Question about MagLite Mag-Lite& Flashlight
My 6d maglite keeps blowing the bulb
I have put 3 new bulbs in mt maglite 6d cell but it keep blowing the bulb
  • 5,660 Answers
6D Maglite? As in 6 D cell batteries?
1-1/2 Volts (Each battery), times 6 = 9 Volts.
Using the proper bulb?
The original is a Krypton bulb. (No, I didn't make the name up)
http://www.toolup.com/maglite_lmsa601_mag-num-star-6d-relacement-bulb.aspx
http://www.batteryjunction.com/maglite6c.html
Guess what happens if you put a 3 Volt bulb with 9 Volts?
Regards,
joecoolvette
Posted on Nov 27, 2012
  • 3 more comments
  • john wain Nov 27, 2012
    hI joecoolvette
    Yes it a 6 D cell batteries maglite and i have used the correct size bulb 9 volt. but they still blow
  • joecoolvette
    joecoolvette Nov 27, 2012
    Hi John
  • joecoolvette
    Alright...........you guys at Maglite Industries get down here, and explain this. I expect a 32 page dossier on my desk in the morning..............Wait!............What? Oh. I shouldn't have posted John, because I have no idea now, lol! Best I can think of is corrosion has developed inside. Causes the Switch contacts to spread, and distance causes an abnormally large gap. Electricity jumps across the gap, and shorts the bulb out. OK, what do I win? lol!
  • joecoolvette
    Fine........I'm going to take my toys, and go home.
badenhop
  • 44 Answers
SOURCE: I have replaced batteries and bulb in maglite
Sounds like a bad switch, but if you live in the US, you have a limited lifetime warranty on your light.
Contact Maglite at: http://www.maglite.com/feedback.asp
You should also consider installing a LED bulb in your light. If you use it much at all, it will quickly pay for itself in battery life and the light is a lot whiter.
Posted on May 24, 2009
  • 377 Answers
SOURCE: i have a 6 d
Not sounding good. I have had the problem in the past with Mag lights and though they are good, I always seem to have battery corrosion problems. What I have done is to get a non-metalic rod, wooden doweling has worked for me, carve a bit of a blade at the end, sort of like a long screw driver and work it into and between the batter and flashlight case. Not so hard as to deform the flashlight, but to try and break the seal between the corroded (I assume) battery and the case. Spray in some WD40 and work the dowel in and around the battery. Stop on occasion and tap the open end of the flashlight on a heavy rag laid atop a piece of wood to try and jar the battery loose. By repeating this process I have been able to remove corroded batteries, but not necessarily save the flashlight, as some times the on/off switch is corroded as well. Once you get the batteries out you may be able to clean the inside with some abrasive (steel wool?) to clean out the corrosion, but as I said, you may not be able to save the light. Best of luck!
Posted on Aug 30, 2010
agent91
  • 2100 Answers
SOURCE: how to remove bulb from
Twist the front bell off, unscrew the bulb.
Posted on Sep 28, 2010
  • 22 Answers
SOURCE: My recharble 3 cell maglite will not turn on even
You probably have a defective switch, which happens. Maglights are lifetime warranty, so if you go to
http://www.maglite.com/repaircenters.asp and look for a service center, you can mail it in and have it repaired or replaced for free.
Good luck,
Gary
Posted on Dec 03, 2010
  • 257 Answers
SOURCE: Do you carry an LED bulb that I can put into my
Try www.batteryjunction.com
Posted on Mar 07, 2011
Put new batteries in it,turned it on and still wont work,you think it might be the bulb
Before replace the bulb, check for rust or dirt inside the electrical contacts. clean it. if still wont work, replace the bulb.
sammyc47
Feb 22, 2011 | MagLite 4 Cell C Flashlight Black
Keeps blowing new bulbs
Since this is a simple construction flash light (no electronics) make sure you are installing the correct bulb for the voltage of the batteries.
If you use a bulb that is for a 2 cell (3.0 volt) in a flashlight that takes 4 cells (6.0 volt) the bulb will burn out every time.
Oct 15, 2010 | MagLite Camping, Backpacking & Hiking
I have a five D cell Maglite. Seems to always
There are diffferent mag lite bulbs made for different amounts of batteries. Be sure that you have the 5 cell light bulb. Also try to keep your fingers off the glass. if you get any oils on it, wipe it off before turning it on.
Also you can get mag lite specific bulbs...they cost more but they're worth it.
Feb 03, 2010 | MagLite Flashlight Type: Black D Cell 5:...
How to get the bulb out of a 3-D battery maglite
Unscrew the head of the flashlight and take it off. There is a metal ring around the bulb that you have to unscrew to remove the bulb.
Jan 01, 2010 | MagLite 3 Cell D Blue Flashlight S3D116
HOW DO YOU PUT A BULB IN A MINI-MAGLITE?
Unscrew the lense, pull bulb out replace with new one. Normally an extra one is in the end cap in a plastic tube. be sure not to touch new bulb with hands use a tissue.
Oct 09, 2009 | MagLite Camping, Backpacking & Hiking
I can't get the bulb out of my 3 D cell MgaLite?
After unscrewing and removing the reflector/lens housing just push in lightly on the bulb twist counter clockwise and it should pop right out.
Sep 11, 2009 | Camping, Backpacking & Hiking
HEADLIGHT BULB KEEP BURNING OUT ON MY BENZ..2002 C CLASS
Try to put a relay on every bulb to prevent burning, and also check the bulb socket make sure it is not loose.
Jun 09, 2009 | 2001 Mercedes-Benz C-Class
MagLite Mag-Lite& Flashlight Logo
458 people viewed this question
Top MagLite Electrical Supplies Experts
ken skalski
Karl Kittsteiner
lakeareaserv
Level 1 Expert
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
