Question about Philips VR550 VHS VCR
Phillips VCR 550
I cannot record from Freeview. I have gone to the timer menu and told it to record from a set time, but it starts recording immediately. I have checked the cables. I did the Auto Tuning again, and organised the few channels it found. Why doens't it record properly?
  • Bea Guerra Jun 05, 2007
    so when i left it on the channel i wanted to record and told it specifically the time it should start to record why should it start recording straight away?
    Novelist:
    Champion:
  • 277 Answers
It only the time setting not cable
Posted on Jun 05, 2007
I have a Panasonic TV with inbuilt Freeview TH-42PX70BA. I also have a Hitachi VCR VT-FX980E which I use to record analogue channels. Now that the analogue signal is disappearing I would like to record...
The simple solution is to connect your VCR to a Freeview set top box, which you can pick up for around £10. Simply connect the box via a scart lead. If the Video has two scrat sockets use the other for the box. For recording set the VCR up the same way but instead of selecting channel one or two etc set it as AV2 if that is the place the box is connected. When recording leave the box on the station you want to record and the VCR will record it. Don't forget to allow a few minutes either way for the start and stop times. Also if the VCR has PDC switch it to off.
You should be able to record this way whilst watching another channel on the TV. Some Freeview set top box's have timers on them so if you are out and want to record two shows on different channels you can.
If you have only one scart then a scart switching unit such as this below will solve that problem. Found on Amazon.
Sep 13, 2011 | Televison & Video
I would like to record a show/shows on tv using my lg gc990w 6 head hifi stereo vcr . A work colleage has told me I cant do this because I am trying to record a high definition channel. Is this true or...
you can try setting your tv to record and your vcr to record at same time,,,i have digital tv and set record time,,then on vcr set to record avi at same time,,the only problem is the tv turns itself on when timer starts,, hope this helps and makes sense,,cheers.
Feb 08, 2011 | LG Televison & Video
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
I'm thinking of buying this VCR/DVR combo - Toshiba DVR670 -- but first I want to know if you can program the VCR recording timer using time span information -- not just those codes for programs you find...
Usually, depending on the source, or channel, timer recording can be performed on a VCR; even this model.
The short answer is YES - you can record cable times or set manual scheduled recordings on this VCR. It depends on the channel(s) available in your area, and/or the source (such as cable receivers/set top boxes, etc.) which are intended to be recorded.
Feb 09, 2010 | Toshiba DVR670 Player
I have a Panasonic VCR PV-V4202-A. I want to
You need to go into the menu and look for timer recording,then set in the channel,dateand time the program starts,then press the timer button.It will not start recording until it gets to the time the program starts.
Sep 11, 2009 | Panasonic PV-V4022 VHS VCR
Phillips VCR 550/07
Calmly and relaxed, read the operator's manual to realize the exact proceedure or one-day, multi-time-setting. Upon reading the context will indicate the component's ability and weather the programing is to be direct component button pressing or through the remote control.
Jan 22, 2008 | Philips VR550 VHS VCR
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Record
i have uploaded the user manual for this model, it should be visible within the next 24 hours. the quick version is this:
if you haven't done so yet, set the clock
menu/ use up/down arrows to select "clock set", press right arrow to select, set day, year, etc using up and down arrows, when each is set, the right arrow moves you to the next bit
once clock is set
timer recording
menu
use up and down arrows to scroll to timer recording, and press the right arrow to select
set the program number (1-8)
set frequency (once, daily, weekly)
set the date to record
set start time (i usually go 5 mins prior)
set end time (i usually go 5 mins after)
set channel number
set tape speed
exit by pressing clear/c reset
press t-set to activate the timer
the timer rec light should come on, the timer recording will not be active unless you press the t-set button
hope this helps
trin
Nov 16, 2007 | Sylvania SRD3900 DVD Player/VCR
Vcr won't record on timer
when you set the timer you need to ok the settings of the programme you record then you need to switch the video off on the controll as it will only record in standby mode cus if the video is switched on it will wait for you to tell it to record hope this helps
Oct 19, 2007 | GoVideo DV2150 DVD Player/VCR
Philips VR550 VHS VCR Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
