Question about Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat
Thermocoupling on a Honeywell Economy Plus EP50B Boiler
Hi. I am trying to replace the Thermocoupling on this above boiler but in all the confusion of cleaning the unit, i forgot where to plug the other end with the stub on it,i believe its the switch part which is supposed to screw into somewhere. I have a Corgi registered friend coming in 3 nights to check it all but i wish to put the new thermocoupling in to see if it fixes the problem, but i cannot find any online diagrams to show where to plug the other end into.
If i could be sent a picture of the boiler without the cover on or a diagram showing how and where to plug the honeywell/ Glow worm thermocoupling in,that would be awesome!
Hope to hear back soon.
Best Regards
Matt Garner
    Problem Solver:
  • 11 Answers
The thermocouple most likely plugs into the gas valve, the box with the gas control on it.
Posted on Feb 11, 2009
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
Boiler ignition failer
Try adjusting the gas to air mixture and flow rate. I don't work well in very cold weather, either. I think that's fairly typical. Even a diesel engine is difficult to start in cold cold weather. Perhaps heating the room where the boiler is would help or at lest insulate the room well. Including stopping any drafts that may be causing a windy condition in or around the combustion chamber.
Feb 06, 2014 | Honeywell Triangle Tube Prestige Solo 110...
Burner not quite right
You need to get an engineer urgently , there could be a flue problem , i would suggest shutting the boiler off until then
Jan 23, 2014 | Water Heaters
Hi, I've a fagor feb20e Eco plus combi boiler in
There is a flow sensor in the circuit and it is not sensing the lower flow from just the hot water. When you put it on heat though it does.
May 31, 2013 | Water Heaters
Pilot goes off every two to three weeks
Check voltage at the gas valve and at the thermocoupling. If you are reading more then 24 volts at the gas valve then replace it, or less then replace it also
Feb 10, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
I want to increase the boiler temp by using the your aquastat
Warning! Can cause electrical shock! Here is the instruction manual
for L7248c
http://customer.honeywell.com/techlit/pdf/PackedLit/68-0281.pdf
Jan 12, 2009 | Water Heaters
Protech Systems FasNSeal FSWMKE4 4" Vent Kit for Wall Mounted Boilers & Wat Logo
455 people viewed this question
Top Protech Systems Water Heaters Experts
Paul Carew
Donni Steen
Are you a Protech Systems Water Heater Expert? Answer questions, earn points and help others
