My bosch washing machine at a 40 degree setting won't fill and the light just flashes after a while but when I set it to 30 degrees it fills and runs normally
    Genius:
  • 1,550 Answers
There is some problem in relay switch .
Posted on Jan 10, 2009
    Sergeant:
  • 431 Answers
May be the heat sensor had gone bad. check it
    Sergeant:
    Champion:
  • 247 Answers
Welcome-
so what is the question?
tom
  • Thomas Jan 10, 2009
    what is the model of your washer?
  • 716 Answers
The Hot Or Cold Water Is Off
Hi, recently bought a bush a126q washing machine, worked perfectly fine after 2 washes. However, firstly the programme starter light doesn't stay on throughout the wash, is this a problem? Then the washing...
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board. It's like rebooting your computer. I did this to mine and it cleared up the problem.
Oct 16, 2013 | Washing Machines
My Bosch maxx6 takes very long on wash cycle
Possibly heater fault....if you set unit to, for example, a 40 degree wash, the machine will just keep washing unit it reaches selected temp, then drain and do the rinses. If the heater is open circuit then it will wash and wash and wash until the module times out because it is not getting there and continue to rinses, making the programs excessively long. (You may also find, if it has a display that it sit at 0.01 for a long time at the end of the cycle. Not sure of your model as you have not posted it, but if you go through the test below you can test the heater.
1. Put main dial to off
2. Press and hold start button whilst turning dial one click to left (easycare 30).
3. When display show 8.88 or two of the progress light come on, release the start button
4. Turn dial anticlockwise to 90 cotton (take the long way, NOT thru OFF or you'll have to start over)
5. Press start
The tub will fill a little and if the heater is ok, after a few minutes you will hear it 'kettling', the drum does not turn during this test.
If you have a meter that checks amp draw, if the heater is ok it should read around 9 amps.
Hope this helps
Mar 23, 2013 | Bosch Washing Machines
My bosch washing machine has taken to only allowing washing at 30 degrees. When a higher temperature is requested, no water flows into the machine. Any ideas why?
Clogged/defective/burnt out hot water valve. Disconnect hot water hose and clean the filter in the valve inlet. If this did not help, check if there is power to the hot water valve when it's supposed to fill. If there is power, but no water is coming into the washer - replace the valve.
Apr 10, 2010 | Washing Machines
Bosch WF2001 washes only 30 degrees programmes
We had this problem and it turned out in our case that the hot water inlet filter was blocked. The pump wasn't receiving any hot water into the machine so wouldn't start on anything except a cold (30degree) wash.
We turned off the the hot water tap on the plumbing at the back, disconnected the inlet pipe from the machine, then put the end of the pipe in a bucket and turned the water back on, and saw loads of sediment spurted out.
We ran it until we'd filled the bucket, then turned the tap off, emptied the bucket down the drain, then disconnected the hose from the plumbing and cleaned the hose separately (there's a gauze at the plumbing end of the hose so make sure that's clean).
Then get some pliers and where the hose attatches to the machine there's a filter that you can pull out. Clean this out. In our case this was completely blocked with limescale sediment etc.
Reconnect everything, check it's all tightly fastened etc. then turn the tap on the plumbing back on - turn it on to a hot wash, press start ...and in our case it all worked a dream again.
All this info is in the manual if you've got one, but I thought I'd write it out in case you've got this problem and don't have the manual.
Ahhhhh... cleeean washing again! Hope this works for you. Happy go laundry!
Mar 04, 2010 | Bosch Washing Machines
Sometimes my new machine will not fill with water
make sure that your drain hose is coming up ( 90 degrees ) from the base of the machine. and then drains near or close to the height of the machine. the drain hose at least needs to be at a 45 degree angle to fill properly otherwise it will continuosly drain. hope this helps.
Oct 18, 2009 | Washing Machines
Only works on 30 degrees
If it is a hot and cold fill m/c.then make sure that you have water present at both valves.
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
BOSCH washing Machine WFE 2021
perhaps it is waiting for user to add fabric softener? how it got in this mode?
May 28, 2007 | Bosch WFE 2021 Front Load All-in-One...
Washer only seems to work on 40 degree cycle
check to see if this model has 2 water inlet hoses
if there is 2 only 1 may be used and is connected to hot tap thus only letting in hot water when machine requires water
Jan 03, 2007 | Bosch Axxis WFL 2060 Front Load Washer
DIal is misaligned!
It could be a faulty water heater stat ,or the hot and cold fill pipes are the wrong way round. close Ireland bye bye
Sep 01, 2006 | Tricity Bendix WDR1040W Front Load Washer...
Washing Machines Logo
Top Washing Machines Experts
Richard Roth
Richard Roth
