Question about Dewalt Hilti Te 2 Rotary Hammer Drill
Took apart and removed motor now don't know how to reassemble
Removed the front part of the tool and all the motor pieces fell out now i don't know how to replace the in the correct position
2 Suggested Answers
comax
  • 154 Answers
SOURCE: Transmission fell apart. Looking for blueprint to reassemble.
The transmissions come as an assembled unit and there are no drawings for the internals. If you can find an old drill that is no good, use it as a guide.
Hope this helps
Posted on Apr 14, 2009
I have a Poulan 5020AV. The thing cuts wood like a woodchuck on crack! The problem I'm having is regarding the reassembly of the handle/trigger mechanism. I took it apart in order to remove/clean the carb....
Anytime I get into an unfamiliar saw I always take a number of pictures with the I-phone to help with reassembly. Not too much help is it?
It will only go together correctly ONE way. Do not force any of the parts as if you bend the carb linkage, you will forever have a problem with it. A hint: sometimes the parts have to be inverted and slowly twisted or turned back upright to install.
Jan 17, 2015 | Poulan Garden
How do I reassemble kwikset lock set LIP 5 SMT?
Contact:
Consumer Services
19701 Da Vinci
Lake Forest, CA 92610
1-800-327-LOCK
It's difficult to know without seeing it in person or with good pictures.
Aug 03, 2014 | Kwikset Locks & Locksmithing
How to fix a grabber reacher?
I have a idea to help you .If apart ,you mean the rivets are missing? If this is the issue, find or ask a family member w/ a pop rivet gun.The claws that do the grabbing are stamped,labeled (L)-(R). Reassembling the Grabber w/ the rivet gun wouldn't be too difficult .I could fix your problem, if we were neighbors!
Mar 03, 2013 | Unger NN140 Nifty Nabber Trash Grabber 51"...
Remote for appollo 1996 fell apart need to know how to reassemble
Replace it, they don't provide repair instructions for this type of device.
Nov 05, 2012 | Cars & Trucks
1985 chevy blazer steering wheel removel
Remove the horn button, it should pop off unless you have the deluxe wheel in which case it is held on with 2 Philips screws on the back of the wheel. There is a large nut that has to come off as well as some bits and pieces for the horn. PAY close attention to how these pieces come apart or your horn won't work when you reassemble it. Attach the steering wheel puller and remove the wheel. It helps to give the bolt on the puller a rap with a hammer as you tighten it. Don't bother to try to do this without the puller... it don't work.
With the wheel out of the way, you will see a plate with grooves in the edge of it. This is the locking plate. There is a special tool to remove this but you probably won't be able to rent it. Try to borrow it if you can. If not, it can be removed without the tool. BE WARNED that THIS PLATE CAN HURT YOU as in break teeth or a nose. It is spring loaded with a very heavy spring. To remove it get a piece of boomstick or bar about 16 inch long. Enough so you can use your shoulder to push down on it and hold it while you pry the lock ring off the center shaft. Then ease the plate up until you feel it break contact with the spring. then remove it and the spring. Don't bother trying to put it back together without the spring. You'll just have to take it back apart and put the spring in. Hope this helps.
Oct 02, 2011 | 1985 Chevrolet S-10 Blazer
I took my Dell wireless mouse apart to clean the wheel. The spring fell out. I don't know where it goes back ( I didn't see where it fell from). I put it back together without the spring and now...
i beliece it is very fiddly to put that certain spring back in cus it is hard to see where they go back, my advice is to go to a local PC store and get them to use the right tools to place it back in for you.
Jul 15, 2011 | Computers & Internet
I took apart the handle for my Toro Trimmer Model number 51972 and a spring fell out and I'm not sure where/how it goes back into the handle. I took it apart because the trimer runs but the spool does not...
Hello, Hopefully the exploded parts list can help you out... I've done the reassemble of a trimmer handle once and explaining it can get dicey. The only suggestion that helped me was to have scotch tape handy to act as a third hand when holding small items between two other parts. You don't actually wrap the item, just place it on a small piece of tape - when the item is in position the tape removes easily. Your diagram link is the top one. Good Luck!
http://www.poulan.com/node7925.aspx
Aug 01, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Plastic piece fell down lint slot
You can take it apart however you need to be careful.
You will need a vacuum. socket set and other hand tools.
First unplug the unit, now pull it away from the wall
remove the back panel remembering once you remove any panel you will be exposed to sharp edges.
on your left facing the rear of the dryer is the vent work to the fan motor, you need to remove this, your attachment should be inside this piece. If you have to remove any wires label them well with masking tape, and some ID system you can remember
Use your dustbuster and vaccuum out all the lint and other fall out, make sure the venting is in good working condition replace as needed.
Reassemble as needed.
Jul 15, 2008 | Whirlpool Dryers
Dewalt Hilti Te 2 Rotary Hammer Drill Logo
26 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
