Question about Richmond Heat Trap Nipple Kit - RP20003
Heat Trap Nipple which side into the tank
I bought your heat trap nipples, in the directions it says red side up for the hot and blue side up for the cold. the nipples in the package are both blue and both sides of the nipples are blue. So which side goes into the hot water heater.
  • Richmond Master
  • 5,245 Answers
Don't install heat trap nipples if house has pressure issues, or pipes get clogged with hard water.
Heat traps will clog, and whistle, hum, buzz, and reduce household pressure.
Make your own heat traps by configuring pipes differently.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#heat-trap
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
Buy regular di-electric nipples at local box store plumbing department instead of heat trap nipples.
http://waterheatertimer.org/images/IMG_1879-di-electric-nipple-300.jpg
If you go ahead and install the heat-trap nipples, look inside the nipple.
Look past the plastic bar that divides down middle.
Notice that one end has insert inside the pipe. While other end does not have insert.
End with insert goes into water heater first.
Notice also if you blow into the heat trap nipple that air flow is constricted.
If air flow is constricted, then water will also be constricted.
This is why heat trap nipples are not recommended.
Why do they have heat trap nipples??
So manufacturers can report higher EF energy efficiency rating for product.
Do heat traps save money. Yes, but make your own by reconfiguring pipes. Save $9.20 per year electric heater, $4.00 per year gas heater.
You can save more money by maintaining water heater, which pays about 10$ per month in future replacement costs.
Or fix leaks, and install dual-handle faucets so lifting single handle faucet in middle does not continually run cold water into tank. This saves $2-$8 per month.
Posted on Nov 27, 2012
  • Marc Garin
    Marc Garin Apr 02, 2014
    HOw do I remove the old ones ??
How to install heat traps in correct direction.
follow the arrows blue being cold in and and pink hot out .
Mar 15, 2015 | Camco 2PK Dielectr Heat Trap
Kenmore power miser 5, water only stays hot for
sounds like the down tube broke off On the cold side there is a tube that takes the cold water to the bottom of the tank and heat up to replace it . That causes it to help push up the hot water . You will need to remove the nipple bringing in the cold water and replace the tube. you can check on the tube after you remove the nipple by sticking in a finger and pulling up the remains of the tube if it was not attached to the nipple if there is nothing there same thing you need a down tube.
Oct 09, 2014 | Water Heaters
Squeeling sound and lower pressure from gas water heater
Probably the factory-installed heat trap nipples are clogged.
Open following links.
Noisy whistling and humming and low pressure are common problem with heat trap nipples and inserts from factory.
Replace heat-trap nipples with pex-lined nipples, or remove heat trap inserts with screwdriver or needle nose... careful not to break insert so it falls into tank ... which can then get lodged in hot water line elbow or under-sink shut off.
Factory-installed heat traps are part of overall strategy so manufactures can claim more efficient water heaters, without requiring customers to any thinking.
Other strategies include foam insulation instead of fiberglass (so that wires cannot be replaced on electric units), reducing factory-set temperature from previous 130-135 to 100-120, and re-estimating downward the hot water use for average family.
So some of the strategies are useful, while others problematic or imaginary.
Call manufacturer to pay-for or provide new pex-line nipples. Warranty for fist year covers Labor and parts, and after 1st year, warranty covers parts
http://waterheatertimer.org/Water-heater-manufacturers.html
Save $10 a month in future replacement costs: maintain water heater so it lasts longer:
http://waterheatertimer.org/How-to-maintain-water-heater.html
Apr 25, 2013 | Rheem Tankless water heater for 1-2...
NEW WATTER HEATER MAKES A HUMMING /WHISTLING SOUND
Factory-installed heat traps can cause this problem:
Remove heat traps, or heat trap inserts, or heat trap nipples.
Make your own heat traps, and save 4-9$ per year, using flex copper connections, or reconnect pipes in heat-trap configuration.
Always insulate pipes.
With electric heater, pipe insulation can run all the way to tank.
With atmospheric-vent gas water heater, the pipe insulation cannot obstruct air intake at draft hood. With power vent gas, the pipe insulation can run all the way to tank.
Mar 10, 2013 | Water Heaters
I am looking for a magnesium anode for a Rheem natural gaz water heater PV75
There are two types magnesium anode.
1) Hex-head that screws into separate port on top of tank, and comes either 44" long or 12" sausage links.
2) Combo-anode that connects to Hot water nipple, and comes in solid or combo.
Contact guys at following link to purchase anodes
http://www.waterheaterrescue.com/pages/WHRpages/English/OrderPages/XCart/sales-through-XCart.html
General instructions and types of anodes
http://waterheatertimer.org/Replace-anode-rod.html
Rheem 'preferred parts'
http://waterheatertimer.org/pdf/2011_Rheem-anode-rods.pdf
Purpose of resistorized anode is supposedly so magnesium performs as well as aluminum.
Rheem however had 'resistorized elements' years ago, and that turned out to be promotional gimmick so people would buy rheem-brand products.
Nov 02, 2012 | Protech Rheem/Ruud SP13901B - Anode...
How to how to install the anode rod - for extended warranty - in a new Rheem waterheater?
You are installing a combo anode rod that replaces hot water outlet nipple. This means you will have 2 anode rods, which doubles the anode capacity of tank, which can cause extended life of water heater, assuming that both anodes are inspected each 2-5 years.
Sounds like a heat trap insert is in the way.
Look at parts sheet that comes with product manual.
Pull insert out since it will cause clogs.
Same insert is on cold side nipple.
I want you to contact the Tank forum since they are anode experts:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Tank will recommend magnesium anode and not aluminum.
My understanding is that Rheem water heaters are made so only Rheem brand anodes fit their tanks. While other companies use generic anodes that are sold at any plumbing supply, and also sold at Tank website.
You can configure pipes to make heat traps that save save $2-4 per year on gas water heater operation.
http://waterheatertimer.org/images/Heat-trap-install-900.jpg
Sep 08, 2012 | Water Heaters
Heater wont start. I replaced the pressure witch, doesnt work, I by passed the pressure switch and put the red and blue wire together and it will run until it gets hot. I remove conected wire and...
What water heater do you have?
Is this a tankless or tank-type water heater?
If tank-type, what gas valve is on the heater?
What does the water heater manual say?
Add a comment with more information for possible help, or possible re-direct to correct expert.
Sep 22, 2011 | RELIANCE ELECTRIC WATER HEATER
I am trying to replace the dip tube in my RheemPowerVent water heater but I can't for the life of me figure out how to get the old one out. The treaded metal cold water nipple is screwed into a circular...
1) Rheem power vent series:
http://www.rheem.com/product.aspx?id=C24E3F52-A6A4-4BC7-AF5B-0DF23A7A0263
2) Looking at product over-view manual: It says 'inlet connects directly to a dip tube which directs water to bottom of the tank.'
So it appears that dip tub is connected to heat trap nipple on cold water side
3) Sample manual for Rheem shows exploded parts list
http://globalimageserver.com/fetchDocument.aspx?id=a92c7d0e-8a95-48ba-8810-cd714f33d47a
The exploded view shows cold water nipple separate from dip tube, and shows dip tube gasket, and makes it unclear
4) Manual shows Rheem phone number:
1-800-432-8373
5) You can also post specific questions like this on pro water heater forum: http://www.thetankatwaterheaterrescue.com/forums/forum3/
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project. As general rule, expert will not answer unless they know specific answer, to avoid dissatisfied customer.
Fixya is always less expensive than a service call.
Feb 05, 2011 | Rheem Flared Water Heater Dip Tube
Richmond Heat Trap Nipple Kit - RP20003 Logo
1,561 people viewed this question
Top Richmond Water Heaters Experts
Gene Haynes
Tom Chichester
David Spradling
David Spradling
Are you a Richmond Water Heater Expert? Answer questions, earn points and help others
