Question about Mitsubishi VS-50111 50" Rear Projection Television
My mitsubishi tv is double and red on the left side of screen fine on the right but red at the bottom
Model VS-50111 is it expensive to fix?
  • 31 Answers
SOURCE: mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Posted on Jun 30, 2008
drumbanger
  • 1199 Answers
SOURCE: bugs in my tv
YES!
remove the top back panal screws (be carefull the mirror is connected to the panal! do not drop!) now wipe off and clean the three glass lenses inside..also wile your in there clean the inside of screen and the back panal mirror You will see a big improvment in picture!!
Please rate this response and help keep this area free!
Posted on Jan 22, 2009
  • 4090 Answers
SOURCE: picture on the mitsubishi HD1080 VS-50111
Nope, But your convergenjce chip is about to die. i would turn it off and leave it off and call a tech to rectify it before it takes out the whole board or all 3 as some capacitors are also overheating. Parts $100+Labour of about 1.5 hrs at this stage! later it will be $600
Please rate my help++++Thanks for using FIXYA
Posted on Nov 30, 2009
  • 10 Answers
SOURCE: mitsubishi vs-50111 Short Protection circuit
I need more detail of what the problem you are seeing if your getting red blinks or anything put in more details
Posted on Jan 18, 2010
SOURCE: Mitsubishi VS-50111 Tv does not stay on.Turn Tv on
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Posted on Jul 01, 2011
I have a model VS 50111 and the colors are out of alignment blue shadow to left yellow to right. Can I fix this problem
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Please do us a favor and rate this solution after reading
Apr 14, 2011 | Mitsubishi VS-50111 50" Rear Projection...
Intermitent black screen with sound, blue screen-no sound, normal
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck...
Sep 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
There is double text in red and green.
u have bad convergence ic , this parts is easy to located there 2 big black peaces the parts # start with stk , u have to do alot of soldering connection , or u can hire a tv tech and paid about $200
Nov 03, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
VS-50111 and horizontal lines appear and shuts off
hello i have the service manual which i'll send for free along as you leave me a fair rating thanks
regards
shaun
May 31, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi vs-50111 Short Protection circuit How do I fix this
Jan 18, 2010 | Mitsubishi VS-50111 50" Rear Projection...
All three colors are off by an inch or two can i fix it or is this a pro's job
The Convergence Circuit has failed and a Professional would be needed to fix it.
Hope this helps,
Skyassoc
Jul 16, 2009 | Mitsubishi VS-50111 50" Rear Projection...
Red is out of alignment
when i go to convergence and align the white cross with the blue its ok ,but when i try the red it doesnt line up and if l get it close enough it get misaligned only with the red ,green and blue fine
Nov 15, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-50111 50" Rear Projection Television Logo
16 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
