Question about NEC Televison & Video
Sir i want circuit diagram of onida colour tv 29 inches with smd components mounted latest circuit diagram
Sir i want the smd of onida 29 inches colour television.where can i get the smd components. my mobile number 9902938522
budmrtn
  • 11361 Answers
SOURCE: Misplaced Mount/Stand for TV
You can try looking here or contact them: www.shopjimmy.com
http://s807.photobucket.com/home/budm/allalbums
Posted on Jun 13, 2010
  • 4 Answers
SOURCE: My wall studs are wider than my television mount
It is very unusual to have wall studs this far apart - most are 16" on center. Mounting anything that is very heavy on studs so far apart will not be safe. Have you considered a table top stand?
Posted on Dec 28, 2008
SOURCE: DARK PICTURE ON ONIDA COLOUR TV
Check for the loose EHT line (along with the last anode cable),running between the EHT and the PCB of the CRT).It worked for the model 9999.
Posted on Jan 07, 2009
toolkits
  • 1099 Answers
SOURCE: I have an Onida 29
All lasma an lcd ts have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. but if otherwise
Panel is faulty. probably bad connections inside the panel.
Good luck.
Posted on Aug 02, 2010
mislamy15m
SOURCE: Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Posted on Aug 28, 2011
Where can I get Onida Igo CRT TV 29" circuit diagram
Usually there are schematics pasted inside the casing. If the is a sub-compartment(ie. power supply, signal shield required areas) the schematic for the components in the compartment will be pasted to the inside wall & not usually visible until you open it. Hope you find this helpful, good luck.
May 15, 2016 | Televison & Video
Onida tv circuit diagram
Check its speaker first. If found OK, check and replace damaged component/s at its audio output section circuit, and check for any loose solder terminals at the audio output IC.
Gopakumar Gopalan Google
Mar 11, 2014 | Televison & Video
If you wish to get more details, check this link. Hopes it will help you.
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 03, 2013 | Televison & Video
I want onida co29ohtl circuit diagram
  1. onida CO29OHTL CIRCUIT PLZ Rqusat send bay fbt num
Nov 22, 2012 | Televison & Video
I have onida 29 tru slim tv how can i unlock the volume because its lock?
how to unlock the all programes in onida true slim 29 inch tv
May 13, 2012 | Televison & Video
Onida stand by problem
sir my onida tv 21'' ineed un lock
Nov 07, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Televison & Video Logo
75 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
