Question about Orbit Pump Start Relay
How to wire a sprinkler relay to timer
Orbits 57009
2 Suggested Answers
SOURCE: have a orbit 57009 pump start relay but pump does not turn off
It sounds like a stuck pump relay.
Posted on May 06, 2009
My orbit is wired right, but only sprinkler number 2 will work. It comes on when I push for 1 3and 4
If indeed it is wired correctly, and your wires go where you think they do, then your Orbit is defective.
Test by removing wires 1,2,3, and 4.
Push for 1, and touch wire 1 to the connector for 1. Sprinkler 1 comes on? Touch wire 1 to the connector for 2. Sprinkler 1 comes on?
If yes to both, then Orbit is broken.
Sep 06, 2016 | Orbit Hardware & Accessories
How to connect the wiring
Need to know what your trying to connect to
Mar 08, 2016 | Orbit Irrigation 57009 WaterMaster Pump...
Wiring new sprinkler timer one wire on my old
Just cut the common wire and put one end in each of the 2 pins. The rain sensor just interrupts the signal to the valves when wet.
Nov 04, 2013 | Orbit Underground 57896 6 Station In/Out...
When i turn the system to run hear a click in the pump relay but system does not come on
Turning the dial to run should not send any electrical current anywhere it simply is set to come on at the scheduled time. If your turning the dial to run and attempting to start the valve manually and a click the pump or valve solenoid clicks, the flow control may be closed, the water is off or the valve has failed to open. Try opening the bleeder screw to see if the valve opens this way. If so, try replacing the solenoid if no, replace the valve.
Aug 29, 2013 | Orbit Irrigation 57009 WaterMaster Pump...
I have city reclaimed water source for my sprinkler system. My problem is I connected the waterlines to the solenoid (1) and then the zone index valve (4 zones ), then i wired the solenoid to my spr
What model number of timer? I have to see exactly which timer you have to answer question.
What wire goes where?
Are you using 120Volts?
What is output voltage of timer?
What voltage is solenoid? 24Volt or 120Volt?
Copy following links for Orbit manuals:
http://www.orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Aug 09, 2012 | Orbit Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Sprinkler timer will not start pump. i need wiring help
have the same problem,, but the small button on the bottom of the start relay works to run the pump or if i put the two start 24 vt wires to the timer 24 vt spaces,, but can not get the timer to turn on the pump when it turns on the water, even tried the orbit help center, and they said it was faulty timer, so i replaced it ( another wasted 2 hrs to return the old and hook up the new one) only to find out it too was exactly the same results. Next round,, i look for a diferent brand timer and pump relay switch,,, hope this will solve my problem
Sep 12, 2010 | Orbit Pump Start Relay
Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Orbit Pump Start Relay Logo
49 people viewed this question
Top Orbit Garden Experts
squeely
richie46
Are you an Orbit Garden Expert? Answer questions, earn points and help others
