ROYAL JET FLOW GRAVITY FURNACE BLOWER MOTOR - Heating & Cooling
5 Suggested Answers
  • 17 Answers
SOURCE: Gas flows to long before igniting.
try cleaning the crossovers between the burners. Also look closely at the flame and make sure that the burner is firing all the way to the pilot. Sometimes its just a few little holes that vent a little gas to give the flame a path to follow will be stopped up and cause the condition you describe
Posted on Nov 18, 2008
  • 116 Answers
SOURCE: How to install a new blower motor in a Goodman gas
remove the blower unit it slides out on some gas furnaces you may have a control bord in the way if you dont have a goodman motor you will need a belly band to clamp to new motor to provide the mounting arms also after loosening the shaft set screw spray w wd40 turn on side and shake motor should fall out if gas furn 115v motor hope this helps
Posted on Jun 09, 2009
  • 582 Answers
SOURCE: I have a Ruud 90 Plus Model UGRA furnace and blower starts immedi
NO BECAUSE THE BOARD IS TELLING THE FANS TO STARTARE THE CONTACTS FUSED TOGETHER OR STUCK IN THE CLOSED POSISTION CHECK THIS FIRST
Posted on Aug 10, 2009
  • 80 Answers
SOURCE: Carrier 58 Series Furnace Blower Motor Won't Shut Off
Yes. If the high limit is tripped, the furnace will bring on the fan continuously until the limit resets. Often, they will not reset if tripped repeatedly. If the furnace is too large for your application, you probably are not able to move enough air to keep the heat exchanger cool enough.
Posted on Oct 03, 2009
Where can I find a manual for a Royal Jet Jr, model EG2-50 Gravity furnace.
I am looking for that exact wall furnace to replace one that is not working well. In fact I need two of those EG2-50 Junior Jet
Jan 22, 2016 | Heating & Cooling
Pilot light on my heater keeps going out an I have a hard time lighting it. It's a Royal Jet serial no. Is 55FG385412 Model FG355 help if u can
Get the pilot light sensor replaced as the burn down with use and if they are just out of spec the sensor cools and shuts off the gas flow for safety
Dec 05, 2015 | Dayton Gas Furnace Heater
I have a CCA24FCC that keeps shutting the furnace off for lack of air flow. The blower seems o be working well, i have replaced the filter even when it appears to be clean. Is there a sensor that measures...
There are 2 blowers to be concerned with. The main blower simply passes the household air over the heat exchanger to provide warm air for the supply vents. The other blower, which is more important, is the draft inducer blower. This is a smaller blower that starts first to create a negative pressure in the fire box to ensure that carbon monoxide gases will pass up the flue when the gas jets ignite. There is a pressure switch associated with this blower. When the inducer blower starts, it pulls air up thru the flue until the pressure switch activates. Then the gas jets can ignite, warming the heat exchanger. A few seconds later, the main blower will start to warm the air. If the inducer blower or the pressure switch is faulty, the furnace will not fire up.
Feb 24, 2015 | Filter Heating & Cooling
What causes insufficient air flow across evaporator coils
Dirty filters is number one, other blocked ducts.
Bad or slipping blower motor
Slipping belts , if you model has it/ them.
Jul 20, 2014 | Ruud RGTC07ERBGS N/A Achiever 75000 BTU...
Increased Humididity Setting ands now Water
Humidifier receives voltage when the indoor blower motor comes on in the heating mode, and blower motor dose not come on right away.See if water flows when indoor fan is blowing heat, Good luck.
Mar 04, 2010 | Honeywell HE225B Humidifier
Replaced blower motor in my Intertherm furnace, now blows cold
most blowers have a high( black wire) and low(red wire) low works much better in the heat mode
Jan 17, 2009 | Berkel 827E Gravity Feed Deli Meat Slicer
Not enough air flow coming from the vents on the second floor.
If you feel like increasing your blower motor speed you can do this. Go to the air handler take the cover off to expose the blower motor. You will see a circuit board that has the blower motor wires going to it. Using your flash light look at the board and locate the terminals that read Cool Heat Park ... Now the Cool terminal should have black colored wire going to that one. Now locate the Heat terminal if it has red going to it and maybe blue sitting on the park terminal then swap the two around, blue is like med speed on the blower. Where Red is low speed. This will increase the blower about 50 rpms. You can even read your blower motor and get the speeds more detailed. You have a big house your unit is I bet a 4 ton A/C and 125,000 btu furnace. Probably has 1600 rpm motor. This is one solution. You have a up flow model and when you open the furnace cabinet up you will be able to see the specs. on the furnace. Let me know how that goes ken here in Kansas
Jan 13, 2009 | Ruud Central System Air Conditioner
Nov 18, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Coleman furnace problem
Sometimes people replace the blower motors with a higher horse power. Has this motor ever been changed? I believe the original should be a GE motor
Nov 12, 2007 | Heating & Cooling
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
