Question about HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop
Canon IR400 copier
Anytime I try to make more than one copy at a time, this machine just goes off and comes back on again by itself. It is ok though when i make one copy at a time. Any suggestions will be welcome.
Dear sir, I have ir400 copier. please help me to solve the error no. e051
Posted on Nov 04, 2012
Dear sir, I have ir400 copier. please help me to solve the error no. e051. thanks,
regards
Posted on Feb 09, 2009
Canon IR400 print copy to black print
Most likely it's time to replace the drum unit. Mfr Part #: Canon 1342A003AA, GPR-2, F43-6701-700. Those drum units only last 55,000 copies and then the copy quality starts to degrade.
Nov 24, 2014 | Canon Office Equipment & Supplies
Canon IR400 mechine print to black copy
I have canon ir400 machine... it displayed error codes e604 and e315... what i do? plz help me....
Sir i have recently purchased IR 400 canon photcopier my problem is the machine is giving error 604as soon the machine is started problem . plz solve my problem
Jan 06, 2011 | Canon imageRUNNER 400S Copier
No copy quality in my ir400
to improove copy quality
1: clan the cd unit & use fresh toner
2: clean the primary & transfer charging rollors
Nov 25, 2008 | Canon MF8180C Color Laser MFC Printer
IR400 ERROR CODE E014,E806
E-014 - The fixing motor has a problem. This can be the fuser drive motor, DC Controller, or Image Processor circuit boards. The only time I've had this problem is with one of the fuser bearing going bad and causing excess drag to the motor, giving you the error. See if the green fuser advance knob is hard to turn. If so then check the bearings.
E806 - This is not in the book that I have. Be sure of the number.
E-805 - There is a fault with fuser cooling fans ( located on the delivery door )
Nov 20, 2008 | Canon imageRUNNER 400S Copier
Grey Band/lines across page
your problem could be one of many things first try stoping the copy half way in the machine. to do this open the front door and cheat the door switch with some folded up paper or use a flat screw driver to bypass the switch. make a copy and watch the paper when in goes into the drum and starts to come out like 3 inches pull the screw driver or paper out of the switch. carefully pull the paper out from the machine and see if the image is ok. if the marks are there the problem is with the drum. if the image is clear and there is no marks then open the left door on the copier and inspect the rollers in the heat unit. to do this open the left door the front door has to be open to do this. there is a little green lever on the right side pull this down and look at the 2 roller if you see marks on the top roller or dirt on the lower roller this is your problem. also check the miliage reading on the drum if there is a sticker and check the meter on the machine the drum is rated for 55,000 copies.
Jan 03, 2008 | Canon imageRUNNER 400S Copier
HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop Logo
192 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
