Question about Canon PowerShot A95 Digital Camera
Have a canon digital ixus i zoom and e18 just flashing up and the lens wont move
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 11, 2009
SOURCE:
What does E18 mean
Lens error. Try http://www.e18error.com/ for help on fixing it.
Jun 29, 2014 | Canon PowerShot SD30 / IXUS i Zoom Digital...
Tip
Working with E18 and cannon cameras
he E18 seems to be a significant flaw in an otherwise great camera.
It is a flaw well know by users of Canon Powershot and Ixus cameras and is currently not acknowledged by Canon as a flaw in camera design.
HOW IT ALL WORKS:
Canon E18 error happens when the lens gets stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
Apparently, people who posted about this incident on forums say they had to send the camera for repair and that Canon has horrible customer support and response time.
The problem usually happens because dirt or sand get into the lens mechanism. But it seems that more and more people are showing, who took great care of their camera, and still started receiving E18 errors.
It seems that the problems have been happening with the following types of Canon cameras:
- Powershot A40
- Powershot A60
- Powershot A70
- Powershot A75
- Powershot A80
- Powershot A85
- Powershot A95
- Powershot A400
- Powershot A410
- Powershot A430
- Powershot A510
- Powershot A520
- Powershot A530
- Powershot A540
- Powershot A610
- Powershot A620
- Powershot S1 IS
- Powershot S2 IS
- Powershot S10
- Powershot S30
- Powershot S40
- Powershot S45
- Powershot S50
- Powershot S60
- Powershot S70
- Powershot S80
- Powershot S400
- Powershot S410
- Powershot S500
- S100 / Digital Ixus
- S110 / Digital Ixus V
- S200 / Digital Ixus V2
- S230 / Digital Ixus V3
- S330 / Digital Ixus 330
- S400 / Digital Ixus 400
- S410 / Digital Ixus 430
- S450 / Digital Ixus 55
- S500 / Digital Ixus 500
- S550 / Digital Ixus 750
- SD20 / Digital Ixus i5
- SD30 / Digital Ixus i Zoom
- SD100 / Digital Ixus ii
- SD110 / Digital Ixus iis
- SD200 / Digital Ixus 30
- SD300 / Digital Ixus 40
- SD400 / Digital Ixus 50
- SD450 / Digital Ixus 55
- SD500 / Digital Ixus 700
- SD550 / Digital Ixus 750
- SD600 / Digital Ixus 60
- SD630 / Digital Ixus 65
- SD700 / Digital Ixus 800
- SD800 / Digital Ixus 850
- SD900 / Digital Ixus 900
Instructions
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
There are 2 other guides, one Bulgarian and one Estonian with the take apart procedure for Canon cameras. They are not in english but have a lot of pictures which help with the process.
- Bulgarian guide
- Estonian guide
on Jan 03, 2010 | Cameras
I am getting a message E18
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
In this link could check additional details: e18error.com
Hope helps (remember tp rate this answer).
Mar 29, 2011 | Canon PowerShot SD550 / IXUS 750 Digital...
Won't turn on. I press the power on button and the lens won't come out. It's revealing an E18 code on the display.
E18 = ZOOM LENS ERROR
Movement of the lens barrel did not end
within the specified time.
caused by MAIN PCB ***’Y
Feb 04, 2010 | Canon PowerShot S400 / IXUS 400 Digital...
E18 error on Canon ixus40 - lens stuck
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon powershot sd300 e18 error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 16, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
CANON POWERSHOT SD400
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Jan 16, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
E18 problem - zoom lens does not work, can't take a picture
If you can find this crappy site, then you must have enough talent to find canon.com. Duh?
Aug 26, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
E18
E18 indicates a lens or "optical unit" problem. In other words your zoom lens won't function correctly. Canon will be more than willing to look after you.
Mar 29, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot A95 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
