Question about Canon Office Equipment & Supplies
Error code E6 on MP287
Once it has been started, printer stops and black ink light lighted. The printer stops and get E6 code.
Hi budy........If you facing Error No. E6 , don't worry about that Plz try to press Stop/Reset with Color Button a same time, I hope it will good solution for You......................
Posted on Feb 18, 2013
  • mdarshad0101
    mdarshad0101 Feb 18, 2013
    it was so helpfull for me..................
  • AJITH S NAIR
    AJITH S NAIR Jan 03, 2015
    thank you for the information. My printer error code 06 solved with this helpful tips. Thanks once again ?AJITH, IRIS, CALICUT, KERALA
  • 544 Answers
SOURCE: error code E6 after I inserted a remanufactured
You could try to press the stop/reset button for at least 5 seconds.
If this does not work, remove both ink cartridges, close cover, turn off printer
Unplug printer, wait at least 20 minutes, plug printer back in.
Wait until printer stop cycling, install ink cartridges.
If there is still an error, the cartridge maybe bad.
Posted on Feb 04, 2011
SOURCE: Paper does not feed and E3 error code is flashing
I have one of these printers and have found the problem, crappy enigineering and inferior parts. Looking at the printer from behind, on the left side (where the motor is located) There are two white gears, located at the bottom and behind a larger black gear. One is of medium size and has a spring. The other is smaller and slides into the medium gear. If you can get these two gears back together and in their proper location, then you're set. But, if you're like me and get frustrated easily, DON'T TRY IT! I broke mine :( A repair will cost as much as a cheap printer, so bite the bullet and hit-up your local rite-aid, they have printers that wont bust the bank. Keep your MP 150, after all the scanner/copier will still work without its attached printer.
Posted on Nov 06, 2007
SOURCE: MY Canon Pixma MP 500 Printer won't Print.
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
  4. To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
  5. With the printer powered on, press and hold down the <Stop/Reset> button then press the ON/OFF button.
  6. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
  7. clear any paper jam
  8. May be your product requires repair service.
Posted on Apr 03, 2008
old marine
  • 1992 Answers
SOURCE: CANON MP210 ERROR E15 - INK NEW PRINTER, NEW INK
Go to this link. In the search window in the center of the screen, type "error e 1 5" and click on the Search button. Select the appropriate error message, then select the answer that says "reseat ink cartridge". You may not have locked the cartridges into place by lifting up until they click.
Posted on Oct 24, 2008
  • 630 Answers
SOURCE: wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Posted on Aug 22, 2009
Sir i hav feced a e06 error in mp287 pixma plz solve the problem
Try this solution I found on a German site. Other sites I found did not even mention E06 as possible. Site is linked below, you can use GoogleTranslate to convert to your own language. Good luck!
Error E06 Canon MP287
The characteristics or signs:
  • Currently in turn on the printer does not print the worksheets.
  • ALARM indicator light lit In follow with lights flashing orange ink information.
  • LED indicators display appears on E06
How to Reset Error E06:
  • Press and hold the stop / reset until the standby light green and then release.
  • If the indicator light still flashing again, repeat again by pressing the stop / reset.
  • Finished
Dunia Printer
Jul 06, 2015 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
What can i do for my printer canon pixma mp287 series if get in low-mode.???
I think you are saying that the "Low Ink" warning has stopped you from printing.......The message can be cleared by holding down the "Stop / Resume" button for a count of 10 seconds. If the message is still present it is because both ink cartridges are low. you can repeat the re-setting by doing the same thing twice. This clears the message and will allow the complete use of every drop of ink, however it can also damage the cartridges for refilling if you wish to reuse them.
Nov 19, 2014 | Canon PIXMA MP287 ALL-IN-ONE INKJET...
Error Code E05 Canon MP258
Error Code E05 Canon MP258 may solve by the following steps.
1. Press Stop/Reset button for 5 seconds.2. After five seconds release the button.3. Now your printer will start its process and it is ready to use... thanks
Sep 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error code E6 after I inserted a remanufactured black (pg30) ink cartridge. Continues after removing cartridge and turning machine off
Feb 04, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
My printer cive code E6 and i cant find my book
Canon printers MP 160 AND MAYBE OTHERS
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
May 02, 2010 | Canon PIXMA MP190 All-In-One InkJet...
My Canon PIXMA mp240 is displaying E5 error. I have recently replaced the black ink cartridge but there is no colour cartridge present, as I do not need one. Is there any way to fix this or do I have to...
Hi there
Yes all inks must be in or you will get a error.
it.
procedure:
button pressing
the "service mode"
Try it
it.
All the bst Pineworks
Apr 28, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Getting Error code (E 5) flashing after replacing black reman cartridge. How do you fix it?
it.
procedure:
button pressing
the "service mode"
Try it
it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 24, 2010 | Canon PIXMA MP160 All-In-One Printer
Error 5 code is what
it.
procedure:
button pressing
the "service mode"
Try it
it.
Mar 23, 2010 | Canon PIXMA MP190 All-In-One InkJet...
I have MP240 that has an E6 error message. What does this mean?
Hi there With most ( E ) errors
it.
procedure:
button pressing
the "service mode"
Try it
it.
Feb 27, 2010 | Canon PIXMA MP240 All-In-One InkJet...
I have a pixma mp10 scaner and printer it will not scan the light flashes E and 6. What can I do to fix this? Barbara Nash
Halo Barbara,
Did you mean Pixma MP140/160/150/170/180?. I never hear Canon pixma MP10. Well,it doesn't matter. Did you refill your cartridge?. Error code E6 indicates that ink level is not detected properly by the printer. It usually occurs in refilled cartridge. To fix this problem you need to deactivate ink level detection function by performing following procedure:
For MP150/160/170/180: Press START button (Black or Colour)
For MP140: Hold down STOP/RESET button for about 9 seconds
Please rate me as Fixya if this solution useful for you. Thanks
Source:
Canon Inkjet Printer Forum
Nov 27, 2008 | Canon Office Equipment & Supplies
2,213 people viewed this question
old marine
old marine
