Question about Sony Bravia KDL40HX800 40 in. LCD 3D HDTV
Panel issues with sony kdl-hx800
One faint vertical band on the left of picture and dark portion to the left of picture; sound and rest of picture OK.
  • Kennedy Musumba Nov 27, 2012
    The faint vertical band is not thin but thick, around 2 inches wide and somewhat translucent i.e. picture can be seen faintly in that section
  • Sony Master
  • 933 Answers
That sounds like a defective LCD panel tab connection. Does it go away if you tap the left side of the set? Or does it clear up when the set warms up?
Posted on Nov 27, 2012
4 Suggested Answers
vinnyq
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
  • 8457 Answers
SOURCE: My Sony Bravia KDL-46Z4500 keeps switching off
Power board have problems.Replaced capcitors puff up or burst open,Know how to solders?Or replaced the whole power board buy refurbish power board at Shopjimmy.com,Ebay.com.
Posted on Jan 22, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
Sony bravia KDL-50W800B got only vertical lines when turn on.
You need to take it to a TV repair service, preferably one that specialises in Sony TV's. There is nothing you can do to fix this yourself.
Jun 16, 2016 | Sony Televison & Video
How do I fix the picture?
there is a T con error please replace the T con in this condition
Feb 15, 2016 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My sony bravia KDL-55HX800 SWITCHES OFF ITSELF
It appears to be a normal issue with this model, however there is an update on Sony's site that addresses that issue. If you look at the very bottom of the update details I'm about to post, you will see it
55 Class 54 6 diag BRAVIA HX800 LED Backlit LCD HDTV 3D
Click on Firmware and Read towards bottom of File Description.
The firmware update can be downloaded here
This is how to update by using a USB Storage Device
System Software Update 55 Class 54 6 diag BRAVIA HX800 LED Backlit LCD HDTV 3D
May 23, 2014 | Sony BRAVIA Televison & Video
Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
Aug 18, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony KDL-52WL130 Dark and blurry on left side of screen . Also vertical lines on left side of screen
The TV requires thorough servicing and this might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
Our Sony Bravia tv picture keeps going light dark light dark. What is causing this problem? It is very annoying when it goes dark because you can't see the picture. Please help.
I have Sony KDL-32XBR9 and I have noticed a similar problem. When the picture is showing mostly black, for example during the ending credits of a movie, the TV will further darken the display. Once the picture lightens back up, the TV will adjust the brightness of the display back to normal. I just called Sony customer support and they indicated it was a firmware problem and they will be sending a USB device in the mail to update the firmware. Hope this helps.
Oct 16, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Slow picture and dark reddish tint
These sounds like you have an issue with main board or tcon. Picture slow makes me think this is a communication issue between the tcon and the main board.... This needs a professional diagnostic. The good news is i don't think it is the panel which would make the cost of repair beyond the cost of the tv. If it is in warranty or just out of warranty call sony, sometimes if it is just out of sony's 1 year warranty they will make exceptions. But you need to call them for this exception.
Some solutions are not cut and dried and an on-site diagnostic is best. In your case this is true. I have worked on sony for many years and that symptom (at least the way it is described) is not one I have seen.
Oct 10, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Picture left of center bad on start up
Sounds like a bad display panel to me. Have you tried it with component input, or hdmi??
Aug 26, 2009 | Sony BRAVIA KDL-46W3000 Television
Vertical line on KDL-32s20l1
You'll get this abnormality some times due to the signal if you're watching regular analog picture and you have your TV set on full screen, the TV will stretch the picture and you will see more defects than if you're watching it on normal picture. But if you are seeing the same problem when watching HD picture it needs to be serviced try this link I found: http://www.moniserv.com/doc/lcdtv.html
Aug 27, 2007 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia KDL40HX800 40 in. LCD 3D HDTV Logo
164 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
