Question about 1 V1 Radar Detector V 1.85 Software 3.893 Euro Pop2
My Vl is showing a number 8, which i think means has all the numbers lite at once. so i cant see what mode its in or it dosnt show me any direction of bogeys
Why does the lcd display goes bad
Faulty electronics. It may be time to look for another calculator. Try pressing the 8 key enough times to fill the LCD 88888888888. If
Apr 03, 2012 | Sharp EL-512H Calculator
Manual for sharp camcorder model VL-E760U.
I HAVE A PROBLEM WITH THIS CAMCORDER, WHEN I CONNECT TO VIDEO INPUT OF MODERN DVD RECORDER TO RECORD FROM 8 mm T6APE TO DVD DISC THE PICTURE THOSE NOT SHOW PROPERLY IT SHOWS QUARTER OF THE PICTURE . WHEN I CONNECT DIRECT TO TV COLOUR TO PICTURE SHOWS IN ALL SCREEN, CAN YOU SUDJEST SOMETHING FOR THIS PROBLEM?
BEST REGARDS
FRANK PLEVEN.
Feb 12, 2011 | Sharp VL-E760U Camcorder
I wish to have the code number for my V7 to use the skymaster romote
Hi
HOW TO TRACE CODE NUMBERS BY QUICK SEARCH
In case you can't find your brand at code number list, please try with quick search.
1) Set the device that you want to control at POWER ON or VCR at POWER ON with tape loaded
2) Press and hold both, [SET] and aquivalent device key, until LED light shows
up, then release both keys.
3) Press [SET] again, the LED is blinking now. Start to page by pressing [POWER]
and check for any action such as POWER OFF or VCR start to play.
4) If your device has action then check other keys such as [CH +/-] or [VOL
+/-], if negative continue pressing [POWER] to search another code page.
5) While during paging a code was missed out you may press [SET] to change
the Forward / Backward direction of searching.
6) IF any key is not pressed within 30 seconds at search mode then unit will
quit and return to STAND-BY mode.
HOW TO GET THE CODE NUMBER TRACED BY QUICK SEARCH.
Check the code number that has called up to the keypad by pressing [SET]
together with (one after the other) the first three keypad digits:
For example, if is blinking 8 times, 1st digit of code number is [8],
blinking twice means 2nd digit is [2], blinking twice means 3rd digit is
[2], therefore, this code number is [822].
Power source: 2 x UM3 "AAA size" (Batteries located behind cover slide
Regards
Vipin Kakkar
Jan 14, 2011 | Videoseven L17PS 17" LCD Monitor
On our Keys hot tub it is showing F8 along with the EC mode on the panel. We have had it 4 yrs and never seen this , It is also not shutting down all at once after the 2 hrs filtration. Any ideas? ...
The EC mode indicates Economy Heating mode. Which means it check the temp and heats the tub less often. The F8 is usually indicating Filter=8 hours of filtration. Change modes to standard, and change filtration to desired level.
If you do not have the manual for this tub, contact keys for instructions on how to change the filtration options. With out the model number I cannot guide you as to how to do this.
Jan 13, 2011 | Pool & Spa
Dosnt show any words
If your phone refuses to show any word, there seem to be a software problem with the phone.
All you have to do is to get the appropriate software and cables, then flash the phone.
It will work perfectly once again.
Take care
Jun 14, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
My Sharp VL-Z3U show a message that says,:Unit In Safe guard Mode
I was able to reset camcorder and problem cleared up. Thanks.
Nov 20, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
I have done something so the calculator is only displaying whole numbers and will not show anything after the decimal point. Thanks!
Hello
The floating point number display (FIX) is set to zero decimal digits. All your. numbers with decimal parts are rounded.
Look for a key that says [FIX]. Press it and enter a number say3 If I guessed right (Sharp makes numerous calculators) your numbers will show 3 decimal digits.
If there is no such key look for a [MODE] Button. Press the button. If you have a new screen with differents choices look for Format, Float,
On some older calculators there is a table below the display. At the left of the table one finds MODE--> or -->MODE
If it says there Mode DEG:4 that means to have angles in degrees you enter [MODE][4].
I think I exhausted all possibilities. Without you model number, I cannot do more.
Hope it helps.
Sep 04, 2009 | Sharp Office Equipment & Supplies
Cant hit an extention number or option number on voice mail.
once in call there an arrow i beleive it will bring up the keypad, speaker and mute. i think its a arrow or there is an icon once you call jsut try any of them there. i dont have my phone handy with me right now.
Apr 07, 2009 | Dual Electronics CECT P168 Cellular Phone
1 V1 Radar Detector V 1.85 Software 3.893 Euro Pop2 Logo
24 people viewed this question
Top Valentine One Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Valentine One Vehicle Part and Accessory Expert? Answer questions, earn points and help others
