Question about Vacuums
I have a Eureka SurfaceMax 300 yellow one and its not sucking up very well at all, and its blowing dirt and dust out the back?? my ol man checked tonight and said the roller isnt spinning, so if i jus
Model# 2976 avc
  • Rome
    Rome Mar 08, 2014
    After reading and going through the comments, suggestions and advises here, nothing still works, here is what have solved my problem: a) cleaned the canister, cleaned the filters (didn't change them, I actually rinse them with water and dried them). After doing this, my vacuum wouldn't still work. So, I took my other vacuum and poked the non-working vacuum hose and allowed it to be sucked by my working vacuum. Effect? voila! problem solved. if you're successful with the advice i gave, send me $5 at ha ha ha ha ha . I just want to share with you my joy after an overnite struggle of thinking about solving this problem. God bless!
  • Vacuums Master
  • 18,394 Answers
Here is the manual , check belt is not broke, and the pipe behind the brushbar is't blocked up,
http://www.eureka.com/FileLibrary/0fc61edfd20b4edba7f1dae64e8b12e4/en_80244_OwnersManual.pdf
Posted on Nov 27, 2012
mindreader
  • 578 Answers
SOURCE: my eureka model 5892 vacuums up the dirt and
It needs a thorough cleaning -
Copy and paste the following into your browser....
http://www.eureka.com/service/manuals/74227.pdf
PAGE 6 provides routing maintainence (cleaning) that should get you going again....
Posted on Nov 27, 2009
Vac Belts
  • 701 Answers
SOURCE: how to change a broken belt on a eureka surfacemax
Here is some info that will help:
You need this belt:
Eureka SurfaceMax 300 Belt
This is the manual with instructions:
Owner's Guide
Posted on Jan 02, 2010
  • 142 Answers
SOURCE: My Fantom Fury vacuum does not pick up dirt. [The
You will have a blockage in the vacuum hose. Take it of and outside and push the garden hose from one end to the other.
Posted on May 10, 2010
SOURCE: my eureka surfacemax 300 is not sucking up
I've found that some times if you let the cup get too full, stuff will get jammed up above it. Turn off the vacuum and unplug it, and remove the cup. Reach up inside the vacuum above the cup and there is a small, plastic cylinder you can twist to remove (twist and pull down). clean this plastic piece off, and reach up inside where it was located. Clean out that crevice as well. Vacuum should be as good as new!
(It shuts off because it is over heating from not being able to pull anything through there.)
Posted on Jun 13, 2010
#1 Taper
  • 1040 Answers
SOURCE: My Eureka model 2961
Here is a Link to one of my Tips:
www.fixya.com/support/r6311178-vacuum_brush_bar_not_spinning
This should solve the problem.
Good Luck!
Jim
Posted on Oct 12, 2010
Eureka vacuum blowing dust into the air
Check the leak (where the dust come from); maybe you need to tighten or reseat one or more part in that area.
Feb 09, 2014 | Eureka AirSpeed One Turbo Bagless Upright...
Smells hot when running and will not pick up debris I recently cleaned all filters
Something is stuck in the piping system. The passing vacuum air is used to cool the motor. It's not getting that air so it will start to over heat and smell
Jan 09, 2014 | Eureka Surfacemax 200 Bagless Upright...
Seems to **** up the dirt/dust and simply blow it out instead of capturing it inside
Most of these have an suction hose and a blow port. One blows air, one sucks air. Make sure the suction hose is on the correct port. Also, a dirty air filter will cause the same effects. The filter must be good to prevent the dirt and dust being blow around.
Nov 08, 2010 | Craftsman 17026 Wet/Dry Vacuum
Surfacemax 300 yellow eureka vac. is there a belt? if so , what is the belt number and how do you change the belt? most vaccs have this info on the product a is not ablet to locate this info. tnanks
On the top yellow part above the rollerbrush, there are two screws. Take them out. Insert your fingernail into the part where the yellow meets the rubber and lift. The yellow should pop off. Follow the directions printed on the label inside, directly above the rollerbrush to change the belt.
Your vacuum SHOULD have come with a replacement belt as well as an instruction guide. The instructions for replacing the belt are there. If you don't have this, well, that's why I typed this out. :) You can purchase a belt on eureka.com by looking under customer service, and putting in your model number. This is located on the label on the back of the vacuum, under where the cord goes through that loop thing.
Oct 24, 2010 | Eureka 6833D SurfaceMax Canister Vacuum...
My eureka surfacemax 300 is not sucking up anything and i have cleaned out the hose plus i turns off by itself sometimes
Apr 16, 2010 | Vacuums
How to change a broken belt on a eureka surfacemax 300
You need this belt:
Owner's Guide
Jan 02, 2010 | Vacuums
What causes a vacuum to make lots of dust and throw back out what it vacuumed
It sounds like the airducts that lead to your dirt chamber are clogged. The dirt can't get through to the dirt cup so it spits it back out and blows dust everywhere.
Nov 27, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Eureka 4463 Vacuum blows OUT dirt
sounds like the pipe is stopped up,, you need to take it off and run a rod through it and unclog it,, sometimes small toys ect. can get in pipe stop ot up,, hope this help you,,good luck
Aug 14, 2009 | Eureka Lite 4463 Bagged Upright Vacuum
Vacuum
I just discovered that if you remove the dust cup, lay the vaccum back, reach up inside above the dust cup area, there is a yellow piece that can be removed (twist it and it comes out.) I found that there were GOBS of lint and pet hair stuck inside there. We removed all of that and the vacuum works great again!
Jul 25, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
207 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
