Question about HP Office Equipment & Supplies
I am getting a 57.1 Error on HP laserjet 5100 Printer.
Tried to replace the fan but both the fan doesn't revolves and I get the same error again and again, please help
  • 826 Answers
This fan error check the fan on the right side of the printer.check the fan connector and make sure the fan is not blocked.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Posted on Nov 27, 2012
rey17
  • 66 Answers
SOURCE: Problems with hp laserjet 3330
hi,
i think you need to replace the fan of your printer cause maybe they reach temperature level that's why you experiencing that error...
Posted on Oct 30, 2008
antiochpc
  • 1314 Answers
SOURCE: HP LASERJET 4 PRINTER
57 (or 57.1) SERVICE Message (Main Motor
Failure)
The 57 SERVICE indicates that the DC Controller PCA detected a
general motor failure. The Main Motor drives all moving
components in the printing process. The Main Motor is a 4-phase,
DC servo motor controlled by the DC Controller PCA.
The formatter detects a Main Motor failure when:
• The Main Motor does not come up to speed within one second
of receiving drive voltage.
• The Main Motor deviates from the correct speed for one second
after reaching the correct speed.
Main Motor Functional Checks
• Inspect the gear train for debris that would block the free
operation of the gears.
• Check the gears in the Toner Cartridge for wear and binding.
• Reseat J211 (or J214 on the HP LaserJet 4 Plus/4M Plus) on
the DC Controller PCA, and the main connector on the Main
Motor Assembly. Refer to Figures 7-16 and 7-17 for the DC
Controller PCA connector locations.
• If the problem persists, check that the +24B Voltage is present
on the DC Controller. If the voltage is not present, replace the
DC Controller. If the voltage is present, and the motor does
not rotate, replace the Main Motor Assembly
Posted on Nov 06, 2008
  • 97 Answers
SOURCE: HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
Posted on May 20, 2009
SOURCE: error message replace drum for printer hp laserjet
pristonero, there is no "main" button. what are you talking about?
Posted on Mar 29, 2010
vinay229229
  • 1121 Answers
SOURCE: HP LaserJet 3030 showing "Upgrade Error - Call HP
This is very good & rugged printer better repair it, another five years service it will gives you. Just replace formatter assm P/No: Q2664-60001.
Posted on Sep 23, 2011
How to solve 57.01 error turn off then on in my hp color laserjet cp2025 printer
57.xxx codes almost always indicate a cooling fan problem. One of your cooling fans has probably ceased to function, the fan will most likely need to be replaced.
Sep 05, 2014 | HP Color Laserjet Cp2025 Printer Laserjet...
57.xxx codes almost always indicate a failed cooling fan. The fan will probably need to be replaced to get rid of the error code.
Hp color laser jet 4600 57.40 error
57 indicates a printer fan error has occurred
the .4 points to the formatter fan (F1) is bad.
Connector J1004. Voltage should be 24 VDC between pins 1 & 3.
If it is, then replace the fan, if it isn't, replace the DC Controller PCB.
May 01, 2014 | HP LaserJet 4600 Printer
Laserjet error
57 errors refer to fan failure, 57.7 is the "optional duplexer fan failure"-if that is your code rather than 57.07, you will need to replace the duplexer.
May 27, 2013 | HP LaserJet 4250n Printer
57 fan error turn off then on
You will need to replace the fan. Looking at the front of the printer, the fan should be on the right side. You will need to remove right side of the printer to gain access to the fan. Contact HP for a replacement fan.
Jul 13, 2012 | HP LaserJet P2055d Printer
Error in 2420dn laserjet 57.03
57.03 is a fan error. If power cycling the printer doesn't clear the message, Which ever is the bad fan will have to be replaced.
In other words you are going to have to remove the covers to find the bad fan. Or have a printer tech check it out for you.
Aug 18, 2011 | HP LaserJet 2420dn Printer
I get an HP error message on 2600n printer saying "57 Fan Error". Is it fixable?
57 Fan Error
Turn off then on
The device has experienced a problem with its internal fan.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.The fan is not replaceable. Replace the engine.
Jul 11, 2011 | HP Color LaserJet 2600n Printer
HP Printer 57 Fan Error in 2600n printer
it is non replaceble part error in this error we hv to replace the engine control card / clean the fan it may b resolved ur problem.....................
Jul 10, 2010 | HP LaserJet 9500n Printer
57 service error message. Wht does that mean? We
A fan failure was detected.Printer fan or Duplex fan.
1. Check the fan’s connector and make sure the fan is not blocked.
2. Replace the fan.
On older style printers this is often caused by a bad main motor. (Older style printer being printers with halogen heating elements in the fuser - 4, 4+, 5, 4si, 5si, etc).
Oct 19, 2009 | HP LaserJet 4 plus Printer
hi,
Oct 08, 2008 | HP LaserJet 3330 All-In-One Printer
61 people viewed this question
Seeker5211
Seeker5211
