Question about Crafts & Hobbies
Foriegn object stuck in hot glue gun! - Crafts & Hobbies
    Champion:
    New Friend:
  • 217 Answers
What is the object? where is it stuck? depending on the answer to those 2 questions, the solution may differ
Posted on Feb 26, 2013
  • 2712 Answers
SOURCE: Glue Gun Question
Gather the materials needed and place them on a flat surface near an electrical outlet. Examine the glue gun. Locate the metal rest. This is usually attached to the barrel of the gun and is shaped like a "W." Make sure it folds out and locks into place. Locate the trigger. This is just behind the barrel on the underneath side of the gun. It should be a solid piece of plastic shaped like a slice of pie. Just above the trigger, is the barrel loader. This is where the glue sticks go into the gun. Inside the barrel loader there is a smaller round piece of plastic. This is what actually pushes the glue stick through the barrel. Pull the trigger and watch the piece of plastic move with it. Pick up the electrical cord and examine it. Make sure the prongs are secure and not bent. Make sure the cord has no breaks in the outer lining and there are no frays at the base of the gun where the cord attaches. Plug the glue gun into the electrical outlet. Allow the gun to heat at least 15 minutes so it reaches operating temperature. When the gun has heated at least 15 minutes, insert a glue stick as far as it will go without forcing it. Now pull the trigger until a small drop of hot glue forms on the tip of the gun. Practice gluing on the paper plate. Pull the trigger until a ball of glue forms on the plate. Release the trigger and quickly press the tip of the gun down onto the surface of the plate and pull it to the side. This will break the glue and stop it from stringing out when you pull it away. Continue practicing until you get the right amount of glue you want for the object you imagine using. When you pull the gun away, there may be a small string but this will break off easily. When you have the perfect amount of glue and only a tiny string forming when you pull away, you are ready for your project.
Posted on Aug 27, 2008
  • 5 Answers
SOURCE: Glue Gun Troubleshooting
1. Insert your wax stick into a standard sized glue gun. The fit may be tight. The more wax you use, the smoother the fit. 2. Use a second wax stick in the gun to help advance the first, if needed. 3. Heat the gun up to temperature. 4. Do a few test pulls on the gun to get a feel for the quantity of wax you would like to use with your seal. (Two good pulls of the trigger will produce a full seal for the larger sealing coins.) 5. Wait for 10-15 seconds, then press your seal firmly into the wax before it hardens. 6. Lift the seal slowly off the wax. If it comes away and the wax is still quite soft, wait a little longer before pressing the seal down.
SOURCE: Glue gun support
Try using denatured alcohol from your local hdwe store along with a rag, comb, and even a toothpick . A test area would be my first idea; color fastness and while there is not much odor it may affect some people with allergies and respiratory problems. It will take some time but be careful not to saturate the carpet itself just the immediate area; the alcohol may breakdown adhesives bonding the carpet fibers to the backing or seaming tape on the underside.
Posted on Jan 09, 2009
Mrteaze
  • 101 Answers
SOURCE: glue stick is stuck in glue gun and can't be
Make sure you plug in the gun so glue is soft if gun not getting hot the you have another problem
Posted on Sep 29, 2009
sonicboomele
  • 1557 Answers
SOURCE: I have a glue gun
i actually did this to one of my workshop guns i found the best way to fix it was to heat the gun up using a hair dryer and then pushing the old glue back up the tube and out and now when im not using the guns i take the glue stick completely out
best of luck
merry christmas
Posted on Dec 07, 2010
How to use glue gun
PLug it in and if there is a on/off swith turn it on. The gun's heating element will get hot. When it is hot enough to melt the glue stick you have put inside through the hole (that is glue stick sized and on your end) then the trigger will push the glue stcik into the hot metal melting and coming out the end so you can deliver it where you want to glue something. Beware of the heat. You absolutely can burn yourself touching the hot parts of the glue gun. Think how you would not touch the hot part of a steam iron... same problem.) That's pretty much it. Pull the trigger to push the glue stick though and add more sticks as you need them. And beware of the very hot nature of hte tool.
Dec 27, 2013 | Stanley Crafts & Hobbies
The glue won't flow out of my glue gun, any advice?
If it's getting hot, you press the trigger but you get no glue, your tube is stuck. something ( dirt or smthng) blocks the exit. Heat it up, turn it upside down (nose up) and without inserting a new stick, let the heated glue flow iut of the gun. Hopefully any dirt will be forced to fall down. If you need more drastic results, you must open the tool, fasten it on a bench wrench, but make it so that no caurrent will be passing through the wrench, by using two pieces of wood as intermediate holders, plug it to power, nose up. and when it has reached a very hot temperature, use a high pressurized air pistol, to blow out anything that blocks the tube.
Anothe option, is to remove the nose if there is an option to twist it. See if there is a hexagon head. If yes, you cab turn it and eventually clean it up.
Sep 13, 2010 | Crafts & Hobbies
How do i insert glue stick in to my emhardt electric glue gun
Insert the glue stick into the back of the gun. After doing this plug in the gun and allow it to heat up. When the gun reaches the correct heat level you will be able to pull the trigger of the gun which will pull the stick into the gun. This will only happen if the gun is hot enough.
Aug 16, 2010 | 3M Polygun AE II Hot Melt Glue Gun
Glue stick is stuck in glue gun and can't be removed.
Sep 29, 2009 | 3M Crafts & Hobbies
Glue Gun Question
Aug 27, 2008 | Rubbermaid Power Tool Hook Black
Glue Gun Support
Plug the glue gun into an electrical outlet. Make sure it is placed in a secure place, away from flammable items. As the glue gun heats up, a little bit of glue might drip from the end so you won’t want to leave it on a wood table or on carpet. Insert a glue stick into the back of the glue gun. If the glue gun already has a glue stick in the chamber, keep a second one in reserve nearby. Gather the materials you want to glue together. Hot glue works exceptionally well on thick fabrics, dried flowers, Styrofoam, wood and plastics. Since it leaves a thicker residue, it is not the best choice for thin papers, fabrics and ceramics. Check to see if the glue in the gun has melted by squeezing the trigger slightly and touching the tip to a test piece of paper. If the glue comes out easily, the glue gun has heated up fully. If the trigger is hard to pull, wait a minute more for the gun to heat more completely. Pick up the glue gun and squeeze the trigger slightly while you draw a thin line on one side of the item to be glued. Immediately place the other object to be glued on the glue line, pressing firmly. Hold the two pieces together for about 15 seconds. Test to see if the item still holds when you remove one hand. Let the item set for a few minutes in order to “cure.” Once the glue has dried fully, use a fingernail to scrape away any of the excess glue.
Aug 27, 2008 | Dremel 1550:30 Versatip Tool Kit
Crafts & Hobbies Logo
56 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
