Question about JVC TH-C30 System
My 8pin Din connector broke off in my subwoofer. The cable seperated from the metal end with the pins. All the pins seem to be intacked and after getting the ends back together, Im getting no connection. Is there a way that I may be able to rewire it myself?
4 Suggested Answers
SOURCE: JVC TH-C5 Solder 8 pin to sub circuit board
The best solution I could give would be to go on E-Bay and type "8 pin DIN" into the search, and just buy one. I just did. The price is higher with longer lengths, but it's worth NOT messing up the subs built-in amp by getting the pins wrong.
Posted on Sep 06, 2009
SOURCE: is the system cable wired as a serial connector
u can get one from cablesondemand.com 8 pin mini din male/male
Posted on Nov 09, 2009
SOURCE: SP-PWM508 subwoofer input conections
sub hooper power was not come.
Posted on Apr 13, 2011
Pinout for 8pin din plug
Hi looking at female 8 pin din with the groove at bottom this is No 8 going clockwise to the left is pin 6 next is No 1 then 4 - 2 - 5 - 3 - 7. ..Hope this helps..
Jan 27, 2016 | JVC Audio Players & Recorders
Rj45 connectors seem loose in ports. if you wiggle the cable you loose connection. we made our own jumpers with cat 5 and standard 8pin rj45 ends
Does each end "click" when you push it into a socket? It should.
Most 8-pin RJ45 ends have a "tab" -- squeeze it to release the "lock" which holds the end into the socket. Check that the "bump" on the tab is going deep-enough into the socket to "lock" the end into the socket.
Apr 08, 2010 | ADC Kentrox Network panel (MPP-N28BA1)
ACS295 speaker cable to subwoofer, one of the pins of the connector is broken, how can I fix it or get a new connector?
if connector is broken, you need to buy a new connector, but it takes a little handwork and some tools a screw driver some electric iron and solder.
u need to open subwoofer case and check for the connector is soldered in a board is 2 jack 3,5mm female connector and one red mini-DIN connector. replace the connector take a attention on soldering the connector, dont damage the board wires and pins, if the iron above 300ºC.
take a special attention on electrostatic discharge, normaly burns sensitive boards.
Jan 30, 2010 | Altec Lansing ACS 295 Computer Speakers
Zoom 9030 works well after all these years there is a memory battery that needs to be changed every 5 years or so. The only problem is when I plug in the 8050 foot controller it won't change any patches...
It is LIKELY that one or more pins and or wires in the remote cable are broken.
These MINI DIN connectors are "tender" and are easily broken and wires flex at the back of the connector and are broken.
FIRST check that all pins are present at BOTH ENDS of the cable.
NEXT use an ohmmeter to check continuity of each and every pin end-to-end. I suspect you will find one or more broken.
Be aware that repairing this cable requires patience and steady hand as the pins are so close together it is easy to have solder bridges, etc. Sometimes just opening the connectors are a problem to access the pins. Sometimes the cables are MOLDED and those are UNREPAIRABLE other than cutting off the bad conector and replacing it. You can usually buy replacement connectors at DIGIKEY.com and or Mouser.com. You have to CAREFULLY select the apporpriate pin configuration from the catalog page. One needs a small soldering iron and magnifying glass to work on the cable.
USUALLY the wires go from pin to pin. Also a shield on the cable has to be dressed and connected usually. You may find the shell of the connector tied to a pin or just the sheild of the cable.
Jan 08, 2010 | Zoom Music
Sep 01, 2009 | JVC TH-C5 System
Samsung ht ds1000 plays fine, but there is no sound.
you have not blown thye fuses the static sound suggests that that is not the problem
Jan 19, 2008 | Samsung HT-DS1000 System
JVC XV-THC4 Home Theater System
it a 8pin din cable ,,,,I picked up one from a specialty cpu shop in Norcross,Ga
but search ""8pin din cable"" see what you find!!!!
the power cord is extremely common ,you can find that one anywhere ,,,,,most any dvd player ,playstation etc etc etc uses that cord
Sep 17, 2007 | JVC THC4 Home Theater System with 5-Disc...
Power cable for A1451
yes if you will open up the unit and look on the circuit board that it connects to it is labeled plain as day what each plug is (b+, gnd..) find that out and thats how ya do it
Apr 15, 2007 | AudioBahn A1451 10-Disc CD/DVD Changer
JVC TH-C30 System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
