PIXMA Pro 9500 MKII Error B200 = VH (Print Head Drive Voltage) is out of the specified value.
Need to :
- Replace print head and logic board at the same time.
or
- Replace Carriage Unit
or
- Power Supply Unit
5C00 means you need to replace the purge unit,the purge unit is blocked or skipped.Try to unzip the printer and try to replace the purge unit,the purge unit is on the rigth of the printer.
If you try to clean the print head and nothing,first need to replace the print head....if the problem persist you need to replace the purge unit too.The purge unit is on the rigth of the printer,you must unzip the printer to reach the purge unit.
NOTE If you replace the print head you need to use only original cartridge canon,the head is verry sensitive at refill cartrige or compatible.
If i have been useful please give me a vote :).Thanks
The purge unit is blocked,the purge unit is on the rigth if you open the scanner.You must unzip the printer to look at the purge unit.In the main part you need to replace the purge unit.If i have been useful please give me a vote :).Thanks
Problemisa bitserious,the problem is with the purge unit...is blocked,try to look in the purge unit (you need to unzip the printer) notbean objectfellthrough it.6A80 YOU NEED TO REPLACE THE PURGE UNIT.
The 5C00 code is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30. This is the part number, if you need to replace it: Purge unit (QM2-2925).
