Question about Wizard Works Beach Head 2002 for Windows
Can't create primary surface
    Problem Solver:
  • 4 Answers
What are you saying ok let me guess you want to know how to make a surface
Posted on Nov 28, 2012
Error cant create primary surface beach head 2002
How much disk space and the location of the file could cause this error. Depending on where the file is installed you may not have full permissions in windows to read write and modify the file.
Mar 01, 2013 | Wizard Works Beach Head 2002 for Windows
You mean partition ? It could be a defective hdd. Try checking the hdd with HIREN CD. Use another Windows Installation Disk. Post results please
Nov 27, 2012 | HP Compaq nx6110 PC Laptop
There is no picture & video in window
Some VGA card has problem in the Overlay video surface whichTV is used to display video. The new driver has a work around to avoidthis problem by using the Primary surface by default.
To improve the TV performance, Overlay surface can be enabledby right click on the TVremote program running in Windows' System trayand then select the Video Setting.
Dec 05, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
I CAN NOT SIGN IN
https://edit.yahoo.com/forgotroot?done=http%3A%2F%2Fmail.yahoo.com&src=ym&partner=&intl=us
Select one of the following. You will probably have to do this twice because you forgot both username and password.
What's the problem you are experiencing?
Looks like you need some help?
Let us help you find a solution.
I forgot my password
My password doesn't work
I forgot my Yahoo! ID
My account may have been compromised
Answer a few questions and we'll email you your ID
We need to match all the information below with our account records to locate a Yahoo! ID.
Alternate Email AddressThis is the primary alternate email address on your Yahoo! account.
Birthday
Country of Residence
Postal Code
If you don't have an alternate email address for them to email you instructions you may go to gmail.com or myway.com and create one
Oct 09, 2011 | Yahoo Mail
Noise in primary when releasing the clutch sounds like chain slapping
It could be the primary chain slapping. When is the last time it was adjusted? Take the inspection cover off that's in the center of the primary cover. Reach in with your finger and lift the top run of the primary chain. It should be between 3/4" and 7/8" up and down slack in the chain with the engine cold. If it's too loose, loosen the nut on the adjuster just inside the inspection cover opening and raise the shoe to tighten the chain. Retighten the nut once you get it set correctly. If that's not the problem, it could be that the clutch discs are glazed. This is rare on the newer model bikes but I have seen it on a few occasions. The clutch disc will need to be taken out and cleaned and sandpaper used to slightly scuff the surface of the fiber discs. Try adjusting the chain first.
Good Luck & Ride Safe
Steve
Sep 10, 2011 | 2008 Harley Davidson FLHX Street Glide
How do i install my yahoo account to my outlook ?
Visit the Yahoo home page and click the 'Mail' link (see Resources below). This will take you to the Yahoo Mail Web site where you can create your account.
Select the 'Sign Up' link and create an account screen name. Fill in all of the required information, including a password. Choose an alternative if your first choice is already taken
Click on the 'Upgrade' link once you've created a screen name and email account. This will bring you to the email upgrade Web site
Choose 'Yahoo Mail Plus' and click 'Upgrade'. This will bring you to the billing page where you must specify your billing information. Once completed, you'll be able to download your Yahoo Mail into Outlook.
Start Microsoft Outlook.
Select 'Email Accounts' from the Tools menu.
Select 'Add New Email Account.'
Select 'POP3' followed by the 'Next' button.
Enter all of your required user information, including your entire email address.
Specify the server information for the Yahoo Mail account: 'pop.mail.yahoo.com' and 'smtp.mail.yahoo.com.'
Click the 'Advanced' tab and change the POP3 port number to '995.' Change the SMTP number to '465.'
Be sure the 'Log-In Requires Authentication' is unchecked on the main page.
Click 'OK' once all of these parameters have been entered, followed by the 'Finished' button.
Sep 06, 2011 | Yahoo Computers & Internet
Inner primary seal keeps leaking replaced three times all other seals replaced to rode another 1200 kms leaking out inner primary seal still which brand off equitment do you reccommend to use or why is it...
There are several places that could be leaking in this area. First let's talk about the seal that goes in the backside of the inner primary. I always use the James double lipped seal in this area. When you install the seal, put some sealant on the outside circumference of the seal. It must be installed to just below the surface of the primary and it must be straight. Before putting the inner primary back on, lubricate the inner bore of the seal as well as the surface the seal is going to seal against. If the engine starts up and seal has no lubrication on it, the friction will burn the delicate sealing lips and they will be damaged. Your leak could also be the large seal in the face of the transmission behind the front belt pulley. Everything I just said about the inner primary seal applies to this seal as well. The last thing is the pulley could be worn in the spline area in the center of the pulley. You didn't say what year model your bike was but over time, these splines wear and the pulley becomes loose. When this happens, the tension on the "quad seal" behind the spacer on the transmission main shaft fails. Transmission lubricant seeps down between the mainshaft and the spacer and out of the splined area of the front belt pulley. Take the lock plate off the front pulley and check to see if the large nut is tight. If it isn't tight, this could be the problem. The large nut has LEFT HANDED THREADS. Retorque the nut to 150 Foot Pounds. You'll need a special socket and sprocket locking tool to do this job. Take the pulley off and check the splines and replace the quad seal. Make sure you check all the areas whenever you have the inner primary off.
Jul 17, 2011 | Harley Davidson FXDL Dyna Low Rider...
Hello, I have a Turbochef tornado oven, while operation i am getting a Fault code Close door error and it keeps on coming while closing the door with a beep . Can anyone please try to resolve the error...
seems like your primary switch isn't closed correctly or it might bad.
step to trouble shoot
OVEN HAS 5000 VOLTS MOVING INTO IT PLEASE BE CAREFULL
1.press back key to turn off the oven.
2.Open left side pannel.
3.press 'back' and 'enter' key together.Then, enter 9428 and then press enter.
4.You will be directing to an testing screen.At the bottom of thetesting screen there are many alphabets.In which you can see 'P' ,'S' and 'M' .
5.Open the door and watch what happened to alphabet 'P'.I meant to say that when door open alphabet will highlited ,and when closed its seems an regular 'P'
6.open door and close the door .And also keep an eye on the primary switch at the top left corner of the oven where the door latches engaged.If it engaged very nicely and you still see an highlited 'P' in the testing screen then REPLACE THE PRIMARY SWITCH OR IF SWITCH IS OKAY THEN CHEK THE WIRING UPTO MAIN BOARD.
7.If switch doesn't latches properly then adjust switch ,by lossning the screw and aligned it properly.
PLEASE LET ME KNOW IF YOU KNOW HOW TO USE MULTIMETER,SO I CAN EXPLAIN YOU HOW TO CHECK THE SWITCH.
ALSO PLEASE RATE MY ANSWER.
THANKS
May 12, 2011 | TurboChef TORNADO Electric Oven
How to format a pc
You need to create a bootable CD that will delete all of the information on the hard drive permanently. Here's a source for that software: http://www.killdisk.com/downloadfree.htm It's simple: after you create the bootable disk according to the instructions at the link I provided, load it into your primary optical (CD/DVD) drive and then reboot your computer and when your PC goes through it's Boot sequence it will automatically boot from the CD you created and then you just follow the prompts. NOTE: before you run create the boot disk, you should check your boot sequence in BIOS and make sure that the the primary optical drive is first on the list or else the boot CD won't work.
Apr 29, 2011 | Video Game Consoles & Games
Wizard Works Beach Head 2002 for Windows Logo
118 people viewed this question
Top Wizard Works Video Game Consoles & Games Experts
Martin Murray
Andrew Wright
Are you a Wizard Works Video Game Console and Game Expert? Answer questions, earn points and help others
