Westinghouse Tx-42f430s has orange light but dont turn on
  • 29 Answers
SOURCE: westinghouse model tx-47f430s lcd tv wil not turn on
This is known as SLEEP MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These step is done to over-ride the sleep mode.
Roan
Posted on Feb 18, 2010
SOURCE: My HDMI ports won't work on my Westinghouse tx-42f430s TV
FOUND A SOLUTION! (at least in my case) thanks to some creative Google searching...
Apparently the HDMI ports can get into a state where they are unable to negotiate the input signal properly. The way to "clear" the ports and allow the HDMI signal to be detected is to perform a "reset" on the unit.
Just turn the set off using the power button on the right side of the unit. Then, press and HOLD the power button for at least 10 seconds, then release.
The set should turn on and essentially do a "reboot" where it displays the Westinghouse logo. After that your HDMI ports should be functional again.
It worked for me :-) Best of luck..
Posted on Dec 17, 2007
dave1645
  • 834 Answers
SOURCE: got an westinghouse LCD model tx-42f430S. got
have you run setup yet ? if not do so if you still get nothing then you r need a mainboard replacement
Posted on Nov 30, 2009
Testimonial: "Hey Dave, posted a reply please check if you do not mind, Thanks"
SOURCE: westinghouse tx-42f430s won't power on
Hello I have a Westinghouse TV model number TX-42F430S Sometimes it comes on and sometimes it does not. It has an orange light in the center below the W emblem in the center of the TV. when the TV actually comes on that same light is blue Is this the reason that the TV will and will not come on sometimes? is it a power issue mayb a power circut issue???
Posted on Aug 07, 2011
SOURCE: I have a Westinghouse TX-42F430S
we just had this same thing happen in san diego - due to the power outage - and i only get the orange light. did you find a solution yet?\
Posted on Sep 10, 2011
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
Westinghouse tv turns on power light blue works for 3 minutes then turns orange
This is going to be associated with your inverter or your display board. Some cases they are the same board. You will have to take this apart, find the board and then find a replacement.
Apr 13, 2014 | Westinghouse TX-42F430S Television
Westinghouse 42" TV, model TX-42F430S, will not turn on. Orange light in front appears rather than the blue one.
There is a defective electrolytic capacitor (470MF/16V) on the main board that went bad, it will causes intermittent, slow, or not power up, the location number of the cap is not marked on the board, please see the attached photo to locate it.
Mar 12, 2014 | Westinghouse LTV-30W2 Television
POWER LITE IS ORANGE TV WILL NOT TURN ON
Dec 16, 2012 | Westinghouse TX-42F430S Television
I need the comcast code for a Westinghouse TX-42F439S
Westinghouse 10885, 10889, 10890, 11282, 11577. For silver "on-demand" remote.
May 01, 2010 | Westinghouse TX-42F430S Television
Westinghouse tx-42f430s won't power on
More likely it's because of power circuit of your TV set. If you are not trained enough in repairing TV sets, appeal to your local repair center
Jan 25, 2009 | Westinghouse TX-42F430S Television
Won't power up past the W logo.
Try hitting the input button and selecting the correct source. Mine is YBPBR1. That should get you a picture!
Nov 17, 2008 | Westinghouse TX-42F430S Television
Channel number display will not turn off
are you using the TV tuner of the TX-42F30s or are you connecting via setup box
what happen if you change channel
the unit can be reset to factory mode.
Nov 15, 2008 | Westinghouse TX-42F430S Television
TX-42F430S Lock up on power up
I have a similar problem with my TX-42F430S; Mine freezes when changing from Comp 1 to Comp 2. unpluging and waiting was the only fix. Just recently my TV just started turning off(after about 30min of watching) and the led will flash blue. I need to unplug for about 10min before it works again. Getting frustrated and I have contacted Westinghouse to send for repair. only had the TV for 3 months; connect to Roger Explorer HD box.
Nov 02, 2007 | Westinghouse TX-42F430S Television
Televison & Video Logo
829 people viewed this question
Top Televison & Video Experts
Electro Med Services...
