have gone open circuit when C501 has gone leaky.
Aug 21, 2008 | NAD C350 2-Channel Amplifier
LG 42LC7D-UB Television Logo
Computer Repairing
Computer Repairing
