Question about Exercise & Fitness
E7 error message - Exercise & Fitness
    President:
  • 832 Answers
Err 7 on SportsArt Treadmill M# 6300
Either the main program IC didn't detect the incline VR voltage, or the incline VR voltage exceeds the range setting.
Check the incline VR first.Other possible causes include a bad data cable, drive board IC, and display IC. LED 5 on the drive board lights when the VR exceeds the set range. the first thing I would do is a Calibration
Mechanical calibration sets the incline motor pipe to the 0% position. This happens when the red line on the thin pipe is even with the end of the thick pipe.
Electronic calibration sets the variable resistor (VR) value
to the 0% position. This happens when the voltage across the VR blue and green wires is 1.20 VDC.
Here are the steps for the Mechanical Calibration:
Put the treadmill on its side locate incline pin that is on the H frame and pull out the incline pin 2. Turn the incline motor pipe until the red line on the thin pipe is visible just above the end of the thick pipe. 3. Insert the incline pin. 4. Place treadmill back to its upright position and remove the motor cover and be ready to complete the electronic calibration.
Here are the steps for the Electronic Calibration:
1. Locate Incline Motor on top of the unit their is a black box - that is the VR assembly remove the the 3 screws, but do not detach VR wires.
2. Set multimeter to the DC volt setting. Insert multimeter probes into the VR blue and green wire connectors on the drive board Con 2
3. Turn the VR gear ( a recess white gear) with your thumb until the multimeter shows 1.20 VDC or 0% incline position.
4. Secure the VR, If the VR voltage jumps during incline operation or fails to calibrate properly, replace the VR. But if unit returns to normal operation replace motor
Posted on Sep 13, 2013
    Top Expert:
  • 12,223 Answers
See this steps and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Posted on Nov 27, 2012
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
Jul 29, 2016 | Sharp Ar 5316
E7 message
A/C Blowing circuit breaker and giving a error code E7 - Heartland ...
https://www.heartlandowners.org/.../24381-A-C-Blowing-circuit-breaker...
May 21, 2011 - 10 posts - ‎4 authors
Has anyone have any idea what could cause this issue? It is a Dometic rear AC with HP and will not cool at all. The fan runs but no cooling at ... Dometic Refrigerator - Error code E-3 - On the road, help ...
Jun 6, 2015
Dometic CCC 2 Error Code E7
Aug 9, 2014
Dometic A/C won't turn on with remote or from unit
Aug 30, 2012
More results from www.heartlandowners.org
Dec 02, 2015 | Heating & Cooling
I have E7 and machine won't work????
E7 sounds like an error code. First step is to look it up in your owner's manual.
Aug 26, 2014 | Singer Sewing Machines
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
Mar 23, 2014 | Singer 7258 Sewing Machine
My freezer mod#ULG80BC-5 every morning the disply
I dont provide refrigerator repair service on commercial units, but my first instinct is to say that E7 is an error code message, likely pertaining to a self diagnostic system, but you would also likely need the manual to determine the source of that error.
Sep 27, 2010 | Carrier Commercial Freezer CFG48
My error message is E 7 flashing. After leaving it off over night it worked for a couple of copies. Now I am getting the same error message E7.
press and hold the copy key the second part of the code will show then go to google and type in "sharp ar-m205 E7-xx"
where xx is the last of the code you should get an answer there
Jan 12, 2010 | Sharp AR-M205 Copier
When i start printer E 7 2 error messge is displaying
Probably It show 2 (two) kinds of signal or error message.E2 or E7.
just problem E2 mean no insert recording paper.
Problem solve: when show this error press color key or black key then try to feed paper this printer.
E7: when show E7 some fine cartridge are not install properly right position.
Problem solve: follow mark where install color and black cartridge.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I have a Sharp AR-336 with an error code of E7-11. How do I turn this error message off?
The E7 can not be "turned off". This error usually indicates a bad laser unit or "shading" problems. You could try cleaning all the glass/mirror components including the white shading strip under the glass - it may help.
Probably need a new laser.
Mar 19, 2009 | Sharp Office Equipment & Supplies
Error message E7
Ok thsi is fixable E7 is an Automatic Document feeder or finisher problem. There should be another 2 other numbers flashing after the E7 to tell you where in these options the fault is. Hope this helps
Aug 17, 2007 | Panasonic FP-7735 Black and White Copier
Exercise & Fitness Logo
275 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
