Question about Navman Tracker 5500i GPS Receiver
5500 Navman no brightness selection
Have followed manual, pressed bottom icon, shows maximum brightness but still unable to see clear picture
Its water ingress causing a short in the high voltage wiring PCB.
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (no antenna socket on i models) .
Where water has arced there will be burning black on the green PCB evident, cut the gold PCB flat wire and remove the section around the burn.
scrape a small amount of green off the gold flat PCB wire so you can solder a new wire to bypass the short. any 2.5mm insulated wire will do to bridge the gap you have just scraped away, there is plenty of room for a 1 inch wire.
Dry the unit and seal with silicone to prevent re occurrence.
Its a 2 hour repair requiring a high DIY soldering standard but off set it against the time it will take to reload you waypoints in a new plotter , its well worth the trouble.
DAKA
Posted on Nov 29, 2013
5 Suggested Answers
SOURCE: I the lost manual
Hi....
I have gone through your problem.Follow this link.
Hope you are searching for the same.
Posted on Apr 02, 2008
SOURCE: Navman 5500 tracker
Navman 5500 does not support C-MAP MAX maps.. only C-MAP NT+ maps.
Posted on May 02, 2008
KevinWhite
  • 1902 Answers
SOURCE: how do i get a navman tracker 5500 manual?
Hello & Welcome to FixYa
Please click here to download the manual for your Navman 5500 GPS. Please get back to me if you have any other questions.
Kevin
Posted on May 10, 2011
SOURCE: navman 5500 gps backlight dim but set to max
Open the unit with a 1.5mm allen key, unscrew the power/data cable sockets with a spanner and GPS antenna inlet with an 8mm socket (NA to i models) .
Where water has arced there will be burning black on the green PCB evident, cut the PCB wire and remove the section around the burn.
DAKA
Posted on Sep 28, 2011
Ipad 4 user manual
Select picture. Open picture. Bottom left, square and up arrow icon. Press icon, press copy. Bottom of screen, press album, and press plus icon at top to add album, and or go into album and paste picture like you copied.
Apr 14, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Brightness of my desktop has been increased what to do??
I've recently come to the realization that my computer monitor screen is not properly calibrated. In different web forums where photos are posted, I'm noticing that I can't make out a lot of the pictures people are talking about - they're too dark. I've also noticed this when printing out CD covers - detail in the shadows that I never saw on the screen. Also, every time I show people digital photos, I have to turn up the brightness (in Photoshop) to anywhere between 25 - 50 %! Needless to say, I need to calibrate my monitor. For a test, I downloaded one of those "black level" graphs whrere the squares go from dark to light and you should be able to see every square clearly - I can only see half before they disappear into all blackness.
I have one of those old "turn of the century" big Dell Monitors that came with my original computer back in 2000. It has two "select" buttons (- +) and two "adjust" buttons (- +) with a row of icons (showing which parameter you're adjusting) with lights underneath on the left. I know that the "sun" icon is brightness and the "half moon" icon is contrast, but I don't know what the rest are.
After selecting "brightness," I hit the adjust "+" button a couple of times and I expected to see a bar graph showing my adjustment, but there was nothing, so I left it alone. I don't want to screw up my monitor so I want to make sure that I'm doing this right. It says "recall" under the select and adjust buttons with "arrows" pointing to two buttons. I assume that you press these to go back to your default settings.
So, how do I go about doing this correctly? __________________
Paul
Sep 22, 2011 | Computers & Internet
How can i change my navman from German to English. Thank
  • Press the "Main Menu" button on the Navman to bring up a list of options. Tap "Preferences," choose "Localize" and "Language." Each option is selected by touching the screen. The different language options show up on the screen in list format. Touch the language you want to use and press the check mark icon. The Navman will now operate in the chosen language.
  • Jul 01, 2011 | Computers & Internet
    Have lost the manual for my 32" hdTV - the picture
    A manual can be downloaded from the Westinghouse legacy site;
    http://legacywd.com/manuals.aspx
    At this site go to the bottom of page to "Archived-2007"
    and click on "Select a product"
    Here you will click on "LTV-32w1"
    On the page you get click on "LTV-32w1" beside the user guide icon.
    The instructions for adjusting brightness is on page 15 for picture parameters off the Main Menu.
    Its the first icon.
    http://legacywd.com/pdf/15_User_Manual.pdf
    Mar 25, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
    Nu-tec model no NUE1958. followed the manual to the dot. Picture, user mode then nothing. How do i adjust the colour and brightness etc. Have been trying for hours
    Had the same experience 'til I discovered that the manual is WRONG!
    Press MENU and then right arrow to select 'Picture Mode' icon at the top of the screen. Then down arrow and so on to make adjustments.
    Evidently you can only change 'User' mode.
    Feb 04, 2011 | Televison & Video
    How do i recover hidden icons?
    To hide a Home screen icon, complete the following steps:
    1. Select an icon on the Home screen of the BlackBerry smartphone.
    2. Press the Menu key.
    3. Click Hide Icon.
    To show a hidden icon on the Home screen, complete the following steps:
    3. Click Show All.
    After the Show All option has been selected, to show a hidden icon, complete the following steps:
    1. Select the transparent icon on the Home screen that you want to make visible.
    3. Cancel the Hide Icon selection.
    Aug 12, 2009 | RIM BlackBerry Pearl 8100
    I have a navman 5500,I can hardly see the screen on a sunny day
    the problem is that the controlling diode that checks LUX value is damaged (small clear window of minute proportion that adjusts screen brightness)
    Jun 29, 2009 | Navman Tracker 5500i GPS Receiver
    I Hate Photography - I So Don't Understand It
    Okay, first to erase one at a time:
    go to playback mode then find the picture you want to erase. Press the trash can button (it's the 3rd button down in the middle) only press it one time while the picture is showing it will bring up a screen on the left, use the button that at the top back of the camera that goes to the next picture and with your thumb look at the left part of the screen and go down and select the little icon that look is under the first one highlighted then just press the button just to the right of the Menu buttom (this is the enter button and it's not clearly marked at all). This will erase/delete the selected picture.
    To format card and erase all pictures: do all the above but when you press the trash button press it again and hold it for a second and the screen will give you more icons at the left of the screen toggle down to the bottom icon and press the enter button and your format screen will come up. It's easy from there.
    Oct 13, 2008 | Toshiba PDR-3300 Digital Camera
    Device stuck on bottom right icon. cannot change.
    Good Day, hcolern2b;
    Sound like your TV's front panel button assembly is bad, replace or disconnect and use remote only.
    Good Luck, big IRISH.............PS disconnect from front by removing speaker grill and small black panel, follow wire harness.real close by.
    Sep 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
    I the lost manual
    Hi....
    Mar 30, 2008 | Navman Tracker 5500i GPS Receiver
    Navman Tracker 5500i GPS Receiver Logo
    222 people viewed this question
    Top Navman GPS Experts
    Neil Gossage
    Level 1 Expert
    Are you a Navman GPS Expert? Answer questions, earn points and help others
