Question about Sharp Computers & Internet
New lamp light will not turn on. I tried two new bulbs from two new companies.
Green power lamp light on. green lamp light blinking. then lamp light blinks red. then machine beeps. Then machine turns off leaving both lamp and power light red. This projector was given to me so I do not know what is wrong with it. We opened the case and the capacitor appears to be intact. My engineer friend says that there does not appear to be anything wrong with the machine at first glance.
4 Suggested Answers
jahting
  • 70 Answers
SOURCE: Blinking red light
replce lamp ballast board of your projector...
Posted on Oct 08, 2009
  • 12 Answers
SOURCE: The lamp indicator blinks to red after i replaced
PL RESET THE LAMP BYTAKING HELP IN MANUAL
Posted on Sep 12, 2010
mauricio737
SOURCE: Sharp PG-F262X lamp not lighting?
i have same issue please help
Posted on May 27, 2012
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
Panasonic PT50LC14 Power issue
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
May 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
I turn on the 4805,green led blinks & bulb does not come on?
After a few minuets does the green blinking light turn to a red blinking light?
If so the problem is the lamp did not strike.Either the lamp has failed (most likely) or there is a problem with the power supply (less likely)
Feb 12, 2009 | InFocus ScreenPlay 4805 Multimedia...
Panasonic TY-LA1000 has good lamp, but black screen. light is blinking green, then solid green, then after some time goes red?
Jan 11, 2009 | Panasonic TY-LA1000 Projector Lamp for...
New Bulb Doesn't Light
color wheel or light engine,call for service and save your money.
Aug 04, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Samsung HLM507W Blink Lights
beings the connectors were different on the new bulb the spark gap maybe different also if it is the lamp wont work in that unit
Apr 12, 2008 | Televison & Video
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
Computers & Internet Logo
35 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Mark Dewar
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
