Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washing never ends
My washer is about 4 years old, and the washing cycle does not sop. For example, if I start a "regular" wash cycle, then immediately after this cycle completes the washer will begin a "permanent press" wash cycle. Fortunately, the end-of cycle buzzer still works so I can manually stop the washer early into the next cycle.
  • 87 Answers
I would replace the timer.
Posted on Jun 08, 2007
Why is my whirlpool auto load sensing washing machine spraying water while in final spinning cycle?
you could have a bad temperture sensor bad are water valve but first check an make sure the washer drain alway check your drain hose for clog are lint are trash in pump an last you could have a bad timer if you dont know how to check these call a applince service for repair ok
Dec 13, 2017 | Washing Machines
Wt you mean by spin in washing machine
its a separate cycle all by itself.
Say U hand wash something in a sink and instead of wringing it out by hand U can put it in the washer and press this SPIN cycle.
So U can also use it to spin more water out of your garments after the regular wash and spin cycle.
Slower spin speeds mean -
  • Cheaper washing machines
  • Quieter washing machines
  • More stable washing machines
  • Longer lasting washing machines because there's less wear and tear on the bearings, motor, carbon brushes, suspension etc.*
  • Gentler on laundry
  • The drum spins for approx 4 or 5 mins. No water is added and you dont add detergent or fabric softener for the spin only option. The object of the exercise is to centrifugally remove excess water from the garments in the drum. They will still be damp but not sopping wet after the spin cycle
  • Spin takes the water out, extract is even better
May 17, 2011 | Frigidaire ATF6000ES Front Load Washer
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
WASHER MAKES A HUMMING NOISE IN SPIN CYCLE BUT DOESN"T SPIN & CLOTHES ARE SOPPING WET.
what's the brand name and model number,all washers are different,most likely it's the motor humming or the pump is humming,could have something stuck in pump,if the water doesn't drain the washer won't spin,if you have a shop vac pull the drain hose out of stand pipe or sink,stick the shop vac hose onto the drain hose,get it down as low as you can and suck out the water and then see if it spins,if there's alot of water in the tub suck it out of the tub first then go to the drain hose,if it spins when water is out you know it's the pump but if you say water is still in tub i would have to say it is the pump,
Dec 25, 2017 | Washing Machines
Maytag top loader stopped during spin and now won't start.
ok check the lid switch,,did it knock it out of place,,unplug and take back off ,,,
Jan 05, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine suddenly stopped working during cycle
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jan 01, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Washing Machine
the main water valve that the fill hoses connect too in the back of the washer is probably bad.
Jul 25, 2008 | Indesit W 123 Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
247 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
