Question about Home Security
Genie model #2022 does not work
I have a Genie model #2022 2 years old it stopped working, the wall switch and remotes do not work. There is power to the unit all the lights are on. I have unplugged it for twenty minutes and that did not do anything. There is no sound when I press the remote and wall switch although all of the lights are on.
  • daniel katz Nov 27, 2012
    The Lock was never on, both remote and wall switch do not work.
4 Suggested Answers
ltfrc
  • 227 Answers
SOURCE: compatibility with remotes
Have you tried this link?
http://www.garagedooropeners.us/helpgifs/maincode.html
Mike
Posted on Apr 07, 2009
  • 3197 Answers
SOURCE: Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
The LED flashing 3 times is the code for a bad wall control. You can easily verify this by removing the wire from terminal 1 on the rear of the motor unit. If your remote and keypad start working you will know the wall control is bad.
Posted on Aug 03, 2009
  • 68 Answers
SOURCE: genie remotes stopped working
Yes RF units can go bad, especially older ones, the best thing to do would be to get a whole new opener. i say this because if one thing has gone bad that it is only a matter of time before another goes bad
Posted on Oct 25, 2009
I have a genie 2022 and the remotes will not work. I can only open the door with the wall unit. I tried unplugging and plugging in unit and it will work once and then back to the same old same old. Is...
there should be a red or white button on the back of the opener. hit that button then press and hold button on remote. you should hear two clicks.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/brandon_a1f2045feb96cdb4
Oct 25, 2013 | Genie Building Materials
Entry pad quit working on my Genie Excelerator model #H8000D. Changed batteries.Can this be reprogramed or should I purchase a new one?
The relay on the "unit's" circuit board was causing my light to stay on. If I tapped the unit with a stick the vibration would be enough for the contacts in the relay to open allowing the light in the unit to go out. Call The Genie company; the H8000D Genie garage door opener has a lifetime warranty but only if you are the original owner of your home. If you are the original owner you'll need to have a receipt for proof of purchase. If you don't have the receipt then a copy of your HUD-1 form that you received at closing when you passed papers on your home will be accepted as proof of (original ownership of your home). I have had my Genie H8000D for 12+ years now and so far I have replaced the black indoor wall switch, the out door mounted remote control and both internal circuit boards. After removing both old boards I found that the solder on both ends of one "blueish in color" resistor had come loose from the board because he solder failed. I installed the new replacement boards Genie sent me and the unit works as is should. On the old board the resister didn't look bad so I soldered it back onto the board and I'll keep it for a back up.
Aug 25, 2013 | Genie Company Genie Garage Door Opener...
Hi, I have an older garage door opener, Genie
If the opener doesn't work with the button on the wall the opener is defective, either the receiver board or the motor drive circuit or the motor itself.
May 03, 2017 | Transmitter Solutions Building Materials
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears Model 139.53879 (3-Function Remote Control) garage door opener. It's about 12 years old. The remote controls open the door fine but the remotes do not close the door; it has to be closed...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Mar 31, 2011 | Sears Genie Garage Door Gpwk12 Wireless...
How do you replace the battery in the genie garage door remote, its the small one
Never could get mine to work...turns out this model only works with Genie garage door openers manufactured in certain years, and mine wasn't one of those years. Bought a GIT model from a Genie garage door installer, and no more problems!
Oct 28, 2009 | Genie Company IntelliCode GICT390-1BL...
Genie Screwdriver, garage remotes won't work, batteries are fine.
Your receiver has quit working. A call to your local Genie dealer should get you back in business.
Sep 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Genie remotes stopped working
The receiver can go bad and that would stop all remotes from working. The wall control would still work because it does not use the receiver.
Sep 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
My GICT390 stopped working. The red light still goes no when the button is pressed. Where can I get a manual?
Jul 18, 2009 | Genie Company IntelliCode GICT390-1BL...
All remotes stopped working on genie opener, hardwired wall switch works fine.
Your lock on the opener is probably engauged. On the wall control there is a button labeled lock. Press and hold this button for three seconds. Your remotes should work now. If they still do not work, you need to reprogram the remotes. Press the learn button on the back of the motor and then press and hold the remote button. The light will blink once. Repeat this step on the other remotes.
Feb 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
871 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
