Delonghi PAC S1000 Split Airconditioner
I recently obtained a PAC S1000 split airconditioner. I is an older model, perhaps 2005/2006
I have no operating manual for this unit. However having looked at this model on the Internet, it looks slightly different than the model that I now have. Reason being is that my Unit does not seem to have the quick release/fastening joints.
Question now is how do I get the Compressor unit outside and the Fan inside the room if I can not disconnect the lines?
I would really appreciate some help here
Hello you will need to pump system down and disconnect flare nut or decant gas and then undo flare nutsthis is the only way to remove unit
Posted on Jan 10, 2009
I have a koppel split type airconditioner.my remote was deffective can i use a universal remote control chunghop.what is the code?
There is probably no code built into the Chunghop. If the Chunghop has a "Learn" function then you can teach it the commands using an original remote (hopefully you can borrow one).
Jun 08, 2016 | Universal Remote Control Televison & Video
My DeLonghi CPC 505 Split System Airconditioner stops cooling when the outside temperature reaches 33degr Celsius
Check condenser coil is cleaned. Out door fan motor is working with full speed. If not replace capacitor. And also check Running capacitor.Check gas pressure, if newly charged. Thanks.
Feb 05, 2011 | DeLonghi Heating & Cooling
F8 error
F8 on tamashi ac
Jul 03, 2010 | LG Heating & Cooling
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | LG Art Cool LA181CNW Split System Air...
I have an airconditioner a Kelvinator KSR20C Split system
Your condensor fan motor has more than likely gone out. This fan should run at all times when the unit is on. Since the fan isn't working then the motor must have gone out.
Dave
Nov 16, 2009 | GE Zoneline AZ38H12DAD Split System Air...
I recently obtained a PAC S1000 split airconditioner. I is an older model, perhaps 2005/2006 I have no operating manual for this unit. However having looked at this model on the Internet, it looks slightly...
They will have to be cut and brazed.
Regular solder will not hold.
High temp brazing is required.
Also, it is illegal to cut into a refridgerant system without first recovering the refridgerant. It is also illegal to tap into refridgerant systems without having an EPA certification. It can result in very hefty fines.
I know thats probably not the answer you were hoping for. Howver, I would be neglecting my duties to not inform you of it.
Again, to directly answer your question.
If there are no disconnects on the refridgerant lines, they would have to be cut, and rebrazed.
This requires recoveery of refridgerant, vacume of the system, and an EPA certification.
Jan 10, 2009 | Heating & Cooling
MANUAL OPERATION OF SPLIT SYSTEM AIRCONDITIONER
In every model there different location of manual button. Some manual button are located in front of the indoor and some are at the back of the front grille near the control board.
Jan 24, 2008 | Heating & Cooling
Heating & Cooling Logo
353 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
