My pavilion 4445 computer will not boot up .it has error messages that say registry or configuration error. or cannot find win.com. it says to choose command prompt only and run scanrec.but,it wont let me past that point.it keeps saying missing or corrupted file for c:\windows\dblbuff.sys -and c:\windows\ifshlp.sys -andc:\windows\himem.sys. it was working fine,but would not let me get on line. i disconnected it and hooked up my old ibm and checked my e-mails. i hooked the hp,(pavilion) back up and it wont get past the black and white screen giving these error messages.i orderd a recovery disk from hp,which was supposed to restore the factory settings. what i recieved was a disk that says hp pavilion floppy disk controller patch.it wont load either. im running windows 98,and the computer is out of warranty and was given to me. it was working fing with sound,and was loaded with stuff. all i did was unplug it for several hours and this is what i ended up with. any help with this would be greatly appreciated. im an out of work senior vet on a very tight budget.
    Novelist:
    Champion:
  • 233 Answers
It sounds like maybe some malware got into your computer and messed up Win 98 really bad. If you have the OEM disc try and re-install the OS. But you will probably find that Win 98 will not have all the drivers for your computer. It always came up short in that department. And you will find very little on line support for Win 98. It's been obsolete for years. It sounds like this would be a good time to migrate to a more modern OS. Go online and Google Linux. You can get a number of Linux based operating systems for FREE! Ubuntu is supposed to be a good one. It may take a little time to learn to use it but I feel for the price it is worth the effort. Over the years it has become more user friendly. It has it's own applications and should have all the drivers for your hardware. It also is not vulnerable to all of the Windows malware that is out there. So for someone on a tight budget it seems like a good option. While this is not a solution to your immediate problem it is something to consider.
Posted on Jan 10, 2009
Failed to load application configuration data from "core.hp.main/application.xml" what does this mean
It is to do with servers. See; http://docs.oracle.com/cd/E13222_01/wls/docs61/programming/app_xml.html
Try booting in safe mode and restore your system to a known good date. When successful, you will be able to find out mre about why you have this error. It is probably a registry error.
Dec 07, 2013 | Computers & Internet
Code 19 Error
How to Fix Windows Error Code 19
f your computer's CD or DVD drive appears to be missing or corrupted and you've received a "Code 19" error message that says "Your registry might be corrupted," you can fix it by following some steps to modify the Windows registry. Note that while this process isn't particularly complicated, it does require that you are familiar with computers and know how to modify the Windows registry. If you aren't comfortable doing this, you should seek the help of a qualified computer professional to assist.
Instructions
1. Click the "Start" button, click the "Run" option and then type "regedit" and click the "OK" button.
2 Use the navigation pane on the left side of the window to navigate to the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10
3 Select the "UpperFilters" key in the right side of the window, then click the "Edit" button and then click the "Delete" option. Click "Yes" to confirm the deletion.
4 Click the "LowerFilters" key, then select the "Edit" button and choose the "Delete" option again. Click confirm the deletion.
5 Close the Registry Editor window and restart the computer to finish applying the settings that should fix the Code 19 error.
_________________________________________________________________________________________________________________________
How To Fix Registry Code 19 Errors
The Code 19 registry error is caused by a system hardware failure. The failure occurs because the computer is trying to use two drivers for the same device on the computer. When you try to boot your computer, you will get a Code 19 error message that will lock you out of the computer. You can resolve this error by using the Safe Mode option
Instructions
1. Start your computer and then press the "F8" key while it is starting up. This will take you to the "Advanced Boot Options" menu. Scroll down to the "Safe Mode" option with the arrow keys on your keyboard.
2 Press the "Enter" key and wait for the computer to boot into Safe Mode. This should take about 45 seconds to complete. Click the "Start" button when the computer has booted and then click the "Run" box.
3 Type "Regedit" into the run box and press the "Enter" button. This will start your registry checker tool. Wait for the registry checker tool to complete the scan. This should take about one to five minutes to complete. When the scan has completed, you will be prompted to restart your system.
4 Click the "Restart" button when prompted to restart your computer. The computer will restart as normal and the Code 19 error will be fixed.
The Windows registry is a large database that contains the settings and configurations for hardware, programs and applications running on your computer.
Dec 02, 2011 | Computers & Internet
Win 7 blue screen of death on shutdown? happens on one in five shutdowns the others take several minutes (10) to complete the process.
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Thanks for using FixYa.
Jul 16, 2010 | Dell Computers & Internet
Need to boot in restore mode. loaded a driver and its know going to the blue screen
Then press any key.
Then type "y"
Mar 13, 2010 | Computers & Internet
Blue screen Technical information stop: 3A0x00000024 280x00190203 2C0x81B599F8 2C0X0000102 2C0x00000000
Then press any key.
Then type "y"
Mar 04, 2010 | Dell Inspiron 2200 Notebook
Windows installer error
DID YOU GET THE RESTORE CD WITH THE HP SYSTEM IF YES THEN PUT THE CD IN START YOUR COMPUTER CHOOSE BOOT FROM DVD AND THATS IT IT WILL RESTORE IT OR ELSE U TRY PRESS FUNCTION 8 LIKE F8 AND CHOOSE LAST KNOWN GOOD CONFIGURATION. IF DOSENT HELP U HAVE TO GET THE GENUINE wINDOWS DVD AND INSTALL YOUR WINDOWS AGAIN
Mar 03, 2010 | HP Pavilion A6400f Desktop PC, Refurbished
Blue screen of death presario v2000
Then press any key.
Then type "y"
Feb 11, 2010 | HP Compaq Presario V2000 Notebook
How do i fix the blue screen stop 0x0000007e on my dell laptop vostro 1510. I can't even start in safe mode.
Then press any key.
Then type "y"
Feb 10, 2010 | Dell Vostro 1510 Laptop
I can't start my computer. Message "start your computer in safe mode"appears on the screen and than screen goes black and after few seconds the previous message appears on the screen.It's like a vicious...
Assuming Win-XP? ... When the computer is booting up (before windoes graphics) keep on tapping the F8 key to boot into safe mode. You should then be able to identify what is stopping Windows from booting properly.
- Have you just installed any software / drivers?
- Check the error logs and device manager to see if anything is wrong
Good Luck
Jan 18, 2010 | Toshiba Satellite P35-S611 Notebook
Computer won`t boot
u will have to reformat the hard drive and load win 98 or win xp whichever u want to fix this
you can have more detailed info at
http://www.computerhope.com/issues/ch000474.htm
Jan 31, 2008 | Computers & Internet
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
