Question about Compaq Presario SR5712F PC Desktop
Replace wires to sockets?
Changed motherboard. need to know if i put sockets in the right place.
  • 119 Answers
This link will take you to the specifications page for your mother board. On that page you will find an explanation and diagram of your board and cables.
Posted on Nov 27, 2012
Changed my low beam bulb and both wires from the low beam harness and the green and white wire from the high beam came out of the connector. I need to know which holes to put them back in
Your wires should not come out of the connector, I think the thing to do would be get a replacement bulb socket from your local part store. Either Autozone, Oreilly's, PepBoys. Whatever you have local should be able to get you either a bulb socket or connector that you can solder into place. Either that, or hit a salvage yard and cut off a good used one and solder it into your harness.
May 25, 2015 | Cars & Trucks
Tip
How to change an Am2 socket to a 939
<p>1. Connect the computer operating system and save up to five minutes waiting for the AM2. Unplug the power cord plugged into the computer and the cables for each of the other components of the computer case. <br /> <p><br /> <p>2. Put the computer case on its side on a flat surface. Unlocking the computer side panel by removing the case screws on the back wall. So remove the lid of the box that the motherboard is visible. <br /> <p><br /> <p>3. In the Annex, the power of large space in the upper left corner of the computer. Unplug the power from the motherboard. Find the positions of the rectangular, green RAM module on the right side of the fan on the motherboard. <br /> <p><br /> <p>4. Slide the plastic lock down on both sides of the RAM module and remove the module from the motherboard. Repeat the process if necessary, if the computer two or more RAM modules. Find the card with the lower left corner of the motherboard. <br /> <p><br /> <p>5. Remove the screw holding the end of the metal rod of the expansion card on the back of the computer. Pull the card and remove them from your computer. Repeat the process if you have two or more expansion cards on the motherboard. <br /> <p><br /> <p>6. Disconnect the cable from the plastic fan on the motherboard. Slide the side guides of the fan and remove fan and heatsink metal AM2. <br /> <p><br /> <p>7. Pull the handle to the right of the issued AM2 processor. Pull the CPU and the motherboard removed. Remove the screws in the corners of the plate and slide the motherboard, right. <br /> <p><br /> <p>8. Lift the motherboard of the computer case. Place the socket 939 motherboard inside the chassis and drive expansion ports and power with the holes on the back of the case. Press the board to stick to the left and the screws on the motherboard in place to replace. <br /> <p><br /> <p>9. Set the Socket 939 processor socket on the motherboard and reconnect all processor pins on the base contact. Slide the locking arm and spread a layer of thermal cooling of the processor with the applicator stick. <br /> <p><br /> <p>10. Connect the power cord and insert the RAM modules and expansion cards for the new motherboard. Put the lid side of the computer and reconnect all cables. <br />
on Jun 22, 2011 | Computers & Internet
Tip
When you have messed up wiring your motherboard..
it is easy...
remember this your motherboard is like a children play house red for red, square for square.. if it is not compatible for the socket it will never be placed well..
you need to connect the following..
first your main power supply to your motherboard
it is very easy to see.. it is a group of maybe 16 wires in a plastic connector..you will connect it to your motherboard..
your processor power is a four wired in plastic connector but it is square in shape..
note: take a good look in each connector they have squares cirlce, etc shapes in each wires so don't force it to connect if it is hard to it means it is not for that socket..
this is the turning point..
your power button, reset button, pw LED, HDD LED,
maybe you know where it is placed,
but note the sequence.. pw button, reset, pw led,hdd led,
if not you can try to short the pins of *********** board so that you will know where the power button will be placed...
your usb and internal speaker has their own pins....
note: take a good look to your motherboard before you connect it, it may cause you some trouble..
take a look at the + ,- signs that is encrypted in the motherboard...
you have to the red wire is fore the posite and the black is negative..
i know it is compose of four wires but they are in one socket right...
your hdd connect it i know you know that how..
that's all..
on Feb 07, 2010 | Computers & Internet
How do i replace spark plug
Without more information, like make and model, I'll have to give you a generic answer:
1. Unplug the plug wire from the plug
2. Place a plug socket over the plug
3. Use a socket driver to un-screw the sparkplug
To reinstall:
1. set the new plug's gap to the manufactures recommendation.
2. Lubricate the threads of the new plug with lithium anti-sieze grease (lightly, an amount the size of a grain of rice is plenty)
3. Hand-thread the new plug in as far as you can hand-turn it.
4. Put the socket wrench on it, tighten no more than 1/2 to 3/4 turn after the gasket contacts the head.
5. Replace the wire on the plug's top.
On some cars, the space to get to the plugs is very limited. I've changed plugs where the plugs were between the exhaust pipes, or behind the alternator.
Jan 17, 2015 | Cars & Trucks
Boot up
did you put the 4pin power in the board and 24 pin in then check the cpu fan in the right place make sure that all plugs are in the right place as well put in video card
Jun 10, 2013 | EliteGroup ECS A740GM-M Motherboard -...
I DISCONECTED ALL MY CABLE SO NOW I CAN'T ABLE TO CONNECT THE WIRE BECAUSE I LOT MY BOARD CHART
it is easy...
that's all..
Feb 07, 2010 | ASUS P5PE-VM Motherboard
How do Iplug the power switch wires in the corect place on the mother board? for the emachine T2824
Hi.
Did you try to open your CPU casing to find the socket in your motherboard witch is totally fix with the power switch wire. The power switch wire are two forms, there is a 20 pins and 24 pins. If your power switch socket is only a 20 pins, you need to put only the 20 pins.
The 24 pins is not totally combined in power switch wire. If your motherboard power socket contains only 20 pins, so remove the 4 pins in your power switch wires. "Good luck!!"
Hope it may helpful for you!
Regards
ICmanServer
Jul 31, 2009 | E-Machines Computers & Internet
D845GVAD2 mother board
Well if you want to keep your processor than you'll want to search for a motherboard with the same Socket type. You'll need to know exactly what kind of processor you have. If you have the box you can find out that way. Assuming you put it together your yourself. Or if you really have no clue. You can remove the heatsink off the CPU. And the socket label will be written right under that. (examples could be.. socket A.. socket 378.. Socket 754).
Once you find that. You can find a motherboard with that type and just ensure that it supports your processor and you'll be good to go.
Feb 12, 2009 | Intel Desktop Board D845GVAD2 Motherboard
Dc jack
This is usually quite a tricky repair on laptops as you'll need to solder the new jack socket to the motherboard in the laptop.
If you cant get the original socket, you could get a chassis mounted socket, mount the socket onto the case where the old jack was and fix it in place with a nut. Then solder 2 pieces of wire from the socket to the motherboard.
Watch the polarity though, else you'll have a fried motherboard!!!
Jun 25, 2008 | Sony VAIO GRV680 Notebook
Kt6v jumper settings
Some wiring can be confusing such as with the board we were using. As you can see the wires mainly connect from left to right but the hard drive LED and the Key Lock wires connect from top to bottom but still show where the (-) connection is. This is where you need to pay close attention to where things actually connect to the motherboard as many boards have similar configurations.
May 23, 2008 | Abit : KV7 Socket A KT600 Motherboard
Compaq Presario SR5712F  PC Desktop Logo
261 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
