Question about Cooktops
I have a gas odour below the Miele Gas Hob.
I have had the gas fitter return to test for leaks. He has soap and water tested the fittings on the supply line for leaks which proved to be OK. He shut off the supply valve at the gas meter and checked for any usage will the appliances switched off. the meter didn't register any consumption.Is there a possibility that unburnt gas could be accumulating within the appliance housing and then dissipating after the control knobs are shut off? Is there any recorded leakage problems between the control knob and the burners.
    Problem Solver:
  • 15 Answers
Call your gas company again. What you don't want is an explosion! PDQ!!!
Posted on Nov 27, 2012
  • 150 Answers
SOURCE: Burner knob wont turn
appliance repair and yes you can fix it you likely need an infinite switch
Posted on Apr 23, 2008
textonor
  • 130 Answers
SOURCE: Ge Monogram Gas Cooktop - won't boil water - burners seem like they are starved for gas
Bret, lets give this a try. 1st look at the regulator. There is an arrow on it that has to point towards the cooktop. Put is on backwards and very little gas flow. I always advise this first as I have seen people tell me it is correct and when I got out there it was reversed. 2nd was this used as a live demo unit on Propane? If you are on natural gas, this will also happen. The 3rd thing I also check for in something in the gas line on the cooktop side. I had a unit that got some packing in the line and at 5 wc for natural gas, it doesn't take much to restrict. Hope this helps.
Posted on Aug 09, 2008
smartr10U
  • 1305 Answers
SOURCE: gas igniters on all five burners keep sparking (JennAir CCG556B)
Try cleaning around all the ignitors at each burner. Look for build up of cleansing product and/or food. Sometimes all it takes is a good cleaning and removal of a buildup to solve this. Worth trying before replacing a bunch of parts!
K
Posted on Jul 30, 2009
  • 1015 Answers
SOURCE: viking gas cooktop vgsu161-6b sparks continuously.
The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry though no permanent damage has been done. Leave it unplugged from the electrical outlet for a day or two until the liquid dries out. You can manually light the burners with matches or a BBQ lighter in the meantime. If you want to try and speed up the drying process you can use a hair dryer.
Posted on Oct 20, 2009
SOURCE: high-pitched squeal/whistle noise from range
Noise went away by itself. No root cause found. Please remove this posting, thanks.
Posted on Dec 05, 2009
Miele km 440. Why doesn't one hob work?
Hi it could be a blocked gas injector under the gas burner or possibly the control valve for that ring isn't working
Apr 09, 2016 | Miele Cooktops
Flame leaking under lower ring. Common?
no it is a problem with the hob
consider this
as it is a rental property it is the responsibility of the land lord to get a gas fitter in to fix / replace the problem
If you do not ask him to fix it , if there is a problem and the thing explodes, catches fire or gases some one to death, there is every possibility that he will try to blame you for not reporting it
if he refuses to fix it or tries to fix it himself then I would advise that you seek alternative rental accommodation as the problem is for an accredited gas fitter and not a landlord.
Sep 23, 2015 | Smeg 23 in. SE64 Gas Cooktop
Model cs1011G will not stay burning - gas peters out
check for a faulty gas regulator or low gas pressures
best have this done by an accredited gas fitter as they can diagnose the problem properly.
Aug 14, 2015 | Miele Cooktops
Hob igniter not working
Handbooks are available from Miele online. If that doesn't give an answer, you may need an appliance service person. I don't recommend you poke around yourself unless competent with gas and electrics.
Jul 21, 2014 | Miele Cooktops
Miele KM 342 - I have burner - will ignite when knob pushed in but once release knob flame goes out
Hi dear.According to you're explanation,there is flame failure safety device in each hob.Please check the hob,there is one ignition plug & one prob next to each other.Please clean them up with hard brush to get rid of the cleaning chemicals(Like: CIF)residue.It's a sensitive prob becareful when you do this.Please make sure it sees the flame.As long as it feels the heat it'll let hob to run.If that's not work,you may need to change it.Please do this if you know what you're doing,other wise call service department.I hope that helps.Thanks.
Aug 07, 2010 | Miele 36 in. KM342 Gas Cooktop
Miele Gas hob KM326G 2 burners won't stop clicking
Hello Leighvz,
The rings around the burners should be cleaned periodically. Each one has a series of holes to let the gas come out and have to be set back perfectly or else you will continually have this problem. You can clean with regular dish soap an water and a sponge or rag.
Also, If you put a pot or pan on the burner and it is too large it will cut off oxygen to the burner causing your clicking. The clicking only occurs when the oxygen supply is not enough. Hope this helps
Sep 07, 2009 | Miele 35 in. KM326G Gas Cooktop
All 6 top burners have leaking compression flex connector fittings to jet burners. Need serviceman in San Francisco.
Youcan try tightening them up yourself. Need two adjustable wrenches, one to hold the connector to the burner and the other to tighten the compression fitting. After that have a solution of water and soap and spray all around your fittings to see if its still leaking, you will see bubbles, If its still leaking you will have to turn yourgas supply valve off and disconnect flex gas lines replace with new ones. After replacing do the same thing spray with the solution to see if they leak.If you dontfeel comfortable doing this dont.
Aug 25, 2009 | Wolf Range 18 in. SPR-100 Gas Cooktop
Slight propane leak in JDC8536
gas is not in the diy domain as it is more deadly than electricity
call in a gas fitter who will have a gas sniffer to determine the exact position of the leak and carry out the repair
by the time you can smell the gas , it is already at the explosive mix with the air
May 27, 2017 | Jenn-Air JGC8536 Gas Cooktop
Gas Hob Flame
Hello
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
PROBLEM WITH HOTPLATES SWICTHING OFF
Sometimes this happens if the pan bottom is not completly flat or is highly polished. Darker, flat pans work best. It sounds as if the safety is cutting off the burner.
May 31, 2008 | Cooktops
Cooktops Logo
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
