My aspire 5542 wont start up .... the power button light is on but the screen is black...there is no noise if the hdd work.. plss help
A friend asked me to look at his Acer Aspire 5542 which would not do anything except charge the battery. All that happened when pressing the power button was the fan and blue light came on, no hard drive, screen or anything else worked. I checked the memory which was OK, tried an external monitor, nothing. So started taking it apart, got to the main board to find a bios backup battery type CR2032. On checking it, it only had about 1v instead of 3v. I changed it , plugged the hard drive on to the main board connector, connected the laptops battery on to the main board. Pressed the power on button, the lights lit up and the hard drive became active so reassembled everything and tried it again and everything worked fine. It appears that if the internal backup battery is flat then it will not do anything apart fromturn the fan on and light up the power button. There are plenty of sights on the net with disassembley instructions to get at the main board. Hope this helps someone else !!
Posted on Mar 02, 2016
  • 32,281 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Nov 27, 2012
micromend
  • 748 Answers
SOURCE: Need help for Acer Aspire ONE MODEL # ZG5 screen does not work
If you are sure the computer is running then connect an external monitor to the laptop. You will have to select the external using your Function keys FN + F7 or F8. If you can now see your machine on the external monitor then you know it's the screen portion of your laptop that is faulty. If this does not work then the sounds you are hereing are probably just the fan and the hard drive spinning. These are not an indication that the computer is working. All in all, I would say that the laptop needs to see a pro.
Posted on Mar 26, 2009
SOURCE: my acer aspire one netbook was black screen but the power was lighted, i hear the fun was spinning and the hdd was spinning, please help me, when i powered on it lights up but no display at all a blac
all you do is take out the battery in the back and put it back in and your good to go.
Posted on Jun 29, 2009
CompuGuy44
  • 432 Answers
SOURCE: acer aspire 5630 BL50
You can try basic troubleshooting. Unplug the laptop, takeout the battery. With the laptop still unplugged, put the battery back in and power-on the laptop. If that doesn't work and you hear no beeping sounds, the motherboard maybe bad and needs replacing.
Posted on Apr 05, 2008
  • 10 Answers
SOURCE: Acer Aspire one screen stays black
i have this problem 2 days ago.. and this works on me... maybe on your's too you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios how to flash the bios: STEP 1.download the AA1 BIOS from this link: http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip 2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive now, start the process STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in! STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart. this works on me... good luck.. and i hope it will help you.....
Posted on Jun 15, 2009
ailia
  • 175 Answers
SOURCE: acer aspire one black screen and no boot
Contact with notebook repairing engineer. Might be coz of some short circuit, BIOS corruption or any malfunction of the hardware.
Regards;
Hassan
Posted on Jul 08, 2009
I have an acer aspire z1620 that wont boot up. when you press the power button it lights up and says no signal detected then the screen goes black and has a loud continuous noise whats wrong with it?
the noise is problem could be your fan in the power unit
when did you last clean your system the screen going blank could be loose video cable. you be best to get it look at, before it gets worse
Jul 07, 2015 | Acer Aspire Z1620 Desktop Computer
Black screen when power on my acer laptop
hi
try to isolate using external monitor,
check connection of lcd cable
replaced lcd panel
Apr 07, 2014 | Acer Aspire 5241 5251 5332 5334 5338 5516...
My acer aspire 5532 just went black. The power button goes on' but no response whatsoever. Any clues?
Just try this steps
1) Shut down your computer and disconnect the battery and also the Ac adapter which is connected to your laptop, and then once your computer is Off just press and hold power button for at least 15-20 sec and yes do not lift your finger from the power button
2) Reconnect everything Battery as well as your Ac adapter, and try to see if the issue is resolved or not
3) Load BIOS setup Default
4) Try to go to safe mode
5) Do system restore when your computer was working fine
I hope this will answer and fix your issue
Regards
MAJID KHAN
Nov 30, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Screen is black
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Aug 25, 2012 | Acer aspire 5542 1615
Acer Aspire 5542 wont startup
Bring it to a repair shop and have them check it out. They should at the very least be able to recover you data.
Jun 29, 2012 | Acer aspire 5542 1615
Acer Aspire 5542 won't boot up. Power light comes on but screen is black and computer not making startup noises
try tapping f8 when booting up that gets you into safe mode. then try doing a system restore to before your problems. safe mode can take upto about 20 mins before welcome screen. try it this may help
Jan 06, 2012 | Computers & Internet
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
Computers & Internet Logo
1,324 people viewed this question
David Payne
David Payne
